#1 |
Just got a G2 with DC58 wide angle lens. I am worried about damaging the DC58 lens. Is there a filter or glass cover that can be attached to the outside of the lens casing to protect the exposed glass lens?
Thanks for your help. I'll have to browse the other messages posted here too now. |
| sponsored links |
#2 |
The end should be threaded for a 58MM filter.
You can also get a lens cap for the same size. The squeeze clip ones lock tight and come off quickly and will work either over the lens end or the screwed-in filter. |
| Thread Tools | |
| Display Modes | |
| Wide angle lens | suzanneRN | Canon EF and EF-S Lenses | 2 | 26th of April 2007 (Thu) 21:50 |
| Best Wide Angle Lens for S3? | gregrocco | Small Compact Digitals by Canon | 0 | 2nd of March 2007 (Fri) 15:00 |
| Which wide-angle lens? | dafnis | Canon EF and EF-S Lenses | 9 | 18th of July 2006 (Tue) 11:58 |
| Wide Angle Lens | mergino | Canon EF and EF-S Lenses | 9 | 24th of October 2005 (Mon) 10:42 |
| 37mm telephoto, marco lens and wide-angle lens | eagles_creek | Small Compact Digitals by Canon | 0 | 22nd of May 2003 (Thu) 16:46 |
