Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > People
Reply
Thread Tools Display Modes
Old 18th of September 2007 (Tue)   #1
docfav
docfav's Avatar
Default My Peppa
Here's one of my youngest son. My other son calls him "Peppa". No PS yet.
C&C welcome.
ISO 800 (taken at sundown)
1/400
f/4
AV Mode
docfav is offline   Reply With Quote
Old 18th of September 2007 (Tue)   #2
queenbee288
queenbee288's Avatar
Default Re: My Peppa
What a cute little boy. I bet he has gorgous eyes. Your shot is a little underexposed and needs some processing. Using photoshop I did a curves adjustment, boosted saturation, cloned out the extra person in the background and cropped. I also sharpened it a little bit.
Char
www.lanephotography.smugmug.com
Canon 7D, Sigma 70-200, Tamron 28-75, Canon 100 2.8, 50 1.8,
queenbee288 is offline   Reply With Quote
Old 18th of September 2007 (Tue)   #3
docfav
docfav's Avatar
Thank you. That does look better. I'm still a PS n00b. Learning it slowly.
Old 18th of September 2007 (Tue)   #4
bobrock111565
bobrock111565's Avatar
I agree with QueenBee that he is a bit underexposed. But I would take a slightly opposite route...rather than "sharpen" the image after adjusting the tonal values and color, I would do some skin softening instead. I think it looks better on a young kid like this. Beautiful young boy.
Bob Rock
Canon5D w/grip; Canon Glass: 24-70 f/2.8L; 70-200 f/2.8L IS; 180 f/3.5L Macro; 1.4x II Extender & misc. extension tubes; 580exII Speedlites(2); Minolta 5600HS Flash(2); Sekonic L-758DR; Pocket Wizards(6); Dyna-Lites, Photoflex Starlites, softboxes, reflectors, umbrellas, stands, etc...; Gretag/X-Rite Profiling Equipt.
bobrock111565 is offline   Reply With Quote
Old 18th of September 2007 (Tue)   #5
Gamut
Gamut's Avatar
What are you guys doing to smooth the skin? Assuming you're in PS?
5D | 24-105L IS USM | 70-200L IS USM | 50mm 1.4 | 1.4x extender
Gamut is offline   Reply With Quote
Old 19th of September 2007 (Wed)   #6
bobrock111565
Everyone has a different technique, and all have their merits. In PS there are always dozens of ways of doing the same thing. I'll offer two suggestions:
1) The manual method and probably the most popularuplicate your image layer. Blur this duplicate layer using a surface blur or gaussian blur...amount depends on resolution of image. Just look at the skin. Blur it until it smoothes MORE than you want. Then click the "add layer mask" at the bottom of the layers pallet and fill with BLACK. Now there is no effect. Use a soft brush, at about 15% opacity and paint back in with WHITE on the layers mask on the skin areas only. If you overdo it, you can then lower the opacity of this layer to reveal a little of the sharper layer underneath.
2) Really fast and easy method, with very good results: "Portraiture" by Imagenomic. I use this on the default settings on a duplicate layer, and then just lower the opacity of the layer until I'm happy, and further add a layer mask if any non-skin areas got softened too. This program is killer! I can't live without it now. http://www.imagenomic.com/pt.aspx
Bob Rock
Old 19th of September 2007 (Wed)   #7
Gamut
Gamut's Avatar
Thank you Bob. I thought that might be what you were doing. I wasn't sure if there was some sort of after market filter or tool you might be using so I thought I'd ask.
Never heard of Portraiture. I'll check it out. Thanks again!
Old 19th of September 2007 (Wed)   #8
docfav
docfav's Avatar
Yes. Thank You. I'm going to have to try these myself.
Old 19th of September 2007 (Wed)   #9
bobrock111565
I cannot say enough about "Portraiture". I've recently been to a few seminars hosted by a few very famous photographers/PS experts...one by Scott Kelby and the other by Jack Reznicki. Although I was already using "Portraiture" at this time, they both recommended it very highly.
It does instantly what would normally take you several minutes or longer to accomplish. Great results, and like I said earlier, you can just use it on a duplicate layer and lower the opacity if you find the effects too much. But I love it.
Another two programs (PS Plugins) which I find extremely good for portraits are by "Image Trends, Inc.", called "Pearly Whites" and "Shine Off". The first one quickly whitens teeth and eyes, and the other takes the shine off of faces. I sometimes have to run "Pearly Whites" twice for some teeth, but then "Shine Off" usually works fine the first run through. Again you can always reduce the opacity of the duplicate layer after applying. All of these are GREAT time savers.
Bob
Bob Rock
Old 19th of September 2007 (Wed)   #10
docfav
docfav's Avatar
Thanks for the settings. I looked up portraiture. I think that might be a little more than I want to spend for playing around with the kids. I take the time and learn how to do it from your suggestions.
Thanks again.
Old 19th of September 2007 (Wed)   #11
neil85
nice photo ... i like bobrock's edit as when he cloned out the othe person its not as noticed.
the original one by queen you can see the box in which is was cloned.
i dont think its too far off as underexposed ...
brightness to me all depends on the photo, expose it a little to much and the skin tone doesnt match the natural tone the person really has
30D & 28-135 kit lens, 50mm F/1.8 MKII, monopod, tipod w/pan tilt head, 430EX w/ sto-fen omni bounce,
On the brown truck, due 10/26 ... 70-200 2.8L IS
neil85 is offline   Reply With Quote
Old 20th of September 2007 (Thu)   #12
bobrock111565
Yes...agree with Neil. The exposure is really highly "custom". I almost get tired sometimes of hearing comments like "a bit too underexposed...". Well yes, some images technically ARE underexposed. But as Neil says, other images might just look better that way. Not just the skintones, but for example I think if this image were exposed longer, the background highlights would become really blown out and perhaps become too distracting. Yes, a reflector or fill flash would have been welcome, but perhaps not available on this shot. Anyway, a slight underexposure in this case is totally fixable and in my opinion the boys face make it a "keeper".
Bob Rock
Old 20th of September 2007 (Thu)   #13
docfav
docfav's Avatar
Thanks everybody for all the critiques.
Doc
Old 21st of September 2007 (Fri)   #14
Moin
Moin's Avatar
Cute boy, nice Edit..Ty Bob for the Share (Imagenomic)
Moin is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
