Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 7th of August 2007 (Tue)   #1
a570is
Default A570 Lens Flare?
Hi, I've been testing out my new A570 and I've noticed some severe lens flares. Please see the photos here:
http://s180.photobucket.com/albums/x310/nivek-photo/
The strange thing is that none of these shots are straight into the sun (or facing any really bright light source). All of these shots were taken in the shade. I also made sure the lens is free of dust particles.
Notice that these "flares" occur at almost identical spots. Could this be dust on the CCD? But these don't show up on all photos... (see photos)
I'm a bit confused, any insight is greatly appreciated.
a570is is offline   Reply With Quote
Old 8th of August 2007 (Wed)   #2
BBoi
BBoi's Avatar
Default Re: A570 Lens Flare?
Odd, looks like some dirt/dust on the inside of the glass.
BBoi is offline   Reply With Quote
Old 8th of August 2007 (Wed)   #3
a570is
Thanks for the reply. I think you are right. I've looked pretty closely at the outside and there's no dust so it must be in the inside or the sensor. The strange thing is that it doesn't show up on all the shots...
I will try a couple more shots and if it persists, then I will try to exchange it for another.
Old 8th of August 2007 (Wed)   #4
brantfordbandit
brantfordbandit's Avatar
i had a similar problem. all the spots where in the same spot, never noticed at first but they where really noticable on a whitish background, exchanged it for a new one and sofar so good/
www.markephotography.com
brantfordbandit is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
The Lens Flare azkul Presentation 5 30th of August 2007 (Thu) 11:15
Lens flare or something else? Bill Boehme Canon EF and EF-S Lenses 29 19th of July 2007 (Thu) 19:30
Is this lens flare? ebann Canon EF and EF-S Lenses 8 13th of July 2007 (Fri) 01:44
PS CS2 help: Lens flare with bigger "sun", less flare Floriantrojer.com RAW, Post Processing and Printing 2 22nd of May 2007 (Tue) 09:49
Lens flare fkh Wildlife 2 29th of May 2006 (Mon) 12:27
