Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 10th of October 2007 (Wed)   #1
j_richard3
j_richard3's Avatar
Default Anybody use continuous lights (hot lights)?
Hello,
I need help in deciding about studio lighting, I keep going back and forth with the whole stobe light v/s hot light. I know most people on here say strobes are best but I was just wondering if anyone out there uses hot lights and if so ...do you like them and what kind are they. I'm trying to keep cost down but still get something that will do a good job.( I will be using them for portraits mostly.)
j_richard3 is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #2
MikeMcL
MikeMcL's Avatar
Default Re: Anybody use continuous lights (hot lights)?
Dont do it man!
I moved along the same path, and the hot lights are a real headache. If you want to get some nice prices on them, try amvona.com
For a long time, I had both. The hot lights just DO NOT put out enough light for normal portraits. you will find yourself looking for a F1.8 lens, and shooting at ISO 800 or higher in many situations. you will also realize that you cant shoot a family of 5 with a F/1.8 setting and get sufficient DOF. you will have people squinting from the intense constant light instead of blinking once per shot... Not to mention the heat issue, which i will not harp on.
I forget the calculation, but a studio strobe puts out many times the light of a hot light - something like 45 times the light or something like that.
Learn from others' mistakes and get yourself a single, nice quality strobe and an umbrella. you can learn through reflectors, lighting and manual exposures... the rest will fall into place.
Best of luck, PM me if you have any specific questions.
350d, 5d, 17-40L, 28-70L, 135L, 70-200L, 430EX,
Sigma 150mm macro - full alienbees studio set.
MikeMcL is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #3
kevie
Yeah ive used hot lights......link
didnt really get the results i was looking for. And the room was really hot.
30D - 70-200mm f4 L + 17-40mm f4 L + 50mm f1.8 + 2x Sigma 530 super + Kata R-103
www.viraltheshow.com
flickr
kevie is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #4
Curtis N
Master Flasher
Curtis N's Avatar
I used hotlights once.
Keyword: Once.
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #5
s8langwo
s8langwo's Avatar
I don't know how to link to a prior post of mine, but I posted a meager attempt at tungsten lighting in the people section displaying a shot of a friend I made using 4 60W bulbs. I shot the image with the 135mm 2.8 SF lens set on a SF setting of 1 (I think). I'd show you but I understand it is poor form to repost an image I already used another thread.
Regardless of whether you like soft focus or not, you can start to get an idea of what inexpensive tungsten can do. I love playing with it.
My inspiration came from a post to a thread that sfaust made a while back. The thread was of the usual vein that discouraged tungsten light usage until he posted. His use of tungsten lighting on several models impressed me greatly. Unfortunately, I can't find that posting either but I'm thinking it was late 2006. I'm sure someone with more saavy could find it or ask him to post it again.
Believe me when I say this, your efforts to find his examples of tungsten light images will be worth the time and energy.
Take time to play with tungsten. It inexpensive and can produce some neat results.
Kevin
2x40D, 28mm 1.8, 85mm 1.8, 70-200mm 4.0 (non-IS), 17-40mm 4.0, 430 EX (2X), ST-E2, and assorted useful accessories. (Some not so useful too!)
s8langwo is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #6
Titus213
Titus213's Avatar
Here's one of his images - very impressive...
http://photography-on-the.net/forum/...d.php?t=256743
I've used hotlights - with color corrected photolights. They get hot enough to melt aluminum. Sure, it's WYSIWYG, but it is hot enough to cause serious damage, it's not that bright, and power adjustments were problematic - you moved the light. Of course I'm sure even hot lights have advanced in the time since Edison first developed them.
Dave
Perspiring photographer.
Titus213 is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #7
PhotosGuy
Moderator
PhotosGuy's Avatar
I'd use strobes for portraits, especially if that's all you use them for.
I prefer quartz, Colortran 650s, for product though.
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 11th of October 2007 (Thu)   #8
Curtis N
Master Flasher
Curtis N's Avatar
Electronic flash is a relatively modern invention. Certainly millions of portraits have been made with hot lights. There's one of my wife's grandfather hanging in our dining room. Flawless, as far as I can tell.
But from a technical standpoint, I don't think there's anything you can do with hot lights that you can't do with a strobe. With the right gel you can get the same color, the same properties in all respects. The only difference is the light is delivered in a very quick burst rather than spread throughout the exposure.
The incredible brevity of electronic flash also gives you the option of using shutter speed to balance the ambient - an option you don't have with hot lights.
Old 11th of October 2007 (Thu)   #9
awad
awad's Avatar
heres the thing.
i honestly dont think that these two are interchangeable, they both provide VERY different light for different feels. I use both strobes and hot lights, i prefer strobes but they lend themselves better to my work. if you're looking to do traditional straight forward portraiture, then your life will be much better if you invest in a set of strobes, if you're going to experiment a bit, you might get more use out of hot lights.
or, you can get both.
awad is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Is this brolly ok with continuous lights? echo Small Flash and Studio Lighting 0 12th of August 2007 (Sun) 17:59
Hot lights SeanH Small Flash and Studio Lighting 0 10th of November 2006 (Fri) 18:14
hot lights VS. Strobes MikeMcL Small Flash and Studio Lighting 2 31st of July 2006 (Mon) 03:02
Hot lights and guerilla techniques? Myke Canon EOS Digital Cameras 2 19th of January 2005 (Wed) 08:26
New gallery of performers on stage under hot lights maderito Presentation 1 25th of February 2004 (Wed) 12:57
