Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The POTN Lounge
Reply
Thread Tools Display Modes
Old 8th of August 2007 (Wed)   #1
Canon Bob
Default A good lens and a grip
Hi,
I took some advice that I would need a good L class lens and a grip to get me on the road.
Puchased them and raring to go....what do you press to take the picture?
PS...there's something called a 30D in the post...not sure what it is exactly but hopefully it will help.
Bob
1Dx (2), 1D4, 5D2 (IR)>> EF600L, EF400L, EF300L, EF300L, EF200L, EF200LII, EF180L, EF135L, EF100L, EF85LII, EF50L, EF35L, EF24LII, EF24-70L, EF24-105L,
TS-E24LII, TS-E45, TS-E90, MP-E65, EF135SF, Zeiss 15/2.8, 21/2.8, 25/2, 28/2.8, 35/1.4, 35/2, 50/1.4, 50/2, 85/1.4, 100/2, T/C's, L-SC and a WIFE!
Canon Bob is offline   Reply With Quote
Old 8th of August 2007 (Wed)   #2
artyboy
artyboy's Avatar
Default Re: A good lens and a grip
you'll need to mount that on a tank, insert the firing pin and put it to 'Semi'.
Congrats on the new purchase... TWO 70-200s huh?
Canon 1D Mk III, 17-40 F/4L, 24-105 F/4L IS, 70-200 F/4L IS, 24 F/1.4L, 135 F/2L, Canon EF 1.4X II TC, Canon 580EX II, Slik 400DX, Lowepro CompuTrekker/Toploader 70AW
artyboy is offline   Reply With Quote
Old 8th of August 2007 (Wed)   #3
Canon Bob
Only two 70-200's briefly....need to get rid of the f/4, just haven't got around to it yet.
Old 8th of August 2007 (Wed)   #4
Helrain
Helrain's Avatar
Originally Posted by Canon Bob View Post
Hi,
I took some advice that I would need a good L class lens and a grip to get me on the road..
Bob
I think I've cracked the problem.....that lens and grip are clearly on a tree stump and not on 'the road'.
Hope that helps.
Kit List: Canon 40D
Sigma: Macro 70mm F2.8 EX DG, SIGMA 1,4X EX DG Converter, Flash EF 500 DG ST,
Canon: EF 70-200/4L, EF 50/1.4USM,50mm f/1.8 II, EF-S 18-55 f/3.5-5.6 IS
Manfrotto: 190XPROB, 488RC2
Helrain is offline   Reply With Quote
Old 8th of August 2007 (Wed)   #5
radnmad
you need to put batteries into the grip... doh
SomePix
30D, BG-E2, 20D, 17-85 IS, 50mm 1.4, 70-200mm L f/4, 420 EX, 580 EX, plus all the obvious filters, bags and tripods.
Wish List:20-700mm 2.8 IS, Fisheye, Pocket Wizards, Soft Box
radnmad is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #6
cdifoto
Don't get pissy with me
cdifoto's Avatar
Aren't you glad you got that grip? Your rig looks way more professional now.
Did you lose Digital Photo Professional (DPP)? Get it here. Cursing at your worse-than-a-map reflector? Check out this vid!
cdifoto is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #7
Jethro790
Jethro790's Avatar
Yes, yes! It's better to look good than to feel good!
Jethro790 is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #8
laxx
laxx's Avatar
LOL. Mount it on your tripod please. Your 70-200 doesn't have IS
Crumpler 6 Million Dollar Home || Dakine Sequence
40D + BG-E2+ E1 Handstrap
580EX + Stofen || Lightsphere
Tamron SP AF 28-75mm f2.8 XR DI LD Aspherical (IF) Macro || Canon EF 70-200mm f4L USM || Canon EF 85mm f1.8 USM || Canon EF 70-200 f2.8L IS USM
laxx is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #9
Familiaphoto
Familiaphoto's Avatar
I really wish Canon would make the grip white for that lens so it would match. Talk about a fashion issue.
Paul
Blog | Gear | Gallery
Bag Reviews: Domke F-3x | More to come...
Familiaphoto is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #10
davesrose
LOL....you don't have to press anything to take a picture. Just remember to take off the lens cap!!
yeah, I too wonder why Canon only makes telephoto L lenses white. It's like once you get past 135mm, they go from color matched to contrasting white.
Canon 5D
EF135mm 2.0L, EF70-200mm 2.8L, EF 50mm 1.4, EF 100mm 2.8 Macro, Tamron 28-75mm 2.8
davesrose is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #11
rmford
Isn't it for the heat or something? White absorbing less heat, which gives less distortion?
Or is it just because it looks frigging cool?
EOS 400D (Drebel XTi), 18-55 EF-S, 50mm f/1.8 II, 50mm f/1.4, 75-300mm EF III, BG-E3, 580EXII, Slingshot 200AW, Transcend 4Gb.
http://rmford.deviantart.com
rmford is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #12
davesrose
Well the lenses in general do look much better then their Nikon counterparts (which actually are black)!
But I don't believe they're white for a heat issue.....I mean both Canon and Nikon make black camera bodies that absorb heat and could mightily screw up the guts of the camera if it gets too hot. Glass at least can have high tolerances...AFAIK.
Canon 5D
Old 16th of August 2007 (Thu)   #13
Familiaphoto
I'm sure the white is a bit of a status symbol thing. However, there is something with white serving a purpose. Not all Ls are white because not all Ls have the the flourite (sp?) glass which is more subject to uneven thermal expansion. Anyone please confirm. After all, there are white N*kon lenses for this very reason, from what I have seen.
Just my 2 cents.
Paul
Old 16th of August 2007 (Thu)   #14
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Yes, there are white Noink, Minolta and Olympus lenses. But it's not specifically the fluorite - a number of the shorter, non-white, lenses have fluorite elements; it's the large size of the elements and the vast amounts of material that may expand when hot. Try putting a white Canon 70-200 f/2.8 and a black Sigma 70-200 f/2.8 out in the sun on a warm day and see how hot each feels after an hour or so. At least one member's posted on here about having his black camera IIRC and white L out with him - the camera got too hot to touch but the L was still tolerable.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #15
davesrose
Just my 2 cents.
Your hypothesis could be true....I have no way of knowing. It does seem like there is a lot of mystic surrounding fluorite crystals! So some feel that since they're crystals, they may not react well to heat. I've also heard a rumor that the reason NASA doesn't use Canon cameras is because of fluorite in L lenses would shatter from lift off. Well especially with that claim, I'm skeptical. More then likely, they're a government institution that sees no reason to switch from Nikon.
Just as anecdotal evidence, I found a spec sheet of Canon lenses. It does look like all the Ls that have fluorite are white.....but not all white lenses have fluorite. I love my 135mm L, which apparently uses UD elements. Even though it's all black, it looks gorgeous on the 5D: that red ring is a striking accent. You don't get that with the white lenses.....but it does make the black focus ring grips look cool.
http://www.europepress.com/lenses/canon_ff2lenses.htm
and PS about leaving your gear out in the sun all day.....yeah, my black camera doesn't get that hot because I'd poop out from extreme heat before my camera will
Canon 5D
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Aftermarket grip - a good idea? im333 Accessories & Storage 19 17th of July 2007 (Tue) 23:24
Aftermarket grip for 5D....any good? dsoo Accessories & Storage 10 17th of June 2007 (Sun) 01:11
Hahnel 30D Battery Pro Grip any good? NickR Accessories & Storage 2 2nd of April 2007 (Mon) 03:10
3rd-party Grip for Rebel XT- good? imhotep Canon EOS Digital Cameras 4 8th of July 2006 (Sat) 07:29
