Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 27th of June 2002 (Thu)   #1
kinopio
Default Cleaning the LCD screen? (S30)
I seemed to have gotten a... smudge on the screen. Is there special care that I should take in trying to clean it.. like some solution I should use? Just wiping it doesn't seem to work!
kinopio is offline   Reply With Quote
Old 27th of June 2002 (Thu)   #2
Woodchuck
Default Re: Cleaning the LCD screen? (S30)
This is what the manual says on page 143:
"Use a lens blower brush to remove dust and dirt. If necessary, gently wipe the viewfinder and LCD monitor with a soft cloth or an eyeglass lens wiper to remove stubborn dirt. *Never rub or press forcefully on the LCD monitor. These actions may damage it or lead to other problems."
What I do, and it seems to work well, is to breathe lightly on the screen, then I wipe it with a clean soft handkerchief.
Woodchuck is offline   Reply With Quote
Old 28th of June 2002 (Fri)   #3
hapm
If your smudge doesn't come clean with a soft cloth, you made need ROR, residual oil remover. It is made for photographic lens so it should be fine for the LCD. It is available in many photo stores in the US and is meant to be used with lens tissue. I use it with micro cloth.
Hap
hapm is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Spot in lcd screen! Dust or in focusing screen? Kelv2888 Canon EOS Digital Cameras 8 25th of August 2009 (Tue) 19:53
Powershot S30 LCD has White Screen Cment536 Small Compact Digitals by Canon 1 11th of May 2005 (Wed) 06:19
Screen-Shade eliminate glare on LCD screen! trbrogan Canon G-series Digital Cameras 2 23rd of June 2003 (Mon) 14:12
S30 LCD Screen replacement? jfulcer Small Compact Digitals by Canon 0 13th of December 2002 (Fri) 23:35
