Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 15th of August 2007 (Wed)   #1
GarrisonCarter
Talking So i just ordered the canon s3.....
and first off i wanna say i cant wait to get the camera. This is my first camera, so i bought just the camera to fool around with until i get a feel and get use to it. But i was wondering if there are any immediate accesories or upgrades that i should worry about at the moment.
GarrisonCarter is offline   Reply With Quote
Old 15th of August 2007 (Wed)   #2
royv
royv's Avatar
Default Re: So i just ordered the canon s3.....
It's a great compact camera that shoots quite sharp images. good choice.
Apart from a bag and some extra rechargeable batteries, there aren't any real accesories you should have from the start..
Expect of some memory cards!!!
Congrats!
Canon 1D mark III | Canon S95 | Sigma 50 1.4 | 17-40L | 135L | 70-200 2.8L
Flickr
royv is offline   Reply With Quote
Old 15th of August 2007 (Wed)   #3
mes448
I think you should consider getting a lens adapter and uv filter. I say this because the lens, as you know, is mechanical, extending every time you start the camera. The adapter keeps the extended lens safe from being bumped or hit accidently and keeps dust from getting into it, if you get a lensmate one you can put a uv filter on the end and you don't have to take it off and on, the lens extends inside the adapter and stops before the lens filter. Get a clip on cap and you don't have to be bothered by the cap falling off all the time and the lens being exposed to scratching.
I recommend Lensmate as I have one with the uv and its so convenient and safe.
Great camera choice.
mes448 is offline   Reply With Quote
Old 15th of August 2007 (Wed)   #4
283CID
Can you spell E N E L O O P batteries ? [grin]... and a 2 GB memory. **GREAT** little 'picture-taker'... Luv It ...
283CID is offline   Reply With Quote
Old 15th of August 2007 (Wed)   #5
JustShootin'
JustShootin''s Avatar
I think everything you need is listed above. I also think you will love your S3, 'cause it takes just down right great pictures!
Gary
Gary
Canon SX40, S100 and a Non Canon dSLR
“Any darn fool can make something complex;
it takes a genius to make something simple.”—Pete Seeger
JustShootin' is offline   Reply With Quote
Old 15th of August 2007 (Wed)   #6
Canon Guy
Canon Guy's Avatar
Just wait til you get bitten by the bug. Then you'll start buying things like high speed SD cards, wide angle lenses, polarizing filters....
But to start, like others have said - a bag, couple of sets of rechargeable batteries, and an SD card or two. I think other Sx IS owners would agree, a Lensmate adapter would be good to have at least to protect the zoom mechanism and give your left hand something more to hold on to. Whether or not you want to pop a UV filter on is up to you. There are some here that will use them to protect the lens, there are others who don't.
300 HS
S110
Rebel XSi: EF-S 18-55 IS, EF-S 55-250 IS, EF 50 f1.8 II, 430 EXII
Canon Guy is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #7
N/A
N/A's Avatar
Welcome to the forums, Garrison. I'm a newbie here too. I agree with the previous posters. Soon after I got my S3 IS I purchased a 52 mm lens adapter, uv filter, and an inexpensive snap-on lens cap from lensmateonline.com. Then recently I picked up a circular polarizer filter. A 2 gig Sandisk card, batteries, charger, and basic case came bundled with my S3.
If you're planning on eventually buying wide angle and/or tele-converter lenses, I believe (at least I think I've read that) you'll need a 58mm adapter though; at least for Canon brand lenses. Maybe someone else here knows the facts about that? I'd suggest researching that before investing money in the 52mm.
N/A is offline   Reply With Quote
Old 16th of August 2007 (Thu)   #8
Aldwyn
Aldwyn's Avatar
Here is a little S3 shot to get your excitement going. This was done in "landscape mode" from the balcony of my hotel room a few weeks ago...
Aldwyn is offline   Reply With Quote
Old 20th of August 2007 (Mon)   #9
alucaaaaaa
Sanyo eneloop is a must I think. I got an eneloop recharge kit(4 batteries and a recharger) which costs me A$29, quite a good deal.
alucaaaaaa is offline   Reply With Quote
Old 20th of August 2007 (Mon)   #10
whuband
whuband's Avatar
Garrison,
In order to avoid frustration, I would not try to learn all the functions at once since this is your first camera. Read through the manual so you know what is there. Then go shoot some photos on auto or P.
If you can learn something new each time you use the camera, soon you'll have it mastered. Now, as for photography, getting that mastered may take a little longer.
Good luck
whuband is offline   Reply With Quote
Old 22nd of August 2007 (Wed)   #11
CincyShooter
this was my first camera that was a "higher end" model. Anyways...I never even knew there were various modes under SCN lol
CincyShooter is offline   Reply With Quote
Old 23rd of August 2007 (Thu)   #12
volivier
i'm ordering a s3 right now myself. Trying to figure out which memory card to purchase. I read that the sdhc card work, (http://www.dcresource.com/reviews/ca...ew/index.shtml) is that what you'd recommend? I'm a newby at this stuff, and do you buy the 4Gb?
volivier is offline   Reply With Quote
Old 23rd of August 2007 (Thu)   #13
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
What are you planning to do with the camera? Unless you're planning on using it for a lot of videos a regular 2 GB SD card's plenty (you get about 9 min. of TV-quality video per GB of card, so 17-18 on a 2 GB, in 9 min. clips which is a camera limitation). You should be able to get around 450-500 Large Superfine (best resolution) stills on a 2 GB card.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is online now   Reply With Quote
Old 23rd of August 2007 (Thu)   #14
volivier
don't want to hijack this thread... i plan on taking photo's of my kids at 4-H/FFA cattle shows and other normal family stuff. we live in the country on a farm so outdoor, kids, animals, school graduations. I have a reef aquarium I want to photo too.
Old 23rd of August 2007 (Thu)   #15
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
So a 2 GB card or two should be plenty.
Jon
Cocker Spaniels
DC Cherry Blossoms
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Just ordered the Canon 70-300 IS! gef Canon EF and EF-S Lenses 3 18th of September 2006 (Mon) 13:45
I Just Ordered My First Non-Canon Lens JimAskew Canon EF and EF-S Lenses 38 12th of September 2006 (Tue) 01:50
Just ordered canon ef 400 f/5.6L 2005GLI Canon EF and EF-S Lenses 18 22nd of August 2006 (Tue) 02:13
Just ordered some new canon glass! slitherjef Canon EF and EF-S Lenses 3 6th of January 2006 (Fri) 23:23
Just ordered the Canon 50mm 1.8 mdm Canon EF and EF-S Lenses 1 1st of May 2005 (Sun) 13:03
