#1 |
I've always shot in Aperture priority, but I think I will have lot better control under Manual..
Any tips from all you pro's out there ?
http://www.Photo-Galleria.com Powered By Canon 1D Mark III l 5D with Grip l 50mm f1.8 l 17-40mm f4 L l 135mm f2 Ll 70-200mm f2.8 L IS l 400mm f5.6 L l EF 1.4x II l 580EX II l Feisol CF tripod l Wimberly Head II with F9 Bracket l Better Beamer |
| sponsored links |
#2 |
It's best when lighting is constant or if you have time adjust your settings. Using spot metering is amazing, you can get great results if you know how to use it.
#3 |
You can experiment more with shutter speed, and aperture in manual. You can create certain types of effects (blurred background, panning, etc..) One thing about shooting in manual mode, you have to stay on our toes alot more, and be aware of both the shutter and the aperture, or you will screw up a lot more shots.
Step back please... I'm armed with a camera... _____________________________ Gear - Canon 5D/Grip, Canon 20D/Grip, EF 17-40mm, EF 24-70mm/2.8, EF 28-135mm IS, EF 50mm/1.4, EF 85mm/1.2, EF 135mm/2.0, EF 200mm/2.8, Canon 70-200mm/2.8 Canon 580EX II (3) Other Stuff - Manfrotto Tripods/Heads, Domke bag, Pelikan Cases |
| sponsored links |
#4 |
I use aperture priority 90% of the time. If I am a backlight situation or have some other special requirement I will use manual but it is a great deal more work. For me the camera does a pretty good job of setting the shutter speed. Dennis
POTN Book Vol4 Astronomy Image Manager and BC Member 20D, 5DMkII, 50F1.4, 100F2.8 macro, 135F2, 17-40F4, 70-200F2.8, 24-105F4, 580EX Last edited by Dchemist : 12th of August 2007 (Sun) at 18:45. Reason: spelling |
#5 | |
You can still easily alter the meters idea of the 'correct' exposure by using Exposure Compensation, as long as you know why you are using it, and which way to go. I personally tend to use this method. I'm not knocking Manual exposure, it does give you absolute maximum control, but you must fully understand about exposure and the effect reflected light has on an exposure meter (and mode). As 'pagnamenta' said, if the light is fairly consistant it can be worth using if your subject is in 'tricky' light - I do this at events sometimes, but it is easy to carry on shooting even though the light may have changed slightly without knowing it (I've done it!). A lot will depend on what you are shooting, if you shoot a lot of non-moving, backlit landscapes, it may be a good move. If you shoot fast moving objects from different angles, in changing light, it may not. As I said, this is not a 'dis' of anyone using Manual mode, but just a reminder that it's not always the 'best' mode for any one person or situaltion.
-- K e v i n -- Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4 Canon EOS 3, 24-105L, 135L |
#6 |
I started out shooting Av and then slowly switched to M once i understood what the settings needed to be to achieve the final image i imagined in my head. But like kevin c said nothing wrong shooting in Tv or Av mode they are pretty similar to M mode. Plus in the end your shooting digital if the image doesnt look right shoot again. If your in a situation where only one image can be taken plan ahead and set the camera to get the picture when it happens.
30D - 70-200mm f4 L + 17-40mm f4 L + 50mm f1.8 + 2x Sigma 530 super + Kata R-103 www.viraltheshow.com ••flickr |
| Thread Tools | |
| Display Modes | |
| Shooting manual with flash | digitaljoe | Small Flash and Studio Lighting | 2 | 28th of September 2006 (Thu) 10:50 |
| what settings when shooting in manual | Tshoe | Canon EOS Digital Cameras | 7 | 15th of July 2006 (Sat) 06:23 |
| Shooting in Manual (TIM?) | bpuppy | Weddings and Other Family Events | 3 | 3rd of May 2006 (Wed) 07:00 |
| Where can I learn the basics of manual shooting? | Bad_Habit_Racing | Accessories & Storage | 4 | 20th of January 2006 (Fri) 15:45 |
| Manual shooting with flash | wibbly | Canon EOS Digital Cameras | 1 | 7th of January 2006 (Sat) 19:16 |
