Thread started 17 Oct 2007 (Wednesday) 19:08
Prev/next
INK JET OR SUB DYE PRINTER
AnthonyD
Indian Trail , North Carolina
Oct 17, 2007 19:08 |  #1
Hi First off if I am posting this in the wrong place please excuse me. My question is I am just getting into photgraphy . I have an EOS 30D . I am looking for a printer . I remember reading that sub dye printers are best is this true and does Canon have a printer that will result in prints that look like and last as long as those of a sub dye ? Thank you in advance Anthony
Canon EOS 30D, 28-135 IS , Canon G3
R ­ Hardman
R Hardman's Avatar
29 Palms, Ca.
Oct 17, 2007 20:41 |  #2
Dye sub seems to have limited amount of media you can run through a specific brand/model where ink jets have a wider selection of media. Dye used to be what you printed if you wanted archival prints lasting decades but ink technology really has closed the gap on this. Canon used to sell dye sub but I have not seen any advertisements in over a year. I'm sure there will be more posts on this subject from more experianced printers then me. Welcome to the forums and photography!
"Whatever you can do to avoid Photoshop is worth it"
EOS 7D, EOS 350D, EF 17-40mm f/4L USM, EF 70-200mm f/4L USM, EF-S 18-55mm f/3.5-5.6 USM (Kit)
Rick's Digital Desertexternal link
MikeMcL
MikeMcL's Avatar
Dayton Ohio
Oct 18, 2007 01:53 |  #3
Look here http://www.imagingspec​trum.com/home.phpexternal link
These guys sell dye subs and all the supplies.
Dye subs can print VERY nice 4x6, 5x7 etc in like 8-10 seconds. Dye subs use print packs of specific paper and a ribbon at the same rate so buying and replacing the items can be predicted to a very close "price per" margin.
Dye sublimation is what most of the mall booths, event photographers and such use, because you get prints like instantly, and they arent wet.
They are awesome, but it really depends on purpose. it is true that a high end inkjet can give you a better print than a regular quality dye sub, but sometimes speed matters more than the finest quality.
350d, 5d, 28-70L, 70-200L, 430EX,
50 1.8, 85 1.8 - full alienbees studio set.
MikeMcLane.comexternal link
Jon, ­ The ­ Elder
teaching fish to ride a bicycle
Jon, The Elder's Avatar
Joined Oct 2004
Warren, Michigan
Oct 18, 2007 04:31 as a reply to MikeMcL's post |  #4
Anthony.....I have been using Dye Sublimation printers for the last 5 years or so. I use Hi-Touch technologies (http://www.hitouchimag​ing.com/external link).
Primary advantages have been mentioned previously. Remember that Dye Sub (not Sub Dye) printing is continous tone so there is no 'dots-per-inch' comparison.
I have run thousands of prints through both of my units with out problems.
A 40D, a 30D, some nice glass and a great Shooting Partner.
"...As in music, so in life."
SkipD
SkipD's Avatar
Joined Dec 2002
Southeastern WI, USA
Oct 18, 2007 06:59 |  #5
Jon, The Elder wrote in post #4145693external link
Anthony.....I have been using Dye Sublimation printers for the last 5 years or so. I use Hi-Touch technologies (http://www.hitouchimag​ing.com/).external link
Jon - which of their printers do you use? I've been casually looking for a dye sub printer that can do 8x10 prints that I would sell on the job site. The two that were around a couple of years ago (Kodak 8500 and Olympus P400) don't seem to be on the market lately.
Skip Douglas
AnthonyD
Oct 18, 2007 09:23 |  #6
Thank you all for your help and advice, it is much appreciated ! Regards Anthony
Wilt
Wilt's Avatar
Belmont, CA
Oct 18, 2007 14:04 |  #7
Beware that dye sublimation technology can have the 'fatal' flaw that stored improperly, they images can fade quite fast! Put a dye sub print in a PVC clear 'protector' (which also causes photocopies to stick to the protector) and your prints will fade and discolor. This is based upon having had a close relationship with more than one dye sublimation vendor for healthcare purposes and learning of the limiations/cautions.
Furthermore, dye sub uses a 'color print ribbon' for transfer of the color to dye sub media. The 'ribbon' for one photo is typically 3 sections of color (cyan, yellow, magenta) and black. If you print a photo that is dominantly a single color, the other two color sections are effectively wasted.
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.p​hp
SkipD
SkipD's Avatar
Joined Dec 2002
Oct 18, 2007 14:11 |  #8
Wilt wrote in post #4148430external link
Wilt, I fully understand the media issue you mention. There is, obviously, a fixed cost per print.
The one question that I have never gotten a reliable answer to is how one can expect the prints to last in a normal environment. Consider the home, some sunlight, putting the prints behind glass in a frame, etc.
Skip Douglas
Jon, ­ The ­ Elder
Joined Oct 2004
Warren, Michigan
Oct 18, 2007 14:54 as a reply to SkipD's post |  #9
Skip....I still haven't found a good 8x10 Dye Sub unit as yet.
I use a 730PS and a 640PS Hi-Touch for the other sizes.
Fortunately, I live near a very good Costco, which works out for my larger prints.
As for longevity of prints, I can only vouch for 5 years so far on the Dye Sub. As I am approaching 69 years on the planet, I'm not as concerned about prints as I am about digital files.
Wilt
Wilt's Avatar
Belmont, CA
Oct 18, 2007 17:10 |  #10
SkipD wrote in post #4148459external link
Skip, back in the 80's when I was involved with dye sub prints for medical care industry, I hung some Sony dye sub prints on my office wall for longevity testing. They had noticeably faded within a year or two or three (foggy memory, too long ago). Those that were stored in the dark (drawer) looked fine in that same time. I also had put some in PVC sleeves, and those noticeably deteriorated, too!
CyberDyneSystems
Admin (type T-2000)
CyberDyneSystems's Avatar
Gallery: 78 photos
Joined Apr 2003
Rhode Island USA
Oct 18, 2007 17:32 |  #11
Dye sub no longer equals the print quality of the best inkjets IMHO (when I say best I mean pricey too) , and of course they have far less flexibility in papers etc.
They do have some strong pluses though, but for most people getting into photography, a good solid mid range inkjet would be a better choice, particularly if you have ideas of printing your own framed art.
CDS' HOT LINKS
Wilt
Wilt's Avatar
Belmont, CA
Oct 18, 2007 17:47 |  #12
My pet peeve about inkjet is that large black areas 'float' on the surface of the paper for pigment-based prints!
Send them out for good conventional prints on Fuji Crystal...60 year longevity
SkipD
SkipD's Avatar
Joined Dec 2002
Oct 18, 2007 19:00 |  #13
Wilt wrote in post #4149701external link
I tend to agree with the conventional printing for long-term quality if the dye-sub prints don't do any better than y'all are reporting.
Unfortunately, a plan I have been trying to formulate for some part-time income is shooting large groups (class reunions, etc.) and making prints right there to sell. If I can't produce a worthwhile (as in something that will last) print, that sorta blows that part of my idea up.
Maybe in five years or so when I plan to retire there may be a better printing technology that can be portable. Of course, if I could take a Fuji machine to the job site, it would be really easy :p.
Skip Douglas
Wilt
Wilt's Avatar
Belmont, CA
Oct 18, 2007 20:35 |  #14
SkipD wrote in post #4150184external link
Skip, does the phrase "Take the money and run" sound familiar? ;):rolleyes:
Knowing what I know about dye sub, unless they really improved the technology in the past 10 years, I wouldn't bother buying a printer, much less sell the prints!
Wilt
Wilt's Avatar
Belmont, CA
Oct 18, 2007 21:09 |  #15
Well, it does not appear that dye sub has improved all that much. In this test, it is worse than even the worst of the injets for resistance to fade...
http://pixinfo.com ...ade-resistance-test-2007/external link
2,385 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00359 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is mwas
844 guests, 357 members online
