Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 11th of July 2004 (Sun)   #1
riker
Default sd110
i'm considering buying an sd110 when i visit the States at the end of this month. Will it work if i bring it home to Ireland, I 'm worried that the adaptors for the power may not work here in ireland?
riker is offline   Reply With Quote
Old 12th of July 2004 (Mon)   #2
dtrayers
dtrayers's Avatar
Default
My SD100 (very similar to the SD110, the SD110 adding PicBridge support and a print button) manual says the charger voltage range is 100-240V and 50/60Hz. I would assume that Ireland falls in that range.
The supplied charger fits the standard two prong US outlet. You may need an adapter. A corded charger is available.
The camera takes excellent pictures and is very portable. These were taken in February skiing with the kids:
http://home.comcast.net/~dtrayers/welch/
-Dave
http://www.trayersphotography.com
dtrayers is offline   Reply With Quote
Old 12th of July 2004 (Mon)   #3
JohnnyE
Default Just Beware
That's right, only a plug adapter will be necessary so that it will fit into your outlet. No voltage converter will be needed. One problem is that it will not be under warranty in Ireland - in other words, if it fails, you will have to pay for the repairs at Ireland's service centers. See if you can purchase an extended warranty that will be honored in Ireland just in case.
JohnnyE is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Focus Problems SD110 jmvar Small Compact Digitals by Canon 1 3rd of October 2005 (Mon) 23:07
SD110 Firmware Hack Orko Small Compact Digitals by Canon 1 3rd of September 2005 (Sat) 02:38
SD110 versus S410 Mildot Small Compact Digitals by Canon 0 16th of June 2005 (Thu) 22:04
SD110 vs. A510 makocha_m Small Compact Digitals by Canon 2 27th of April 2005 (Wed) 13:45
Problems with the Canon SD110 B-tray Small Compact Digitals by Canon 3 27th of December 2004 (Mon) 08:11
