Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Presentation
Reply
Thread Tools Display Modes
Old 17th of August 2007 (Fri)   #1
Amnesia180
Default Expose - Flash Gallery
Hi All...
Has anyone experienced the "Expose" Gallery (its also a plugin for Joomla).
I use this gallery at www.dan-taylor.co.uk (site still under construction)...
I've been told it has many flaws in it, but I'm yet to come across any.
What do you guys think?
Thanks,
Amnesia
Canon EOS 20D | Canon 70-300mm f4/5.6 IS USM | Sigma 24-70 f/2.8 EX DG Macro | EF-S 18-55mm F3.5/5.6
Amnesia180 is offline   Reply With Quote
Old 17th of August 2007 (Fri)   #2
peter graham
Default Re: Expose - Flash Gallery
I think that Expose is the most aesthetically pleasing gallery I've come across. It seems that you need to be lucky to have the right server settings to have things fully functional. Fortunately my web hoster is a few minutes walk away and I can easily get their attention if something isn't working. There was a major security hole that was fixed not too long ago, make sure you have the updated gallery component otherwise your whole site can be hacked!
I'm still working on the site but the design and layout are pretty well finished, with much trial and error I managed to get the gallery aligned neatly into my template: www.skylinephotography.com There's so many small changes I made I can't even remember what I all modified. All except for the frontpage text which does not want to conform, I have things set up the way I want it.
I also use sef urls so it looks like html pages instead of php, although I believe there's hosting requirements which have to be met to enable it.
peter graham is offline   Reply With Quote
Old 18th of August 2007 (Sat)   #3
Amnesia180
Thanks for the info,
I've played around with the theme a little bit and I've decided on my style etc. The gallery fits in nicely now.... just got to update it with photos now!!
Old 11th of September 2007 (Tue)   #4
Torcidas
Torcidas's Avatar
yea Expose gallery is very good but joomla version have some problems with security so you need to delete few files what allow hackers to upload various virusis, and other bastards on your server and start them when someone start gallery..
My current status: Canon 1D Mark II / 17-40 f4.0L / 24-70 f2,8L / 70-200 f2.8L / 100-400 f3.5-5.6 ISL / 50 f1.8 / 100mm f2.8 macro/ Speedlight 550EX / 1,4 extender
My hiking gallery: www.planinarenje.net/galerija
My climbing gallery: http://www.penjanje.net/galerija
My soccer gallery: http://www.hnkhajduk.com/galerija
Torcidas is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RAW vs JPg, Adobe vs Rgb, expose to the right, expose to the left..... AginKajun General Photography Talk 21 19th of April 2007 (Thu) 12:20
I need a gallery - No Flash taygull Presentation 4 2nd of June 2006 (Fri) 17:06
Flash Gallery Se7enUK Presentation 3 31st of March 2006 (Fri) 14:07
Need a Flash Gallery....... leo11877 General Photography Talk 0 22nd of April 2005 (Fri) 12:01
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
