Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The POTN Lounge
Reply
Thread Tools Display Modes
Old 24th of August 2007 (Fri)   #1
20droger
20droger's Avatar
Location: In a semi-civilized small town in southeastern Arizona.
Default Bad Day at Black Rock
Yesterday, we had a major storm, with buckets of rain and much thunder and lightning.
Even though my computer is protected by a UPS, I shut it down.
THIS WAS NOT ENOUGH!
The computer is a Dell Dimension E510. Like most new computers, it doesn't really shut all the way off.
And, you guessed it, a nearby lightning strike (close enough to make all my fan and dimmer controls go crazy) took out the little circuit board that controls the on-off switch. At least, I think that's what got zapped. It's either that or something in the power supply that supplies keep-alive power to that circuit.
I'll know more later.
The moral is: IN A BAD LIGHTNING STORM, DON'T JUST TURN IT OFF, UNPLUG THE DAMN THING!
Meanwhile, I'm temporarily up and running using my wife's computer, with my hard drive installed. I can only do this while she's at work, so I'm limited to 7:30-5:30 daily.
Sigh!! Just what I needed right now.
20droger is offline   Reply With Quote
Old 24th of August 2007 (Fri)   #2
Mom27andblessed
Mom27andblessed's Avatar
Location: Transplanted Detroiter in Clarksville, Tennessee!
Default Re: Bad Day at Black Rock
Aw that just stinks! Sorry it happened! HUGS
Cindy-wife to Chris, Mom to 7! Canon Rebel XT user.
Mom27andblessed is offline   Reply With Quote
Old 24th of August 2007 (Fri)   #3
Karl C
Location: Now: N 39°36' 8.2" W 104°53' 58"; prev N 43°4' 33" W 88°13' 23"; home N 34°7' 0" W 118°16' 18"
Just think of it this way...
When the door of opportunity closes, another window opens. This could be an opportunity to upgrade your computer.
"Yes, honey, I need to purchase a new computer since the lightning strike permanently damaged my existing computer."
Gear: Kodak Brownie and homemade pin-hole cameras. Burlap sack for a bag.
Karl C is offline   Reply With Quote
Old 24th of August 2007 (Fri)   #4
BillsBayou
In trouble with my wife
BillsBayou's Avatar
Location: New Orleans, La. USA! Favorite Cheese: Caciocavallo Invention: Incendiary Spit-Bomb Wait. What?
"Yes, but we're going to have to take it out of your B&H wish fund."
Take only pictures, leave only footprints...
"Cameras don't shoot people. Photographers shoot people." - Me
I must not break rule GN.4, Please help me un-see that photo, I must not break rule GN.4...
BillsBayou is offline   Reply With Quote
Old 24th of August 2007 (Fri)   #5
Pete W
Pete W's Avatar
Sounds like an insurence claim to me
All the best
Pete Woods LRPS
My Gear List
My Website
Pete W is online now   Reply With Quote
Old 24th of August 2007 (Fri)   #6
20droger
20droger's Avatar
Exactly!! Which I why I'll try the fix-it route first.
Besides, It's only a little less than a year old.
Old 24th of August 2007 (Fri)   #7
20droger
20droger's Avatar
$500 deductible. Hopefully it'll cost much less to fix.
Old 24th of August 2007 (Fri)   #8
Cassie
That happened to me about 6 months ago, luckily it only took out the DSL Router, I still have a 'light' spot on the monitor though where it should be blue.
http://thompson-photo.smugmug.com/
5D3 / 7D
40 Pancake, Sigmalux, Keg, 17-40
430 EX II / ST-E2
Cassie is offline   Reply With Quote
Old 24th of August 2007 (Fri)   #9
JWright
JWright's Avatar
I have my computer and all the peripherals hooked up to a surge protector/switch panel. When I shut off the computer, I turn off the switch panel also. This pretty much isolates the computer from the house circuits.
John
JWright is offline   Reply With Quote
Old 24th of August 2007 (Fri)   #10
Eagle
Eagle's Avatar
7D ■ 10-22 ■ 15-85 ■ 28-135 Σ 50-150 ■ 100-400L ■ Vivitar 2X ■ 580EX II
Gear-PC ShutterStock Eagle's Nest Photography SmugMug Alamy
Eagle is offline   Reply With Quote
Old 25th of August 2007 (Sat)   #11
20droger
20droger's Avatar
Most new computers, like TVsand other such devices, have a keep-alive circuit within them.
In the Dell, it keeps the front switch alive, which allows controlled activation and prevents an instan-off, which may damage Windows.
The comuter goes to the shop on Monday.
Old 27th of August 2007 (Mon)   #12
20droger
20droger's Avatar
I'm back up. It took minutes to find the problem. One of the five USB ports available on the back panel was shorted. My choices were:
1: Get a new motherboard = $$$; or
2: Cut a trace and disable that port completely = No charge (not even his posted minimum.
I now have four back-panel USB ports. I can live with that. Hell, If I need more ports, I can always buy a hub!
This is the weirdest computer problem I've encountered since I started programming the 8008 back when Bill Gates was a complete unknown.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Black is Bad? CBRfanatic0429 Canon EOS Digital Cameras 34 26th of May 2007 (Sat) 13:02
Black Rock & Sheraton, Maui calicokat Nature & Landscapes 7 8th of January 2007 (Mon) 13:14
Black Rock Beach/Talbot Islands HrcRacing Nature & Landscapes 10 23rd of September 2006 (Sat) 16:43
Black-crowned Night Heron having a bad plume day... RonnF Birds 18 12th of April 2006 (Wed) 23:49
Black Rock Rainbow saggy9999 Nature & Landscapes 7 29th of August 2005 (Mon) 07:21
