Thread started 04 Aug 2007 (Saturday) 13:57
Prev/next
Tokina 10-17mm Fisheye vs. Sigma 15mm Fisheye + Sigma 8mm Fisheye
Valiant
Valiant's Avatar
Moscow, Russia
Aug 04, 2007 13:57 |  #1
Tokina 10-17mm Fisheye-zoom vs. Sigma 15mm Fisheye + Sigma 8mm Fisheye for the full frame 24x36mm sensor camera (Canon 5D).
Now I have a lens Sigma 8mm f/3.5 Fisheye (new, not a f/4) and I have borrowed Sigma 15mm f/2.8 Fisheye at comrade. But I think, that Tokina 10-17 (with shaved sun-shade) is very interesting lens too.
I have some questions about Tokina 10-17mm Fisheye-zoom:
1. Is contrast in conter-light shoot strongly falls?
2. Was it easy to correct CA and suppress blooming?
3. What diagonal angle of view is usable at 10-12-14mm focal length?
4. Is flare effect pronounced?
5. Is nodal point "floating"?
Thanks for any help.
Canon EOS 5DMarkII, EOS 5D, EOS 5 (non-D), 24-70/2.8L, 135/2.0L, 70-200/4L IS, 580EX | Sigma 15/2.8 EX Fisheye, 8/3.5 EX Fisheye | Tokina 10-17 Fisheye | Helios 85/1.5 | Contax-CarlZeiss 50/1.4 etc...
Valiant
Valiant's Avatar
Moscow, Russia
Aug 06, 2007 15:25 |  #2
Have anybody some suggestions?
asylumxl
Stuck in an invisible box
Aug 06, 2007 15:29 |  #3
seeing as you have a 5d, the major problem with it for you is that the 10-17 is designed for APS-C sensors, eg. like the 400d/30d. it will vignette very badly.
I M A G E I N A T I O N
..........WEBSITEexternal link
Pixel peeping is like count the sides of a circle, pointless.
GageYoung
Ocala, FL
Aug 06, 2007 15:31 |  #4
Valiant wrote in post #3668375external link
I use a Tokina 10-17mm Fisheye-zoom .. and I have no idea what you're talking about :lol:
All I know is that it's a really fun lens to use!
Gage
www.gageyoung.comexternal link
www.gageyoung.tumblr.c​omexternal link
www.gageyoung.bigcarte​l.comexternal link
www.flickr.com/gageyou​ngphotography
www.twitter.com/gageyo​ung
Valiant
Valiant's Avatar
Moscow, Russia
Aug 06, 2007 15:39 |  #5
asylumxl wrote in post #3678922external link
I'm going to buy this lens for spherical panoramas ( http://www.3dpanorama.​ru/gallery/external link )
Vignetting is not problem.
asylumxl
Aug 06, 2007 15:50 |  #6
http://michel.thoby.fr​ee.fr ...Intricate_Panograph​y.htmlexternal link
here is an article about it on the 5d. you will need to modify the lens, as the sunshade is designed for APS-C, and therefore voiding your warranty. is it worth it for 7 degrees extra FOV over your 8mm?
wimg
wimg's Avatar
Netherlands, EU
Aug 06, 2007 16:03 |  #7
Hi Valiant,
I'll try to answer some of your questions :).
If you mean, is contrast less with contra-light, the answer is no, provided you expose correctly. I find the results actually quite amazing.
So far I never had the need to do so. Some people say it has lots of (T)CA at the edges, I haven't noticed any to any large degree at all. As to blooming, I guess the kind that is supposed to be generated by LCAs with specular type of highlights, again, I haven't been able to get it to do this. Certainly nothing in any high contrast shots I have made so far. And just to assure you, it is easy to get LCAs with my Canon EF 85 F/1.8 at full aperture :).
If you mean on a 5D, I can't really help you here, except that Michel Toby reckons with a shaved lens hood, which could be shaved even more when you're even braver than he is, it is 194 degrees, diagonally, but it vignettes in the corners, similarly to 8 mm on APS-C. Just check the links further down. At 15 mm it is approximately 180 degrees diagonally, on FF anyway, and beyond that it doesn't increase very rapidly, as you are close to the maximum AoV of the lens already. I would think it'll start vignetting rather rapidly after that.
No. You get a start shaped pattern, like you'd get with any lens, caused by the iris diaphragm, plus a few, small diaphragm spots, which are not very conspicuous. Contrast is still very good.
I don't know, I don't normally do panoramics, and I don't have a 5D, so I couldn't tell you. I'll include a few links to the relevant pages on Michel Toby's site.
Tokina vs Nikkor vs Canon: http://michel.thoby.fr​ee.fr ..._Tokina_Nikkor_Cano​n.htmlexternal link
Panography (example): http://michel.thoby.fr​ee.fr ...Intricate_Panograph​y.htmlexternal link
Shaving the hood: http://michel.thoby.fr​ee.fr ..._the_hood/Wim_metho​d.htmlexternal link
Location of nodal point: http://michel.thoby.fr​ee.fr/Locate%20point%2​0nodal.htmlexternal link
Something on CAs and fisheyes: http://michel.thoby.fr​ee.fr ...length_impact_on_TC​A.htmlexternal link
and: http://michel.thoby.fr​ee.fr ...sion_and_reality_TC​A.htmlexternal link
HTH, kind regards, Wim
5D Mk II & EOS 5 (analog) with a gaggle of primes & a solitary zoom, OM-D E-M1 Mk II, Pen-F & Panasonic GM5 with 11 primes, 8 zooms, 3 Metabones adapters/speedboosters​, and an accessory plague
wimg
wimg's Avatar
Netherlands, EU
Aug 06, 2007 16:06 |  #8
It will not vignette from approximately 15 mm on a 5D, where it still has a 180 degree diagonal AoV, IOW, it is still a full-fledged fisheye at that FL, for the 5D.
This is really the universal fisheye for dslrs, the way I see it:
180 degree diagonal AoV at 10 mm for APS-C, at 12-13 mm for APS-H, and at 15 mm for FF!
Kind regards, Wim
asylumxl
Aug 06, 2007 16:09 |  #9
its strange that you say at 15mm it gives you 180 deg fov at 15mm, cos i posted a link to the same guy just before you did and he measured it as much less?!
wimg
wimg's Avatar
Netherlands, EU
Aug 06, 2007 16:09 |  #10
asylumxl wrote in post #3679050external link
It's 194 degrees, so 14 more :). And according to Michel, if you are really brave, you could tweak out a few more degrees, by more aggressively cutting back the remaining rim :).
Kind regards, Wim ;)
asylumxl
Aug 06, 2007 16:11 |  #11
i must be reading from the wrong place. 193.6 i see now, from 12.5mm. wimg can you explain why 10mm on it has less fov than 12.5mm? there is still the warranty issue though :p.
wimg
wimg's Avatar
Netherlands, EU
Aug 06, 2007 16:16 |  #12
asylumxl wrote in post #3679194external link
I think you were reading HFOV and VFOV, of 93 and 140 respectively, for a portrait oriented image. That makes for a 180 degree AoV diagonally.
Kind regards, Wim
wimg
wimg's Avatar
Netherlands, EU
Aug 06, 2007 16:18 |  #13
asylumxl wrote in post #3679208external link
I just did :). It is Circular FOV (= diagonal FOV) vs horizontal and vertical FOV :).
And yes, there is the issue of the lens warranty :).
Maybe someone should write Tokina, to make the hood detachable :). I don't think they realize what a gem they really created with this lens :).
Kind regards, Wim
asylumxl
Aug 06, 2007 16:22 |  #14
wimg wrote in post #3679274external link
could have a tokina 10-17mm II, like the 200 f2.8L II :D
Valiant
Valiant's Avatar
Moscow, Russia
Aug 06, 2007 16:35 |  #15
I saw this web-site. In the testexternal link Tokina 10-17 is very well, but in the real panoexternal linkcontrast is too low and flare is too high. Questions are remain.
I know, that I should shave this lens. But I wish to have a universal lens, for quick pano and hi-rez pano also.
Pro for Tokina 10-17 (at 10 or 12mm) vs. Sigma 8mm:
- Percent of utilization on much more, but in both cases 3 shot for 360*180 pano is required only
- Sigma 8mm has "floating" nodal point, Tokina 10-17mm - ?
16,359 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00163 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is Oldkasilof
941 guests, 482 members online
