Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Motorsports
Reply
Thread Tools Display Modes
Old 12th of August 2007 (Sun)   #1
tsamarin
Default Wrong Shutter Speed?
I shot these yesterday at Laguna Seca. It was a practice day for next week's Historic Automobile Races. I've got a lot of blur. Does it look like focus or shutter? I'm using a 70-300 and was using 1/320. Too slow? These are some of the more presentable shots-I've got some real junk. Would love some C & C from the experts here, thanks.
30D/ 5D2/ EF 85mm f/1.8 / EF70-300mm/ EF 100-400L/ EF 24-105L/ EF 17-40L/ 430 EX/ 055X PROB/BH-55 & CPL1
http://tsamarin.zenfolio.com
tsamarin is offline   Reply With Quote
Old 12th of August 2007 (Sun)   #2
Wazza
Wazza's Avatar
Default Re: Wrong Shutter Speed?
Great 935 shot! 1/320th is often a good recommend speed for a front three-quarters pan - and you've done well here. Looks very sharp.
The more full side on you can get, the slower shutter speeds become easy.
Wazza is offline   Reply With Quote
Old 12th of August 2007 (Sun)   #3
TCorzett
TCorzett's Avatar
Blur is from the shutter speed, but this is the sort of thing you WANT when shooting motorsports. You need to show motion in the wheels/tires or else everything looks parked. To get the cars sharper, yet still show motion in the wheels/tires/background then you need a smoother panning motion... that just takes practice. The smoother you get, the slower you can go!
-Todd...
Unit One Studios
http://www.unitonestudios.com
TCorzett is offline   Reply With Quote
Old 15th of August 2007 (Wed)   #4
tsamarin
Thanks for the comments. By the way, I've looked at work from both of you and am very impressed. Maybe some day I'll be in the same ballpark!
Old 15th of August 2007 (Wed)   #5
Wazza
Wazza's Avatar
Thanks to you
Mine has just come from some practice, as I had free entry to all the drift events in NZ for the past couple of years, plus open trackdays etc. Events here in UK are SO expensive, I'm not even considering going at this stage. Sticking with landscapes
Old 15th of August 2007 (Wed)   #6
Nightstalker
I like the shots a lot although I suspect that you will hit the same problems that I am with the70-300 - http://photography-on-the.net/forum/...d.php?t=361945 - resized they look OK but the 100% image is very soft.
Nightstalker is online now   Reply With Quote
Old 15th of August 2007 (Wed)   #7
DOverton
I personally like these!
First 1 could do with a tighter crop, or a better crop and it would look really nice too, the second shutter speed is stop on
Takes a while but once you get used to it, you be fine
Dan.
DDSLR Motorsport Photography
DOverton is offline   Reply With Quote
Old 15th of August 2007 (Wed)   #8
mkuriger
mkuriger's Avatar
those are 2 very well done panning shots! All my race pictures look like parked cars. I'm too shaky to pan like you pros!
Michael Kuriger
My Myspace
mikekuriger@gmail.com
Canon 5D Mark II | Canon 30D | Canon 17-55mm F2.8 IS | Canon 70-200mm F4L | Canon 24-70mm F2.8L
mkuriger is offline   Reply With Quote
Old 15th of August 2007 (Wed)   #9
RohrC
As mentioned - I really like the second panning shot. The blurred background looks good and the negative space is ahead of the car - thus showing the action going forwards! Looks bang on! Nicely done!
Would be interested in seeing some more of the shots ...
Christopher
1D MKIII, 30D w/ Grip
70-200 2.8 L IS, 24 - 70 2.8 L, 24 - 105 F4 L IS, 16 - 35 2.8 L, 10 - 22 3.5-4.5
Macbook Pro 17"
RohrC is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #10
tsamarin
Thanks for the comments, gentlemen. I've looked at your galleries, so your words mean a lot coming from photographers of your caliber. In an effort to improve, I posting some of my junk, no PP except for a web save. What would you attribute this softness to, motion or lens blur?
Old 16th of August 2007 (Thu)   #11
Cadwell
Moderator
Cadwell's Avatar
For the last two it looks like it was fairly sunny and hot? I'd like to add another variable to image softness which is all too common when shooting across large areas of gravel and tarmac and that's heat haze. Possible at 300mm and gets worse as your lenses get longer.
Glenn
My Pictures: Motorsport/Canoe Polo/Other Stuff
Cadwell is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #12
adamsti
adamsti's Avatar
Every shot from a DSLR needs to be sharpened. Sharpening is not evil. RAW files by nature are not sharp.
7D, 5D MKIII, 17-40 f/4L, 24-70 f/2.8L, 70-200 f/2.8L IS, 300 f/2.8L IS, 500 f/4L IS, 1.4xII, 2.0xII
"I love the smell of racing gas in the morning"
http://www.timadamsphotography.com
adamsti is offline   Reply With Quote
Old 17th of August 2007 (Fri)   #13
bob393
bob393's Avatar
Thanks for sharing!
The equipment list:
20D, EF-S IS 17-85mm with hood and filters, EP-EX15, Grip BG-E2,
4 2GB SanDisk EXtream III CF cards, Dell Inspiron,
Manfrotto 3205 Tripod, Lowepro Orion AW backpack,
PowerShot A620, And an F1 system in it's case collecting dust!
bob393 is offline   Reply With Quote
Old 18th of August 2007 (Sat)   #14
freebird
Nice pictures. One thing I like to do is selective sharpening to some areas of the car and driver. That way your not sharpening the track and other areas that might bring in significant noise in a cropped shot thats enlarged.
Thanks for sharing,
Chuck
freebird is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Question about aperture vs sync speed vs shutter speed dearis Small Flash and Studio Lighting 3 7th of August 2006 (Mon) 14:23
right place - wrong shutter speed! spud159 Motorsports 8 27th of July 2006 (Thu) 00:40
Wrong remote shutter control pttenn Accessories & Storage 3 16th of July 2006 (Sun) 00:45
Electronic shutter speed & sync speed RhoXS Canon G-series Digital Cameras 2 17th of May 2003 (Sat) 16:18
wrong shutter setting when using flash in ae ... tbeetz Canon G-series Digital Cameras 1 16th of April 2003 (Wed) 09:07
