#1 |
Sorry for the second newbie question of the night...
But for some reason, even after reading the manual on the subject, the 580EX II always is at 14mm zoom with an M setting near it. I understand that to be manual 14mm. I have a 24-70mm lens on it, and no matter what I do, I cannot seem to get it to any setting other than 14mm. I thought there should be auto zoom from 14 to 105mm... Any help would be appreciated. Oh and I tried shooting in M, Av, Tv modes.
Gear and Feedback |
| sponsored links |
#2 |
And one more thing.
The flash zoom doesn't seem to be able to change with either manual or auto. In fact it's always in the M thing when in ETTL.
Gear and Feedback |
#3 |
Sorry - this is a 580EX II and that's not the way it works. I push the zoom button then turn the dial until the M goes off.
| sponsored links |
#4 |
Hmm... doesn't seem to work.
Gear and Feedback |
#5 |
That's what the manual says to do also.
When I press the Zoom button and turn the dial any number of times in both directions, nothing happens. I am confused...
Gear and Feedback |
#6 |
do you ahve the diffuser panel pulled out and over the flash? put it back in :P
#7 |
No, I don't have it pulled out.
Gear and Feedback |
#8 |
in manual mode, dont you have to adjust the flash zoom range yourself? i believe the guide numbers are user defined in M mode.
i think it autozooms in ettl. |
#9 |
Push zoom button and zoom on LCD flashes. Turn dial counter clockwise and the M should go off. The push the zoom button one more time.
Zoom the lens and touch the shutter button. |
#10 |
That's what I've been trying, but it does absolutely nothing.
Nothing flashes when I press the zoom button, and nothing changes when in move the dial at all after or before pressing zoom. This is pretty upsetting since it's about 2 weeks old.
Gear and Feedback |
#11 |
Master Flasher
Pull the 14mm panel out, then push it back in. Make sure you push it in all the way.
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
#12 |
Yeah, this is a simple case of the flash thinking that the diffuser is deployed, when it is not.
Of course, your flash may be broken, but I doubt it.
Canon: EOS 50D, EOS 400D, EF 300mm f/4L IS USM, EF 50mm f/1.8 II, EF-S 18-55mm f/3.5-5.6 II, EF 1.4X Extender, Speedlite 430EX Sigma: 10-20mm f/4-5.6, 55-200mm f/4-5.6 | Tamron: 17-50mm f/2.8 | Manfrotto: 055 XPROB tripod, 680B monopod, 804RC2 and 486RC2 heads Kenko extension tubes, Sandisk Extreme III 2GB + 8 GB & Ultra II 4GB |
#13 |
As has been said, a 580EX or 580EX II stuck on 14mm mode thinks that the diffuser is deployed. Either the diffuser isn't pushed fully home, or the switch has stuck.
Pulling out the diffuser and pushing it fully home should solve the problem. David |
#14 | |
Thanks everyone for your help.
Gear and Feedback |
#15 |
i thought i said that -.-, at least you know its not broken
| Thread Tools | |
| Display Modes | |
| 580exII - auto zoom | Rawling | Small Flash and Studio Lighting | 11 | 28th of August 2007 (Tue) 11:59 |
| 580ex Auto Zoom function. | bbc14f | Small Flash and Studio Lighting | 8 | 24th of March 2007 (Sat) 23:32 |
| Zoom or Auto Range on 580EX? | TMR Design | Small Flash and Studio Lighting | 3 | 2nd of November 2006 (Thu) 16:51 |
| 580EX Auto Zoom Question | venmarkid | Small Flash and Studio Lighting | 5 | 10th of March 2006 (Fri) 23:45 |
| 17-85 is lens will not auto zoom the flash | farmer48 | Canon EF and EF-S Lenses | 8 | 8th of January 2006 (Sun) 05:52 |
