#1 |
| sponsored links |
#2 |
"the more I post, the less accurate..."
Photo is soft, possibly motion blur.
Be sure to get your balance, keep your elbows in tight to your body, squeeze the shutter button gently.
David Digital set me free "Welcome Seeker! Now, don't feel alone here in the New Age, because there's a seeker born every minute." www.damphyne.com |
#3 |
Mr. PMS Himself
Did you try to photoshop something out in the lower left corner?...there is some strange stuff going on there...and the image is a bit soft..Bump your ISO to 400 to improve your shutter speed a bit and also to allow you to go to f/5.6 or so...which will give you a bit more depth of field. If you turn on image editing...I will share a rough edit that helps.
You'll never be a legitimate photographer until you have an award winning duck in your portfolio! Crayons, Coloring Book, Refrigerator Art and What I Really Think About Last edited by Woolburr : 26th of August 2007 (Sun) at 12:31. |
| sponsored links |
#4 |
John, the fact that you got this shot in the first place is an accomplishment. They are not easy to catch.
Unfortunately, it isn’t as sharp as it could be. Probably due to a couple reasons. 1. Your shutter speed was only 1/160s, a little slow when using a lens set at 200mm (unless the lens has IS) 2. You used Av with the aperture set at f/2.8 resulting in very shallow DOF at 200mm Increasing your ISO a couple stops will allow faster shutter speed and a smaller aperture which will improve DOF. Arvid
Canon EOS 40D, EF-S 17-85mm IS, EF 70-300 IS DO Sigma 70-300mm DG Macro Tamron 1.4X TC, 200-500, 180mm DI LD Macro 1:1 Nikon CP5700, Nikon 1.5X TC Paint Shot Pro Photo X2 |
| Thread Tools | |
| Display Modes | |
| Swallowtail | Crypto | Macro | 9 | 23rd of August 2007 (Thu) 10:36 |
| swallowtail | photorookie | Wildlife | 1 | 18th of August 2007 (Sat) 17:15 |
| MY SWALLOWTAIL | Bald Eagle | Macro | 18 | 20th of July 2005 (Wed) 17:35 |
| Swallowtail | liza | Wildlife | 13 | 18th of July 2005 (Mon) 13:54 |
| That swallowtail again | Georgees | Critique Corner | 1 | 31st of December 2002 (Tue) 12:33 |
