#1 |
I recently bought an Express Card Compact Flash Card adpater from eBay and it arrived today. I am very pleased with it. It was cheap, works perfectly and fits completely flush inside the laptop. When inserted, the CF card only protrudes a small amount. Here's the item I bought....
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=018 My CF cards are definitely not high speed but I got read throughput of between 7-8MBps and write speeds of ~3.5MBps. Here are some photos to show it in use. Last edited by tdodd : 11th of September 2007 (Tue) at 03:51. |
| sponsored links |
#2 |
Does it remain attached to the computer if you yoink the CF out, or does it come out with it? Had bought a PCMCIA adapter in the hopes that it'd stay put, but it didn't. It also sucked.
Canon: EOS 50D, EOS 400D, EF 300mm f/4L IS USM, EF 50mm f/1.8 II, EF-S 18-55mm f/3.5-5.6 II, EF 1.4X Extender, Speedlite 430EX Sigma: 10-20mm f/4-5.6, 55-200mm f/4-5.6 | Tamron: 17-50mm f/2.8 | Manfrotto: 055 XPROB tripod, 680B monopod, 804RC2 and 486RC2 heads Kenko extension tubes, Sandisk Extreme III 2GB + 8 GB & Ultra II 4GB |
#3 |
The laptop has a firm grip on the adapter and there is an eject button - you can just see it in the photo to the left of the card slot - that you need to push in order to eject the adapter. The card can be removed quite easily from the adapter simply by pulling gently, with a slight wiggle, to free it easily.
EDIT : without the wiggle it is possible for the adpapter to be pulled out with the card. This is hardly the end of the world and the "wiggle" technique does the trick for me. Last edited by tdodd : 17th of February 2008 (Sun) at 02:07. |
| sponsored links |
| Thread Tools | |
| Display Modes | |
| Compact flash from ebay | bobinatcat | Accessories & Storage | 3 | 1st of July 2007 (Sun) 10:52 |
| Express card/34 adapter for Compact Flash cards... do they exist yet? | Ferco | Accessories & Storage | 5 | 2nd of April 2007 (Mon) 13:27 |
| compact flash to sd adapter? | Ryanisme | Accessories & Storage | 6 | 8th of November 2006 (Wed) 22:07 |
| compact flash card adapter? | sGu | The POTN Lounge | 5 | 27th of May 2004 (Thu) 11:37 |
