Reply
Thread Tools Display Modes
Old 27th of July 2004 (Tue)   #1
mike115
Default hello - new to the hobby and got a new g5 and ....
i dont think ive got the hang of it yet. everything i shoot indoors has either a greenish or amber hue to it which makes the pics look very unnatural. ive read the manual and i think i know what the different buttons do but thats not quite helping. outdoor pics are better in comparison to indoor pics. i also noticed quite a bit of jagged edges in some of the indoor pics where the setting comprised of a bookshelf with books and compact discs- is there any way to eradicate this? and what would be recommended reading on this - preferably web based - oh btw before the g5 i knew and i still know nothing of cameras - im an absolute novice at this so please break it down simply
cheers
mike115 is offline   Reply With Quote
Old 27th of July 2004 (Tue)   #2
rraman
rraman's Avatar
Default
Are you using wrong white balance setting by any chance?
Raman
5D Mark II | 40D | Canon 17-40mm f/4 L| Canon 50 mm f/1.8 | Canon 100mm macro f/2.8
www.theZenArt.com
rraman is offline   Reply With Quote
Old 27th of July 2004 (Tue)   #3
mike115
Default
hi raman, thanks for the reply - its usually on auto white balance as i found that the other settings gave a much stronger amber hue and custom set - using a white card - usually resulted in a bluish tinged pic.
Old 27th of July 2004 (Tue)   #4
twl845
twl845's Avatar
Default
Look at the page in your manual for setting white balance. set the appropriate icon on the lcd screen. example: set the little sun icon on a sunny day outside. Your pictures should be OK.
Canon G3, Kodak DC4800, Elements3
twl845 is offline   Reply With Quote
Old 27th of July 2004 (Tue)   #5
John_T
John_T's Avatar
Default
The greenish/amber hue would likely be due to mixed ambient lighting, and since it is mixed it is difficult to find a WB setting that will cover the range. Do you get the same cast on screen and on print, or is there a difference?
If you were to use an external flash, such as the 420EX and a Stofen Omni-bounce on it, or pointing the flash more toward the ceiling it would help neutralize the mixed lighting.
Otherwise you will need to play with it in post processing.
Canon : 5DIII : 7D : 40 2.8 : 50 1.4 : 35L : 85L : 100L IS Macro : 135L : 16-35L II : 24-105L IS : 70-200L II : 100-400L IS : 1.4x & 2x TC II : 580EX : 430EX : Markins Q10 & Q3T : Jobu Gimbal : Manfrotto Underware : etc...
John_T is offline   Reply With Quote
Old 27th of July 2004 (Tue)   #6
ScottK
Default
I agree, mixed lighting is probably the issue. Are these pictures taken with the flash? If so, have you tried the flash white balance setting? I've found it works reasonably well with the internal flash.
As for the jagged lines, it might depend on how you're viewing it. I have noticed that edges like you described do tend to be much sharper on indoor flash shots. If you view the picture so that it fits on your screen (whether on the computer or the camera), it has to be resized, since your screen isn't big enough to display all the pixels in the picture. If that resizing isn't done well (depending on what program you're using to view the picture), it might not smooth those lines as well as it could. First, you could zoom into a full sized view, and see if its still jagged. Or, like with the colors, get it printed and look at the results there. In most cases, you should see the lines come out smoother. If you want to resize your pictures for displaying on screen or on a web page, let me know and I'll give you a trick for resizing that helps eliminate the problem.
ScottK is offline   Reply With Quote
Old 28th of July 2004 (Wed)   #7
4walls
4walls's Avatar
Default Re: hello - new to the hobby and got a new g5 and ....
cheers
Post some examples?
4walls is offline   Reply With Quote
Old 29th of July 2004 (Thu)   #8
IainB
IainB's Avatar
Default
Regarding jagged edges, check what resolution the camera is set to. If you are taking jpegs in auto mode, a low resolution setting will naturally produce low quality. Try superfine, or better still, shoot in Raw.
_______________________________________________
IainB
"Chi non ha moglie non ha padrone."
IainB is offline   Reply With Quote
Old 29th of July 2004 (Thu)   #9
mike115
Default
hi - thanks for all the replies - i have had to be away from the pc for the last couple of days but i will reply in detail over the weekend and post some sample pics if possible.
cheers
Old 3rd of August 2004 (Tue)   #10
mike115
Default
hi, the pics have been finally uploaded and here they are with brief commentary.
http://photobucket.com/albums/v324/m...rent=room2.jpg
view of my room - this is the kind of look i have been getting on auto white balance - the main light is a ceiling fluorescent which is warm white. you can also see the jagged effect on the cd collection on the left of the pic and on the blinds which curiously also has a curved thingy which appeared on the lcd screen as pink/reddish rays.
another problem with this pic is what you see at the corners- i dont know what this effect is called - im so new to the terminology - i used a raynox 6600 wide angle lens taking this pic and had a hoya 72mm uv guard filter on the raynox. and this is the result of that- wtihout the uv filter, i dont get the darkened corners. is there a way to counter this?
http://photobucket.com/albums/v324/m...rent=room1.jpg
same room but with tungsten setting - this time you will see a what looks like a halo at the ceiling - which goes away when the uv filter is removed.
http://photobucket.com/albums/v324/m...nt=windows.jpg
http://photobucket.com/albums/v324/m...=picframes.jpg
more jaggies- with the buildings, at the louvres and with the framed pics, at the frames. note the colour of the pic with the frames - on awb setting.
http://photobucket.com/albums/v324/m...orejaggies.jpg
this was taken with a flash and i was quite shocked at the result.
http://photobucket.com/albums/v324/m...ent=jagged.jpg
more jaggies
http://photobucket.com/albums/v324/m...rent=bench.jpg
look at the pathway
http://photobucket.com/albums/v324/m...ent=cdrack.jpg
look at the window blinds for jaggies.
sorry for the long post. what you see in the pics above have been driving me nuts really and any help or insight given as to how i can overcome them would be really really appreciated.
thanks very much
m
Old 3rd of August 2004 (Tue)   #11
Belmondo
Admin
Belmondo's Avatar
Default
Mike:
I tried opening the images, but I'm getting a message that says they're password protected.
I'm not short. I'm concentrated awesome!
Belmondo is offline   Reply With Quote
Old 3rd of August 2004 (Tue)   #12
mike115
Default
hi belomondo, sorry for that - it should work now. most of the pics were taken on av mode - superfine resolution except for the pic of my pc table which i think was taken on auto mode with flash. save for this pic, no flash was used.
cheers
m
Old 4th of August 2004 (Wed)   #13
Andy_T
Default
Mikey,
how did you resize the pictures for the web?
To me, the jagged lines look some very bad resizing algorithm.
The picture with the windows looks like it was best viewed with some red/green 3d glasses
Could you post the picture with the windows or the one with the park bench in its original size (2.500x2000 pixels) or something like that?
Let me tell you what I'd try if I were you:
- Shoot one of these pictures in RAW mode
- Convert the RAW image to TIFF in Canon ZoomBrowser
- Open the TIFF image in Photoshop LE (great program, should be included in your G5 box)
- Resize the picture in PS LE to the size you usually use for the web (1200*800 or the like)
- Apply the 'unsharp mask' or 'sharpen' filter
- Save the image as JPG file, quality=10
This should give you a significant improve in quality.
I include a link to one of the pictures of my son (from the G2) that was treated like that. Apart from a little motion blur, it does not exhibit problems like the jagged lines your photos seem to suffer from:
http://www.photo.net/photodb/photo?p...71&size=lg
Best regards,
Andy
Andy_T is offline   Reply With Quote
Old 4th of August 2004 (Wed)   #14
mike115
Default
hi andy, thanks for the suggestions - that is a very clean and sharp pic - i can imagine a lot of jaggies if i had taken the shot. i will work on your instructions and report back.
on resizing - i didnt change any parameters at the time i downloaded the pics thru zoombrowser. could resizing have taken place nonetheless? sorry if this is a strange question - all this is still very new to me.
thanks again
mike
Old 4th of August 2004 (Wed)   #15
Andy_T
Default
Hi Mike,
Zoombrowser should not resize the pics when downloading, but load them in the size they were taken (RAW/large/medium/...)
Do your pics look the same on your PC (using ZoomBrowser)?
Have you tried to open them in Photoshop?
If they look different on your PC, then maybe the site you posted them to does reduce the size of the images... maybe you should try a different one. Photo.net is not bad.
Your G5 should have the following resolutions:
2592 x 1944
1600 x 1200
1024 x 768
640 x 480
Check your display, if you have selected 'L':
(Display from DPReview G5 review): http://www.dpreview.com/reviews/canong5/
If you shoot 'large JPG' or RAW, then the resolution of the picture will be 2592 pixels by 1944 pixels.
The picture you posted has a resolution of 819x614 pixels ... that's only 0.5 Megapixels or about 10% of the information of the original image
This is an example of a picture with 4 Megpixels from the G2: http://www.photo.net/photodb/photo?p...80&size=lg
If you click on the 'smaller' button, you'll see a photo that was resized not in PS, but by the website's algorithm ... not the optimal result.
Best regards,
Andy
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
My other hobby Grace People 56 6th of October 2007 (Sat) 19:34
My other hobby Addicted Transportation 9 8th of February 2007 (Thu) 14:27
I have a hobby... Flame Birds 1 26th of January 2007 (Fri) 06:43
my new hobby... windoze Birds 19 16th of July 2006 (Sun) 21:29
Need a Hobby-Is the Way to Go? Bmosbacker Canon EOS Digital Cameras 51 24th of April 2006 (Mon) 05:01
