Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 10th of October 2007 (Wed)   #1
canon shooter
canon shooter's Avatar
Default selective color in CS3
Probably not a good description of what I want to do.
But with that said what is the easiest way in CS3 after converting to B&W to put the original color back in one item. For ex. wedding pictures of bride and glroom where they are converted to B&W but her flowers are the original color.
Jim
5D Mark III Grip, 40D Grip, 20D, Canon 17-40L, Canon 24-105 F4L IS, Canon 70-200 IS II F2.8L, Canon 100-400L, Canon 50 F1.4, Canon 100 F2.8, Canon 580 EX
It's the Glass that Counts! Visit http://www.genphotosaz.com
canon shooter is offline   Reply With Quote
Old 10th of October 2007 (Wed)   #2
NOsquid
NOsquid's Avatar
Default Re: selective color in CS3
Duplicate layer, desaturate, edit as mask, paint over flowers with black brush. Go over mistakes with white brush.
NOsquid is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #3
tim
Light Bringer
tim's Avatar
Alternate way is to select part you want in color using selection tool/magnetic lasso then copy that out to a new layer, then use a channel mixer layer to make the background B&W. I could probably come up with a half dozen different ways but either of the two here will work.
tim is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #4
csm328
csm328's Avatar
Quickest way is: desaturate (new layer if you want), history brush over the area you want the colour and, voila! you're done.
Wayne
Canon EOS 60D, Grip, 70-200L, EF-S 10-22, ,EF 28-135mm, EF 50mm f/1.4 USM, Speedlite 430EX, G-10, 24 GIG of Various CF Cards
csm328 is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #5
S.E.V.
/Include subdirectories, empty directories, and verify.
S.E.V.'s Avatar
I goolged selective coloring and got this as the first link Selective Coloring
Did it in CS2 and worked for me.
Here are some practice images i did.
ShotsInTime / Gear List /Flickr / Canon Family Portrait
- Don't Argue With A Stupid Person, They Will Bring You Down To Their Level And Beat You With Experience.
S.E.V. is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #6
saturnin
saturnin's Avatar
top layer color
bottom layer bw
and erase lol @ least thats how i do it... really is no wrong way..all the suggestions are great
http://www.saturninfloyd.tumblr.com samples
http://www.asphaltjunkiez.com - award winning filmmaker - 3 documentaries done, more to go. I'm not wasting this 1 life.
Gear is gear, gotta do wif what you got! This forum makes me bite my tongue like no other forum i've ever been on
saturnin is online now   Reply With Quote
Old 12th of October 2007 (Fri)   #7
multiple*choices
multiple*choices's Avatar
All of these are sensible ways. You want to make sure those that when you work on your photo, you do it non destructively. So the best way in my opinion is masking (versus history brush or erasing). Also, you want to start with a rich black and white.
If you click on the link in my signature, you will see samples of selective coloring using my action set "color magic" and "coloring book."
Hope that helps.
Jodi
MCP
multiple*choices is offline   Reply With Quote
Old 12th of October 2007 (Fri)   #8
pixelprincess
pixelprincess's Avatar
Hope that helps.
Jodi
This is how I do it too. Ditto on the rich black and white- simple desaturation is for snapshooter . Try blending a couple of b/w gradient map layers/ masks for that.
pixelprincess is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
First selective color Steezy303 People 3 29th of April 2007 (Sun) 15:34
Full Color or selective color? silvrr Still Life, B/W & Experimental 15 13th of February 2007 (Tue) 21:40
Interesting CS3 selective color shortcut tim Weddings and Other Family Events 5 28th of January 2007 (Sun) 15:27
selective color brantfordbandit Still Life, B/W & Experimental 2 3rd of December 2006 (Sun) 14:11
