Reply
Thread Tools Display Modes
Old 7th of June 2001 (Thu)   #1
Richard Wolfson
Default G1 neck strap
I love my G1 -- but not the cheesy neck strap that dangles the camera from just one side. Has anyone found a way to install a second eyelet and a proper SLR neckstrap that holds both sides of the camera? Or some other solution?
Canon's one-eyelet-only G1 strap lets the camera swing around when I walk. I find it too short for picture taking if I leave it on my neck -- especially when composing in the LCD display instead of the optical viewfinder -- but too long to use as a wrist strap.
Richard Wolfson [rwolfson at LyricDesign.com]
Richard Wolfson is offline   Reply With Quote
Old 4th of July 2001 (Wed)   #2
sparkyrwb
Default Re: G1 neck strap
A Canon PSC-1000 form fit G1 camera case is a good solution. Not only will it protect your camera, but allows you to attach a real strap with two attachment points. I am using my old 35MM SLR strap. I purchased my case at eppersonphoto.com. BTW, it will not accept the camera with adapters on (slight drawback) and fully close the case.
sparkyrwb is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How do you attach neck strap with a hand strap? Jakpro Accessories & Storage 19 1st of June 2012 (Fri) 02:40
Horizontal Carry Neck strap and hand strap simwells Small Flash and Studio Lighting 1 27th of April 2007 (Fri) 17:16
Put your neck strap around your neck. Even when sitting Transportithere General Photography Talk 35 12th of March 2006 (Sun) 08:20
Hand strap and neck strap for 20D? ghaleon109 Canon EOS Digital Cameras 11 20th of November 2005 (Sun) 19:47
BigEd Users, Hand strap or neck strap? kafene Canon EOS Digital Cameras 25 16th of January 2004 (Fri) 21:12
