#1 |
I'm off to Belgium to shoot some motocross next week,and I'm hoping the weather will be good.I will be using a 70-200 2.8 for most of it and I was wondering whether many of you shoot with a polarizer fitted. I never have in the past but was thinking it might help when getting the air shots.Most shots will be at 500th sec or above.
| sponsored links |
#2 |
I guess the air shots will look nicer with a polarizer, provided you shoot at an angle of approx. 90 degrees to the sun. You'd loose 2-3 stops with a polarizer, so in order to freeze action, you would have to take this into account.
Kidn regards, Wim |
#3 |
I've used the polarizer at the track to help with reflections from windshields. And when you get a bit of sky in there (because you have to stand so far away and don't own a 500 or 600mm lens) it definitely looks better.
| sponsored links |
#4 |
Motocross sounds like it has a potential for flying mud so a filter of some sort would be good insurance.
Personally, I only use a filter on my 70-200 f/2.8 when it's neccessary as I think the results are better without it....UV filter that is...I don't have a Polariser that size yet.
1Dx (2), 1D4, 5D2 (IR)>> EF600L, EF400L, EF300L, EF300L, EF200L, EF200LII, EF180L, EF135L, EF100L, EF85LII, EF50L, EF35L, EF24LII, EF24-70L, EF24-105L, TS-E24LII, TS-E45, TS-E90, MP-E65, EF135SF, Zeiss 15/2.8, 21/2.8, 25/2, 28/2.8, 35/1.4, 35/2, 50/1.4, 50/2, 85/1.4, 100/2, T/C's, L-SC and a WIFE! Last edited by Canon Bob : 29th of July 2007 (Sun) at 10:03. |
#5 |
Thanks for the replies,If it's blue skies then I'll probably give it a go just to satisfy my curiosity.
| Thread Tools | |
| Display Modes | |
| Difference between Circular Polarizer and Linear Polarizer | TriguyTodd | Canon G-series Digital Cameras | 5 | 30th of January 2011 (Sun) 15:57 |
| Warming Polarizer or regular polarizer? | jjasc | Canon EF and EF-S Lenses | 2 | 23rd of July 2007 (Mon) 16:24 |
| Moose's polarizer vs. Standard polarizer | Just Be | Small Compact Digitals by Canon | 2 | 13th of June 2006 (Tue) 15:18 |
| Polarizer filter in motorsport | eos-rob-uk | Sports | 7 | 22nd of July 2005 (Fri) 03:23 |
| Polarizer vs Circular Polarizer | COKE CAN | Canon EF and EF-S Lenses | 13 | 20th of April 2005 (Wed) 16:01 |
