Reply
Thread Tools Display Modes
Old 1st of October 2007 (Mon)   #1
alinsyed
Default Good wildlife lens
Hi,
I'm going on a safari soon and am looking for a good telephoto lens. Currently have a Sigma 28-200 but not that happy with its performance and also need at least 300mm. Any suggestions welcome; prefer not to spend too much so L lenses probably out for the moment.
Thanks,
Canon 400D, 18-55 Kit Lens, 24-105L 4.0, 50 1.8, Sigma 28-200
alinsyed is offline   Reply With Quote
Old 1st of October 2007 (Mon)   #2
KTA
Default Re: Good wildlife lens
I see you're in a low budget, I would recomend you a sigma or canon 70-300 or 75-300 and even consider a kenko 1,4x if compatible with the lens. Hope you have a good safari and show us some pics of your trip
David "KTA" Catta
Canon EOS 1DmkIIn
KTA is offline   Reply With Quote
Old 1st of October 2007 (Mon)   #3
mcmadkat
mcmadkat's Avatar
Probably about the cheapest option is the Sigma 75-300mm APO
Although I would recommend the Canon 300mm f4
30D 17-40L 580EXII
mcmadkat is offline   Reply With Quote
Old 1st of October 2007 (Mon)   #4
LightRules
"flat out embarrassing"
LightRules's Avatar
Cheapest: Sigma 70-300 "APO" DG Macro
Upper-Middle: Tamron 200-500 SP or Sigma 50-500 EX
High: Canon 100-400 IS
LightRules is offline   Reply With Quote
Old 1st of October 2007 (Mon)   #5
sebr
sebr's Avatar
I was in Kruger National Park (South Africa) last month and was using the 70-300 IS. Depending on how much is not too much, this may be your best alternative.
Sebastien
5D mkIII ; 17-40L ; 24-105L ; 70-200L II ; 70-300L ; 35L ; Σ85/1.4 ; 135L ; 100macro ; Kenko 1.4x ; 2x mkIII ; 580EXII
Benron Tripod; ThinkTank, Lowepro and Crumpler bags; Fjällräven backpack
Complete Gear List
sebr is offline   Reply With Quote
Old 1st of October 2007 (Mon)   #6
mpoole
Buy a used 100-400 and sell it when you get back.
mpoole is offline   Reply With Quote
Old 1st of October 2007 (Mon)   #7
alinsyed
Thanks all, leaning towards the 70-300 IS also after reading through other posts.
mpoole, based in Dubai now so used glass not really an option.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Lens for wildlife??? What's good? deepsouth Canon EF and EF-S Lenses 5 18th of November 2006 (Sat) 11:29
Good wildlife companion for the 300 2.8 paulhillion Canon EF and EF-S Lenses 20 10th of November 2006 (Fri) 14:29
Good lens for wildlife photos hef Canon EF and EF-S Lenses 16 26th of November 2005 (Sat) 20:44
Good wildlife lens - 100-400 & 1.4x TC? morehtml Canon EF and EF-S Lenses 31 19th of September 2005 (Mon) 11:22
Good Zoom Telephoto lens for Wildlife photography birch Canon EF and EF-S Lenses 8 19th of April 2005 (Tue) 20:52
