| sponsored links |
Thread Tools | Display Modes |
#1 |
Hi, I'm just starting into flash and using manual mode. I've come aross some amazing images here and on some other sites that have these amazing saturated skys and use flash outdoors. I read on another site that you use the flash off camera and meter the sky. I'm stil confused. Can anyone expalin it to be in "stupid" terms for someone that is new to this? I have a 430ex and 580ex but no way to get them both off camera. Please help
5Dx2, 580ex, Tamron 28-75, Canon 50 1.4, Canon 100 2.8 macro, Canon 135L, My Blog |
| sponsored links |
#2 |
You can do it with the flash on camera. You have to set the flash for hi-speed sync and then point the camera at the sky and get a meter reading. You can then either lock the exposure and recompose or you can set the camera to manual and set the settings that you got when you metered for the sky. Recompose on the subject and take the picture. It will expose the sky properly and the flash will fill in your subject making them expose properly. I hope that is clear enough.
#3 | |
Master Flasher
There are several ways to do it but here is the easiest: With the camera in manual mode, set your ISO at 100, shutter speed at 1/250 (1/200 for the Rebel models). Aim at the sky and adjust the aperture until the needle in the viewfinder is centered. This will give you a deep blue sky. With the flash in E-TTL mode, set your FEC at 0 and shoot.
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
| sponsored links |
#4 |
Great! Thanks so much Curtis! Just what I needed, quick and relatively easy. Will have to try it tomorrow.
#5 |
Curtis, I didnt even think about doing it that way. With the flash models he posted made me think of the hi-speed sync. Great advice. I guess at this point it is about how much DOF you want sweetypie.
#6 |
That is how I do it. But I usually FEC -1. See below!
Gear MP Image Studio "When I hit the gas, I want the whole world to think it is comming to an end." - Homer Simpson Last edited by ItsMike : 1st of May 2008 (Thu) at 03:09. |
#7 | |
#8 |
Master Flasher
And if blue sky is what you're going for, a polarizer works great, too!
#9 | |
Scott Vista owner...and user _________________________________________Gear www.scottcphotography.com |
#10 | |
Master Flasher
190/16=11.9 At f/22 the distance drops to about 8 1/2 feet. 190/22=8.6 Using high speed sync will cut those distances in half.
#11 |
Reading from the Northern sky is usually as good as reading a gray card, the Southern sky is about one stop brighter.
#12 |
Branching off from the OP's question.
What if you had an off camera flash that does not support E-TTL? Set it to Auto mode? Or this is when a lightmeter comes in?
http://blog.edwardhor.com http://www.flickr.com/photos/edwardhor/ http://www.modelmayhem.com/EdwardHor http://www.twitter.com/edwardhor justAL: PIxel peeping is what separates the men from the boys! |
#13 | |
Master Flasher
Old fashioned auto flashes can be used off-camera, outdoors, but it's tricky. The flash unit's sensor needs to be carefully aimed at the subject or something else at a similar distance that will bounce the light back. If the sensor is pointing at a distant background, overexposure will result.
#14 | |
Time to save up for a Sekonic or similar ![]()
#15 |
I just set max flash sync speed and ISO 100, set up my light, and chimp out an aperture value. If I want the flash to be brighter or darker, I'll usually do it by moving it back and forth, as I tend to default to around 1/2 power, and I hate going all the way up to full (wayyy too long recycles). Once I have proper exposure, preferably with the sky underexposed a little at this point, I just set my shutter speed wherever I want it to get the desired effect; I may just properly expose it, maybe blow the background out a little, but my favorite tends to be slightly underexposing, especially when you have nice cloud formations and you want to preserve saturation. Here's a couple examples: the first one took me maybe five minutes to make, and the second was more like 15, but I was in the shot, which made it more difficult. Both were made with just one flash and no light meter.
EOS 20D w/ BG-E2 grip Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM Speedlights SB-25/SB-26/580EX, Pocket Wizards and such My Gallery |
| Thread Tools | |
| Display Modes | |
| Over exposed SKY | RacEcaR | People | 29 | 5th of October 2007 (Fri) 17:40 |
| Blown out dress, properly exposed Background... | italianfemmy | Weddings and Other Family Events | 58 | 26th of July 2007 (Thu) 20:36 |
| changing the color of an over exposed sky... | flipteg | RAW, Post Processing and Printing | 3 | 25th of June 2007 (Mon) 06:51 |
| Under exposed flash Why? | guzzibob | Critique Corner | 14 | 6th of July 2006 (Thu) 22:18 |
| One day she will be properly exposed | incendy | People | 23 | 4th of February 2006 (Sat) 03:03 |
