Reply
Thread Tools Display Modes
Old 13th of August 2007 (Mon)   #1
MaxxuM
MaxxuM's Avatar
Default HOYA PRO1 MC UV Review + Filter vs No Filter Tests
Filter: HOYA PRO1 Digital MC UV(0) ~$44-$64 US at time of review (Mine was $44)
THK Photo's Site – Link to Product
http://www.thkphoto.com/products/hoya/gf-01.html
Canon Rebel XT & Canon EF 70-200 F4 IS @ 138mm
Lighting: Approximately 250w of 5500K light (umbrellas) – All ambient light was turned off.
Testing: Four pictures were taken with and without filter to examine color rendition and contrast in a controlled environment. The “Family of Angles” was adhered to to reduce 'any' reflection or glare within the scene. I picked from the four pictures of each judging on sharpness. All shots were treated identically; one was adjusted for -1/3 EV in Bibble by .33, sharpened by a factor of 1 in accordance with Canon's recommendations (the Rebel XT is by far not as sharp as the 5D or 1D Series), cropped to 8x10, all other settings were unchecked or deselected and the exact settings were applied to the second picture. The full pictures were resized (Bicubic Sharpener) but the 100% crops were saved as JPEG's, posted to Photobucket and then posted here. In truth, the provided pictures are just a formality since the only true data is in the color tests done within Photoshop and I worked exclusively with 8-bit .tif files. They do however provide you with the scene and the range of colors. Please forgive the noise in the photos as I had to shoot at ISO 400 to get the speed up as I do not yet have a tripod ring and the camera did shake enough to blur the pictures at 1/8 (where the lens sweet spot is at 5.6 @135mm). The pictures actually did come out better with me just hand holding with IS on, but to keep it more scientific I used a tripod.
Without HOYA PRO1 Digital MC UV(0) – The Control
With HOYA PRO1 Digital MC UV(0) – The Experiment
At this level I can see a slight difference between the two photos. Now, the following images are 100% crops if what I hope are identical areas of each of the photos. In the 'experiment' I selected three areas to test for color using the first (w/o filter) as the control. Ideally, I should have gotten a color card, but this is what I had onhand. The three spots were 1) The Sea World ticket within the square, the Angle within the 5's semi circle and the first crayon from left to right. Please reserve your opinions as the JPEG comprestion did degrad the quality slightly and who knows what Photobucket does with them
100% Crops of Tested Area
Now, these are the color tests. I found that they are not 100% accurate due to the noise levels which did play a small part in picking the areas I chose to sample. I used Photoshops “Grid” view to make as sure as possible that I was sampling the same areas but since there was so much noise the readings probably were thrown off slightly. Next test I believe I'll use my Tamron lens.. I just love my new L however and could not resist
Ticket
Without Filter - R: 208 G: 209 B: 206
With Filter - R: 208 G: 209 B: 204
Angle
Without Filter - R: 228 G: 84 B: 31
With Filter - R: 225 G: 81 B: 35
Crayon
Without Filter - R: 78 G: 147 B: 184
With Filter - R: 79 G: 150 B: 186
Initial findings in a controlled environment were that there was a slight difference with and without filter and I expected that. You cannot place a $34 filter in front of $1000 of glass and expect there not to be. It was a big surprise however to see more noise in the photo 'with' the HOYA filter. In addition, there is a very slight softening effect on the photo 'with' the HOYA as well. In short, the filter is effecting the image quality of the photo's.
Canon 7D & 60D With Grip's
Canon: EF-S 17-55 F2.8 IS, EF 70-200L F4 IS, EF 85mm F1.8
MaxxuM is offline   Reply With Quote
Old 13th of August 2007 (Mon)   #2
MaxxuM
MaxxuM's Avatar
Default Re: HOYA PRO1 MC UV Review + Filter vs No Filter Tests
Pt. II
The first test was conducted in a controlled setting and did show some difference between with and without filter. There was a slight increase in noise and slightly less saturation of colors. The noise was negligible and unless one was pixel peeping it would go unnoticed by most people. The very slight lack of saturation was constant in all four shots – I could see the difference immediately. However, this can be compensated for in post processing and again, most people would not be able see the difference unless they were told what to look for. Detail however stayed constant – the filter did not seem to effect detail at all.
The second test is a real world test of the filter and is aimed at simply comparing contrast and color. No measurements will be made because there simply is no way to set a 'control' and thus, all conclusions would be highly subject. Again, the photos were treated equally; setting were made with one then pasted to the other so they would be identical. (No hood w/ sun behind me behind clouds, 200mm, ISO400, Cropped to 8x10, EV -1/3, Bibble +.33, WB Sunny, Sharpened +1 and all other settings at 0 or unselected).
Without Filter F5.6 1/160
With Filter F5.6 1/125 (do not know why this changed but it was constant)
100% Crops
Without Filter
With Filter
Again, there is a marked difference. Look closely at the background – notice the bokeh? Again, I was surprised. This effect was constant and could be demonstrated every time. The filtered photos were suffering. Detail seemed to be the same as was overall clarity. Color, saturation and contrast were very slightly changed, but the only way to spot this was through pixel peeping and knowing what to look for.
Conclusion
This was certainly an eye opener for me. In my 'controlled' test there was a slight increase in noise, slightly less saturation of colors but no or little difference in detail. In the 'real world' tests color, saturation and contrast were slightly off and noise was slightly more noticeable. The one issue, the only real one I found for myself, was what happened to the light coming through the trees within the unfocused areas. It was obvious that this filter was effecting the light. I switched back and forth, changed to manual focus and changed F/stop three times – the bokeh flare persisted and increased at F4 and lessened as I went up in F/stop.
So, will I be continuing my use of this filter? Yes. I predominantly go filterless, only using them when the situation dictates. In conditions that are harsh there is no better protection of optics than to use filters. Will I have them on when doing professional or during studio work, no. There simply is no need.
I am sure people will find their own reasons or examples to conclude what they will. I am not here to judge other peoples experiences nor tell them what to do. This was simply a test to satisfy 'my' curiosity and I believe I did.
Old 13th of August 2007 (Mon)   #3
poah
I found no image quality difference when I tested my filters. hoya HMC, hoya S-HMC, Hoya Pro1 digital, hoya pro 1 CP, Hoya CP, kood P-series CP.
Free printer profiles PM me for info
poah is offline   Reply With Quote
Old 13th of December 2007 (Thu)   #4
NEXC
All filters will degrade the ultimate IQ to some degree. The question then becomes does what the filter add e.g. cutting haze for UV or reflections for a polarizer provide a greater overall benefit to the image. In some cases yes but not all. I currently have Hoyas and am looking to upgrade to B+W. Will see how much of a difference that makes.
NEXC is offline   Reply With Quote
Old 13th of December 2007 (Thu)   #5
freddyco
freddyco's Avatar
Ya, I am surprised there are not more definitive tests and reviews comparing no filter versus the various filter and protector brands. I agree, there are times when wearing a filter is best for the image. But most of the time, simply removing the protector will get you the best possible image. It only takes 10 seconds to put it back on.
I don't really notice filter quality so much when viewing on a monitor, but when printing large photos, all filter and lens weaknesses tend to become exaggerated. And to me, the final print on the wall is ALL that matters.
freddyco is offline   Reply With Quote
Old 13th of December 2007 (Thu)   #6
WMWARD2
WMWARD2's Avatar
OP, thank you for posting this. I am fairly new to digital and have the same lens and filter that you used. The results suprised me!
Wally
WMWARD2 is offline   Reply With Quote
Old 13th of December 2007 (Thu)   #7
mmahoney
mmahoney's Avatar
Eye opening .. I've not seen many filter tests and had always presumed the effect of quality filters to be negligable, but that is not the case here.
In the interest of complete control the outdoor test seems to have foilage in the BG which may have moved slightly (and thus affected the reflectvity). I'd like to see one with a constant source of light causing the flare.
Regardless, the effect of these filters is more than I thought. Thanks for showing this.
mmahoney is offline   Reply With Quote
Old 13th of December 2007 (Thu)   #8
TTSkipper
Just curious, for the first tests, you say that you sampled using the grid in PS, but did you use a single pixel to get the color or did you have the picker to select a bigger square of pixes, like 3x3 or 5x5? Since there is noise, I would think that the 3x3 or even better the 5x5 would give a more accurate assessment than a single point.
TTSkipper is offline   Reply With Quote
Old 13th of December 2007 (Thu)   #9
Wilt
Wilt's Avatar
A truly scientific test would involve taking a randomly distributed sample of shots taken with and without the filter (known only to one person helping with the experiment) and then presenting all the photos to an observer who has the challenge of identifying the filterless vs filtered photos. Then if the statistical correlation between 'identified' vs. 'real' is high enough, one can then draw the conclusion that filters do alter images to an identifiable degree.
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is online now   Reply With Quote
Old 13th of December 2007 (Thu)   #10
Double Negative
*sniffles*
Double Negative's Avatar
Filters increasing noise and affecting bokeh? I don't think so.
They might change colors slightly (if the filter has a cast, for example) or saturation (if there are reflections or flare causing loss of contrast).
The color sample size you took seems too small to me to give meaningful color values even with the grid, etc. like TTSkipper mentions.
La Vida Leica! • LitPixel Galleries -- 1v-HS/1d Mk IIn w/E-1 & Op/Tech straps
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Double Negative is offline   Reply With Quote
Old 13th of December 2007 (Thu)   #11
Lester Wareham
Moderator
Lester Wareham's Avatar
If you check out the Protective Filter FAQ (link in sig), you will see that others have been before you.
Comments on your results:
1. Colour Tests: Yes most UV filters will introduce a small colour bias. Look at Q16: "In the case of a Hoya SHMC Pro 1 UV(0) there was a small warming towards red of about 2 steps in 210 (red-blue) or 100K in 5250K in terms of colour temperature. ", the answer includes two small swatches. Not a big issue specially if you take a WB reference.
2. Contrast: Look at Q8: Detailed tests under controlled conditions with in frame relative light source levels about the same level as the naked sun; showed no obvious effect on contrast and for most lenses minimal additional flare and ghosting, the lens being by far the dominant factor.
An exception was deeply recessed lenses where the filter could introduce some ghosting under these very harsh conditions. My concern with your method here is being outside the conditions are not well controlled.
3. Sharpness: Look at Q8 again. This has been tested using SRF/MTF test methods, the addition of the filter made no statistically discernible difference.
Note however, that measurements to this accuracy did show significant camera AF accuracy from shot to shot with or without filter.
Unfortunately this means it is very difficult to measure for any effect on sharpness simply by just comparing two shots, the AF accuracy is just not good enough for that: For that reason this is one of the most common areas that testers have systematic test design problems.
4. Bokeh: I'm not sure what you are seeing here, perhaps you could markup a shot with arrows or circles to show what areas you are referring too. I can see some small difference in what looks like flare, but in uncontrolled conditions this could be due to movements of sun-blocking vegetation or movement of the sun itself.
Now it seems that there can be a very strange double image effects in out of focus areas when single coat filters are used (Again see Q8 for discussion but at this point no examples)
I have checked for this with Hoya SHMC Pro 1 and found no indication of this although I don't have the examples up at present. I have never heard of bokeh problems being claimed for high end filters prior to this.
My Photography Home Page RSS Feed
MP-E, EF 100mm, EF 180mm : The Macro Dark Unholy Trinity : Bow down before their darkness and despair!
Macrophotography by LordV
Lester Wareham is offline   Reply With Quote
Old 13th of December 2007 (Thu)   #12
MaxxuM
MaxxuM's Avatar
I'm glad this has been informative for people. I have purchased more filters to test; Hoya's and B+W (ouch that was expensive) and will be doing more tests once I have the time.
I shot and re-shot the filtered outdoor test several times with exactly the same results. It definitely wasn't controlled, but from what I remember there was no wind and the foliage in the background is a Masquite tree which doesn't move much even when the wind is blowing. I want to try again with the Tamron and see what happens (some people told me later that the 70-200 may have issues with most filters actually – thus me purchaseing a Hoya Pro MC Clear filter).
I should have been more clear – I did try to choose the same pixel but the filtered test did have more noise thus every picture I took and tried to match on the original there was a mismatch. So I did what I could and just selected a pixel right next to it that most closely matched the originals color.
Very good point... If someone else wanted to experiment and add thier findings here that would be great! I did shot many shots though but chose these for the samples.
I should have just said flare and left it as that – but included boken because that was where I noticed it.
Old 13th of December 2007 (Thu)   #13
MaxxuM
MaxxuM's Avatar
Yes, everyone should read these FAQs – very informative! What I was testing was not 'filters' in general but this specific filter. I have purchased B+W multicoat filters now and will be testing them as well. To answer #4 in the last two images, look at the halo's of the OoF lights coming through the trees. In the filtered image they are larger and more predominant vs the unfiltered test. I shot more than 15 shots and they all came out the same way – I went back to the same spot to confirm this after downloading – it happened again. I think I know why now after you reminded me of this: “An exception was deeply recessed lenses where the filter could introduce some ghosting under these very harsh conditions. My concern with your method here is being outside the conditions are not well controlled.” This is what may have been causing that 'flare' like effect I discribed.
Old 14th of December 2007 (Fri)   #14
Lester Wareham
Moderator
Ok MaxxuM it's flare/ghosting and not bokeh as such, that was my guess.
Looking at this pic of the 70-200/4 IS it does not seem to be any more recessed than the 200/2.8 below, perhaps I am wrong, can you supply how many mm is between rear of the filter glass and the top of the lens front element please.
When I say well recessed I mean lenses like the 50/1.4 and to a lesser extent the 300/4 IS. So I would not expect your 70-200/4 IS to show a strong response, of course I have not tested it so I can't be sure.
When you do get a ghosting response of that sort it tends to be strongly coloured as in the example below and normally reduces quickly on stopping down:
That your example shows as white makes me suspect it is due to some small change in environment, but I understand you found it was reproducible.
It is great that you are doing careful tests, take nothing for granted is my motto.
Can I suggest you do some conformational tests using the inside methodology I developed. This removes all chance of environmental variation and improves repeatability. If you use a very sturdy tripod you should be able to compare pixel for pixel with minimal alignment issues by using the difference blend option in photoshop. A description of the methodology and calibration is here http://www.zen20934.zen.co.uk/photog...lare/index.htm
Old 18th of June 2009 (Thu)   #15
Tigerkn
Thanks Max for the info.
Tigerkn is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hoya Pro1 UV filter circa Accessories & Storage 2 4th of March 2007 (Sun) 20:20
WTB: HOYA Pro1 Circular Polarizer 77mm filter sito Classifieds: Buy 0 6th of August 2006 (Sun) 10:59
Hoya Pro1 filter v Pro1 Digital yeleek Canon EF and EF-S Lenses 21 20th of January 2006 (Fri) 16:53
