Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 2nd of September 2007 (Sun)   #1
madplower4
Default Maintaining focal point in sports
I am having problems keeping my center focal point on my subject when they are moving in all directions or running fast. I am using cf 4-3 ai servo etc, but the servo will grab focus on background stuff if I can't perfectly hold my focal point on a moving subject. I was told that there was a way to slow the focus speed to alleviate the instant refocus issue. I was told that I could use a CF? to put that focus speed to medium-slow to help this problem. I can't find how to do this. Any help? It is primarily a problem when shooting soccer and American football, when I am having trouble keeping the focal point on a moving subject. I know one answer is to let off of the *button at times, but I am way too new to master that. HELP
madplower4 is offline   Reply With Quote
Old 2nd of September 2007 (Sun)   #2
asysin2leads
I'm kissing arse
asysin2leads's Avatar
Default Re: Maintaining focal point in sports
Hey, deja vu.
http://photography-on-the.net/forum/...d.php?t=371691
asysin2leads is offline   Reply With Quote
Old 2nd of September 2007 (Sun)   #3
Nightstalker
From what I've read on here you should run AIServo with all focus points active.
IIRC it will base lock on from the center and use the outer points for tracking.
I may be talking BS but I'm sure I've read this on the forum.
Nightstalker is offline   Reply With Quote
Old 2nd of September 2007 (Sun)   #4
scott wiggins
Folks, it might help if you tell everyone what camera model you are using.
Sounds like you need to slow the tracking speed down. The centre spot is the most sensitive spot and tracks vertically and horizontally in all of the entry level/prosumer bodies. I'm just learning the 1D at the moment so can't yet comment on that. That was the case with my 20D; using the centre spot helps to get focus on what you want and not on something you weren't bargaining on.
Scott
1D MkIII, 7D, 5D MkII, Canon 70-200L f2.8 IS, Canon 17-40 f4 L, Canon 24-105 f4L, Canon 1.4x TC II, Canon 24-70 f2.8, 100 macro, Canon 100-400 L, Canon 50 f1.4, Sigma 10-20, 580 EX flashes & ST-E2
See my pics online at www.srwiggins.smugmug.com
scott wiggins is offline   Reply With Quote
Old 2nd of September 2007 (Sun)   #5
dmwierz
dmwierz's Avatar
Plower - You can try messing with your AI Servo speed, but whenever I've done this, I've hosed things up more than I helped them.
In the end, what you are experiencing is exactly what makes sports photography so challenging. It's not easy to get consistently in-focus images of subjects that are moving fast and unpredictably.
The best thing you can do, IMO, is to practice, practice and practice..
Personally, I've tried expanding my focus points, moving them around, changing AI Servo speeds (as mentioned above), using multiple points, etc., and I always, always come back to center point AI Servo as my method of AF. With this scheme, I get the highest % of keepers far and away.
Try a few of the suggestions here and see if they help, but I'm guessing what's needed more than anything isn't a new AF scheme, but just more time behind the lens.
Good luck, and I look forward to seeing your work.
Dennis
http://www.denniswierzbicki.com
http://www.sportsshooter.com/dmwierz
Dennis "
Yeah, well, sometimes nothin' can be a real cool hand."
dmwierz is offline   Reply With Quote
Old 2nd of September 2007 (Sun)   #6
superdiver
superdiver's Avatar
Like Dennis I have gone from center point to all points to moving point and am back at center point right now. Who knows I may try other points again in the future...thats the curse of always looking to improve...
But the more I shoot the more consistent I get, I find that the gadgetry and little to do with consistency and practice has every thing to do with it...
Not trying to be discouraging or talk down to anyone as I am by no means a pro, just a long time learner with a long way to go....LOL
40D, davidalbertsonphotography.com
Newbie still learning
superdiver is offline   Reply With Quote
Old 2nd of September 2007 (Sun)   #7
i601254
Have to agree with Dennis as well. After getting my first Canon (1D MK II) I spent 6 months trying every conceivable setting and found that AI-Servo with center point AF worked best for me. AF point expansion in theory sounds great but I quickly found that I was getting far fewer keepers when using this setting. I've also pretty much settled on moderately slow setting for AF speed. As stated it really does come down to knowing your equipment and practice, lots of practice. There are far too many people who think that just because they own a pro body DSLR and some expensive long lenses that magic just happens on its own. The first thing most inexperienced photographers do is to assume that there's something wrong with their equipment. While bodies and lenses to need regular servicing, the majority of issues can be attributed to lack of experience and unreal expectations. Keep honing your skills and it will all begin to fall into place eventually.
Steve Ickes
PhotoFX Pros
1D MKII (x2) | 70-200 f2.8 | 24-70 f2.8 | 50mm 1.4 | 300mm f2.8 | 400mm f2.8 MKII | and my irreplaceable Think Tank Modulus system.
i601254 is offline   Reply With Quote
Old 2nd of September 2007 (Sun)   #8
asysin2leads
I'm kissing arse
I agree. Played around w/ the focus points while shooting soccer. Center point worked out the best. Had the highest % of keepers. I've read on here somewhere that if your shooting baseball, set you focus point just above the belt line. I tried that and it seemed to give me the best results.
Old 2nd of September 2007 (Sun)   #9
cwphoto
Go ahead, make my day
cwphoto's Avatar
Location: Kellyville, Baulkham Hills, Cumberland, NSW, Australia
Sounds good in theory but centre-point is more consistent/precise.
EOS 5D Mark III | EOS 600D | EOS-1V HS
L: 14/2.8 II | 24/1.4 II | 35/1.4 | 50/1.2 | 85/1.2 II | 135/2 | 180/3.5 Macro | 200/2.8 II | 400/2.8 IS | 16-35/2.8 II | 24-105/4 IS | 70-200/2.8 IS II | 100-400/4.5-5.6 IS.
Sundry: 580EX II | 12 II | 25 II | OC-E4 | BG-E6
cwphoto is offline   Reply With Quote
Old 3rd of September 2007 (Mon)   #10
superdiver
superdiver's Avatar
So how often do you guys have your stuff in for regular maintenance, or do you do it only when there is a problem, and if you do send it in "regular" where do you send it, how much does it cost and how long does it take?
Old 3rd of September 2007 (Mon)   #11
cwphoto
cwphoto's Avatar
Never. Only when it breaks.
Old 3rd of September 2007 (Mon)   #12
apexnow
apexnow's Avatar
Believe it or not, that is one of the most helpful comments I have heard. After my very first outing with my very first SLR camera, I had 200+ pictures with no feet. I then told my self, "aim lower" but still had the same trouble. Instead of trying to aim lower I will do as you have suggested, aim at the belly. I think that using only the center focus point will also help. I had a lot of great pictures that the background was in focus but not the player I was shooting.
I am sure that some are sighing and thinking, "dang rookies", but hey, that is where I am at.
Canon 400D / Canon EFS 18-55 / Promaster 70-300 / a black bag
apexnow is offline   Reply With Quote
Old 3rd of September 2007 (Mon)   #13
dmwierz
dmwierz's Avatar
Once you get to know your equipment, how it responds and what to expect from it, you'll know when something is wrong, so to second CW's comment, I only send my stuff to CPS when it breaks. I can't be without it for more than a few days at any time so soething pretty bad has to be wrong for me to send it in.
Dennis "
Old 3rd of September 2007 (Mon)   #14
madplower4
Thanks to all for the advice. I am using a 30D. To again reiterate the dilemna, as an example, when a running back is running down the field at full speed, I am using cf4 *button for focusing, but keeping the center pt focal pt on a kid running at full speed is HARD! Keeper, blur, blur, keeper, blur, keeper. You get the point! Anyways, it just seems that the answer is practice! I just thought I had heard that slowing the focal change speed helped, but didn't know how to do that.
This photography thing is like golf! Everytime you get better, you realize that there is a next level of "better" to achieve.
And one last question....How come the truly great keepers that I get are always of someone else's kid? The one's of my kids are usually the lousy ones, but a get great shots of kids I don't even know!!!!!![IMG]file:///C:/Users/Jeff/AppData/Local/Temp/moz-screenshot.jpg[/IMG]
Thanks again to all for your advice.
I am using a 30D, 70-200 is, with a 1.4 extender when needed.
Old 3rd of September 2007 (Mon)   #15
cwphoto
cwphoto's Avatar
I'd suggest going away from *-button focus for a start. Just because a few SI guys use it doesn't mean it's best practice for YOU.
Leave it on the shutter button and I reckon your keeper rate will improve. Once your technique improves then you can experiment with it isolated.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Maintaining focal point in sports madplower4 Sports Talk 2 2nd of September 2007 (Sun) 19:19
Focal point of 85mm F1.2 MK II enquiry@tcbrake.com Canon EF and EF-S Lenses 7 28th of June 2006 (Wed) 15:29
Focal Point Tuna Still Life, B/W & Experimental 4 11th of July 2005 (Mon) 14:36
Maintaining focal point madplower4 General Photography Talk 6 25th of May 2005 (Wed) 07:46
Setting Focal Point - 300d Mr.B Canon EOS Digital Cameras 2 26th of June 2004 (Sat) 15:11
