Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 15th of July 2002 (Mon)   #1
pechluck
Default help me check the S40 battery life?
I'm a relatively new S40 owner- one of the frustrations is that I never know when the battery is going to die until well, the "out of juice" icon flashes and a little bit later, my camera dies. I do have another battery, fortunately, but is there a way for me to check the battery life before it dies?
On a related note, is there a way to turn off the LCD so I can save my battery when I'm taking photos outside and can't use it anyway?
THANKS SO MUCH!
P
pechluck is offline   Reply With Quote
Old 15th of July 2002 (Mon)   #2
Rustle
Default Re: help me check the S40 battery life?
The only cameras that give you constant power updates (that I know of) are Sony cameras with InfoLithium batteries. These cameras tell you how much power is left right to the minute. Canons don't have that ability, so you've got to go on gut feeling. It gets easier to predict over time.
I assume you're asking how to power up the camera with the LCD off. If you turn off the LCD, then turn off the camera, it will remember that setting when you power it up next time.
Rustle is offline   Reply With Quote
Old 15th of July 2002 (Mon)   #3
jim9tan
Hi,
I am a S40 owner. I have the same problem and am using a spare battery too.
You can turn off the LCD display at any time by pressing the display button until it switches off (Manual Page 30).
You don't need to turn the LCD on and off, in order to review your last shot. Enable the REVIEW function (2 or 12 seconds) in the menu. After you shoot, the LCD will turn on automatically and display the last shot from the buffer. Immediately press the SET button (Manual Page 46) to stay in review mode. You can perform any review function except access previous shots.
When you have finished, just half press the shutter. The camera turn soff the LCD and returns to shoot mode.
REgards,
jim9tan is offline   Reply With Quote
Old 19th of July 2002 (Fri)   #4
rcpage
Try buying the bigger capacity NB2-L battery from BatteryBarn.com that way you can use it first and then switch to the lower capacity one afterwards..
It is 700mah. That is 40% more juice than the standard 570mah battery. The cost is $40.95 incl shipping.
When you have a camera worth around $600 the last thing you need is to be unable to take photos because you skimped on a backup battery.
rcpage is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
New S40 battery dies after a day bongo Small Compact Digitals by Canon 2 4th of February 2003 (Tue) 09:13
Battery Charging Problem on S40 agabril Small Compact Digitals by Canon 0 12th of January 2003 (Sun) 20:40
S40 Battery problem templeman_mark Small Compact Digitals by Canon 0 23rd of December 2002 (Mon) 07:53
Battery lock in S40 9.81 Small Compact Digitals by Canon 5 23rd of August 2002 (Fri) 11:01
Battery catch on s30/s40 iandnor Small Compact Digitals by Canon 4 20th of June 2002 (Thu) 20:59
