#1 |
A real newb here,.............trying to get away from AUTO on my new Rebel XT.
One of the lenses I am using is a Canon 28-135 f/3.5-5.6 IS. If I want to use the Av mode setting (aperature priority), can I select a stop outside the range of 3.5-5.6? I really feel dumb and dumber here, but none of my books really explain those f/ markings on lenses. What do they mean exactly? Is there a "sweet spot" aperature on this and all other lenses? Somewhere in that range? Your help is gratefully received. Fr. Jeff |
| sponsored links |
#2 |
I feel thoroughly satisfied
Those markings you see are the widest f/stops you can set. At 28mm focal length you can set it between, say, 3.5 and f/22 (not sure about the top number, might be 32) and at 135mm you can set it between f/5.6 and f/22 (again, maybe f/32).
Edit: Oh, and the sweet stop is often a stop or two down from maximum aperture.. someone who's used that lens can comment on that though Last edited by Jim G : 20th of September 2007 (Thu) at 19:37. |
#3 | |
Adrift on a lonely vast sea
At 28mm, the largest you can open up to is f/3.5. At 135mm, the largest you can open up to is f/5.6. When set at the aperture priority you can select any aperture you desire BUT will not be able to go any larger that what you lens was designed for. As for the "sweet spot" I am not familiar with this lens.
Doug My Gear List http://www.flickr.com/photos/n8trshtr/ Entered: 2-16-84 Passed: 5-22-84 Raised: 6-19-84 |
| sponsored links |
#4 |
Usually lenses perform best when they are 1-2 stops down from their wide open position. So your lens is wide open at f/4 at 50mm. The lens will probably sharpen up a lot by f/5.6 and maybe a little more by f/8. I doubt f/11 would gain much and there is usually no light level where f/11 does not like a tripod in any case.
My personal stuff:http://www.flickr.com/photos/jngirbach/ Commercial sports:http://girbach.zenfolio.com/ I use a Canon 5D and 1DIV and a Panasonic GF-1 Gear List: http://photography-on-the.net/forum/...postcount=1550 |
#5 | |
Is there a graph/chart of some sort for each, or do I guess initially? Thanks to all for the great feedback. I feel a bit more equipped to make somewhat more intelligent settings! |
#6 |
Here is some info u might like in relation to your lens
http://www.photozone.de/8Reviews/len...6_is/index.htm
#7 |
teaching fish to ride a bicycle
Fr. Jeff....
Use this site to get the info you want. It comes in real handy for situations like yours. http://www.dofmaster.com/dofjs.html My wife and I still use our 28-135's for walk around lenses. A very much underappreciated piece of glass. Wide open and at the extreme ends, it may not be as sharp.
A 40D, a 30D, some nice glass and a great Shooting Partner. "...As in music, so in life." |
| Thread Tools | |
| Display Modes | |
| Candid Aperture Setting | MrsOpie | Weddings and Other Family Events | 10 | 17th of March 2007 (Sat) 20:01 |
| blinking aperture setting | coeng | Canon EOS Digital Cameras | 11 | 21st of August 2006 (Mon) 14:30 |
| Aperture setting | dreamer | General Photography Talk | 3 | 3rd of March 2004 (Wed) 05:32 |
| Av setting the Aperture - problem?? | Innfo | Canon G-series Digital Cameras | 4 | 30th of March 2003 (Sun) 08:09 |
| Setting the aperture on D60 | Sniper | Canon EOS Digital Cameras | 7 | 10th of November 2002 (Sun) 17:38 |
