Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 24th of October 2007 (Wed)   #1
EOS Man
Happy Lucky 888 EOS
EOS Man's Avatar
Default AA NiMH batteries top-up
I charge my set of AA NiMH batteries in a 6 hour Sony charger - and that is a freakin long time. Is it possible to 'top up' AA batteries like we can do with li-ions? Like if the batteries are down by 1/3 juice, then would it take 2 hours to top up or need to go through another 6 hour charge cycle?
My EOS Gearlist
EOS Man is offline   Reply With Quote
Old 25th of October 2007 (Thu)   #2
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Default Re: AA NiMH batteries top-up
Yes, you can "top off" NiMH - unlike NiCds they don't have a "memory effect".
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 25th of October 2007 (Thu)   #3
gasrocks
gasrocks's Avatar
Thomasdistributing.com is the best place I have found for batteries, chargers and info. Sounds like a very long time to me. Maybe a better charger?
gasrocks is offline   Reply With Quote
Old 25th of October 2007 (Thu)   #4
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Fast chargers tend to get the batteries hot - and that breaks the electrolyte down faster, so the batteries don't last as long. It's a tradeoff. Generally, I won't use a fast charger unless I need to get a set charged ASAP. I carry enough to get me through the day and have several recharging at night or the next day.
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 25th of October 2007 (Thu)   #5
i2iSTUDIOS
I have found that the Energizer 2500 rechargeables work great!
i2iSTUDIOS.com
My Blog
D800
D3
i2iSTUDIOS is offline   Reply With Quote
Old 26th of October 2007 (Fri)   #6
asysin2leads
I'm kissing arse
asysin2leads's Avatar
I have the Duracell rechargables (black and green) that are 2650 mA and they seem to do very well. I carry a charger with me and have 24 batteries with me just in case. I've ran out of juice once and there won't be a twice. I missed some great shots by running out of battery.
asysin2leads is offline   Reply With Quote
Old 26th of October 2007 (Fri)   #7
Rudy M.
6 hours isn't bad for 2500mAH cells--that's 500mAH of charge per hour with some top-off, assuming dead cells. OTOH, if you are topping off and the charge time lasts 6 hours, you need a better, SMARTER charger. You would be overcharging your cells. Overnight, slow charging is best for your cells. Fast charge only when you need to. As a rule of thumb, if a NiCd cell could get cycled over its useful life a 1,000 cycles, then an equivelent NiMH cell should be good for about half that, and a Lithium Ion cell about half that. Each time you use the battery, then charge it, even if "topping off", it is considered a cycle. You will get a very short life from your Lion camera packs if you keep topping off--but at $12.00 a pack from Sterlingtech--who cares. In typical consumer applications, it is highly unlikely NiCd cells would develope a "memory" effect--I have some NiCd packs that are about 8 years old that still function fine--I just run them down every 10 cycles or so.
Rudy M.---Thanks to this site, I'm learning something new all the time!
Rudy M. is offline   Reply With Quote
Old 27th of October 2007 (Sat)   #8
tunin
tunin's Avatar
http://www.batteryspace.com/
I am not young enough to know everything. O.W.
www.medjugorje.net
*** Amateur tools ***
tunin is offline   Reply With Quote
Old 27th of October 2007 (Sat)   #9
Raymate
Second Thomas Dist...
Get a quality charger that can do different charging speeds then you can do whatever you like. Like the Powerx or the Lacrosse
But slower is better, if you want to fast charge make sure you also do some slow ones as well.
Canon: EOS 5DmkII • 50D • 40D • 350D • 100 f2.8L IS Macro • 70-200 f4L • 24-105 f4L IS • 17-40 f4L • 50 f1.4 • 60 f2.8 Macro • 85 f1.8 • 430EX • 580EX II • ST-E2
Sigma: 10-20 f4-5.6 EX DC HSM • 30 f1.4 EX DC HSM • 17-50 f2.8 EX • 24-70 f2.8 EX DG MACRO
Apple: CS3, Aperture & iPhoto. Various Manfrotto, Portaflash, Battery Grips, SanDisk & Lowepro
alamy: my stock photography
Raymate is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Chargers for NiMh AA batteries rahimitudm Accessories & Storage 2 6th of January 2007 (Sat) 14:18
NIMH Batteries & Charger drisley Accessories & Storage 6 17th of May 2006 (Wed) 12:48
go buy some NiMh batteries - now cosworth The POTN Lounge 5 24th of November 2005 (Thu) 23:56
Are the Energizer 2500 NiMH batteries new? ShutteringFocus Small Flash and Studio Lighting 8 24th of June 2005 (Fri) 07:58
NiMH Batteries for Canon A60 freestyle3486 Small Compact Digitals by Canon 6 5th of May 2004 (Wed) 10:53
