Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 8th of September 2007 (Sat)   #1
Stewx
Stewx's Avatar
Default How to dodge/burn smoothly
Hi,
Do you guys have any tips for dodging or burning smoothly in Photoshop (CS3, to be specific)? I just find that when using my mouse, the strokes I make are really uneven and you can clearly see the circle shapes where I used the dodge or burn tool.
Thanks,
Stew
40D /w Tamron 28-75mm f/2.8, Canon 50mm f/1.8, 430EX
Stewx is offline   Reply With Quote
Old 8th of September 2007 (Sat)   #2
SoCal69
Default Re: How to dodge/burn smoothly
I'm not sure this answers your question directly, but this tutorial may help...
http://www.dpchallenge.com/tutorial.php?TUTORIAL_ID=55
SoCal69 is offline   Reply With Quote
Old 9th of September 2007 (Sun)   #3
lecherro
It Takes practise iether way, but what i do is set my dodge or burn tool to a lrager softer edge, and sett the intensity very low. That way the "stroke" is not as obvious and the effect is low, and if I need more effect go over it agian. Better to use to little than too much. Also good to copy major layers before effecting in any way to save what ma eventually get screwed up. I know there is undo, but these are also computers that have a mind and will of thier own sometimes and its better to be safe than sorry. Hope this helps.
First step........ Take the lens cap off.
lecherro is offline   Reply With Quote
Old 9th of September 2007 (Sun)   #4
Robf
as above, soft edge, lower % and working on a duplicated layer. After a while you can gain more confidence and just use the % higher and hit it in one go.
Robf is offline   Reply With Quote
Old 9th of September 2007 (Sun)   #5
Mcary
Mcary's Avatar
Tip #1 Don't use the dodging and burning tools
1. Open Image
2. Add new layer -Mode choose Overlay and check the box that say fill overlay with 50 gray
3. Press the D key to return the for ground and background colors to Black/White
4. Select the brush tool and choose soft edge brush set the opacity to 30% to start and adjust as need to get the desired results
5. For the areas you want to dodge set the for ground color to black and for the areas you want to burn.
Mike
OMG I saw a nipple, my eye's are bleeding!
Visit http://www.mcaryphoto.net (Nudity) warning most images found on this website were shot with cheap plastic lens (50mm 1.4 85 1.8 and 35 2.0)
Mcary is offline   Reply With Quote
Old 9th of September 2007 (Sun)   #6
queenbee288
queenbee288's Avatar
1. Open Image
Mike
This is what I do too but I start off with opacity of 5%.
Char
www.lanephotography.smugmug.com
Canon 7D, Sigma 70-200, Tamron 28-75, Canon 100 2.8, 50 1.8,
queenbee288 is offline   Reply With Quote
Old 9th of September 2007 (Sun)   #7
Jon, The Elder
teaching fish to ride a bicycle
Jon, The Elder's Avatar
Thanks folks ......comes in handy for those Western style hat shadows I'm always fighting.
A 40D, a 30D, some nice glass and a great Shooting Partner.
"...As in music, so in life."
Jon, The Elder is offline   Reply With Quote
Old 9th of September 2007 (Sun)   #8
cosworth
I'm comfortable with my masculinity
cosworth's Avatar
I take three RAW files, one 0 EV, one +1 and another -1 EV. I layer mask the +1/-1 and paint them in to avoid pixel bruising.
ACR 4.1 has reduced my dependence on this by easily %50.
jasonhollister.com
Think your camera is noisy at high ISO? Click here
People will always try to stop you doing the right thing if it is unconventional
cosworth is offline   Reply With Quote
Old 10th of September 2007 (Mon)   #9
Stewx
Stewx's Avatar
1. Open Image
Mike
Ah, now that is smart... this works much better
Old 10th of September 2007 (Mon)   #10
lnterestlng
lnterestlng's Avatar
1. Open Image
Mike
If you want even more control you make 2 curves adjustment layers. One lighter and one darker. then mask em out and paint them in where you want. Same principle but just more control. You can go back and change the adjustment layers if you want to.
lnterestlng is offline   Reply With Quote
Old 10th of September 2007 (Mon)   #11
XTremeSLR
XTremeSLR's Avatar
+1 to what smdevo says. It's much better to do it this way.
XTremeSLR is offline   Reply With Quote
Old 10th of September 2007 (Mon)   #12
SeanH
One more-
Quick mask.......use whatever brush fits you image (area your working)....but always a soft edge
Brush the area you want to darken / lighten
Filter / Gass. blur.........change the radius till the red (quick mask) blend nicely and stays in the area you want.(you can erase some by clicking the black if you want.....again soft edge, and before next step)
Click out of quick mask
Select / inverse
new adjustment layer.........levels or curves, whatever you like.
make your adjustments and flatten.
This is the way I do 95% of my dodging & burning, not to mention all of my vignetting.
7D ......waiting on the 5D3
10-22, 17-40 4.0 L, 24-70 2.8L, 70-200 2.8L, 2 X 580EX's
SeanH is offline   Reply With Quote
Old 11th of September 2007 (Tue)   #13
ayotnoms
Perfect Anti-Cloning Argument
ayotnoms's Avatar
It seems to me that masking 2 adjustment layers is more labor intensive than one 50% grey Overlay layer and alternate between black and white brushes.
...but that's just me.
Steve
Gear
ayotnoms is offline   Reply With Quote
Old 11th of September 2007 (Tue)   #14
lnterestlng
The amount of control this gives you far outweighs the minimal effort of switching between layers(which is the same labor output as switching paint colors.) It's one click or key either way. I use a Wacom so it's a matter of tap here or tap there. I like the individual control of each layer's intensity after the fact for fine tuning. Also, I have the whole layer creation process set up as an action so I just press my F9 key and then start scribbling. As a heavy user, the little things like creating layers seem like normal breathing compared to the actual creative work that I need to spend mental energy on.
Most would be fine with the 50% grey route.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
dodge and burn azpix RAW, Post Processing and Printing 30 18th of September 2009 (Fri) 04:21
Dodge or burn? retro RAW, Post Processing and Printing 9 23rd of April 2007 (Mon) 13:26
dodge and burn murtaugh RAW, Post Processing and Printing 2 14th of November 2006 (Tue) 07:35
This is my first attempt at Dodge/Burn - Please comment Fizzbang Still Life, B/W & Experimental 3 26th of January 2006 (Thu) 15:38
PS Burn and Dodge xdiii RAW, Post Processing and Printing 4 15th of November 2003 (Sat) 14:03
