Reply
Thread Tools Display Modes
Old 11th of August 2004 (Wed)   #1
jimtfoto
jimtfoto's Avatar
Default Pro 1 feedback requested
Guy at work is looking at purchasing Canon's Powershot Pro 1 ... any users have comments pro or con? I've heard some of these fixed lens 8 mp cameras have an unusally high amount of noise at anything above ISO 100 ... that true?
The Pro 1 would be used in a newspaper environment ... I have no experience with this camera, since I use a 10D and the pro photogs I know have just been equipped with MkIIs (they don't know anything about the Pro 1 either).
Any input would be appreciated.
Cheers,
jim
www.pix2go.ca
Sometimes I do get to places just when God is ready to have somebody click the shutter.
- Ansel Adams
jimtfoto is offline   Reply With Quote
Old 11th of August 2004 (Wed)   #2
jwcdds
jwcdds's Avatar
Default
I find the noise level to be acceptable at iso 200 and "tolerable" at 400. Nothing a little noise-reduction software can't clean up. But again, it depends on the nature of the photos and what the project require. The pro1's small sensor cannot compare with the huge CMOS sensor of the Canon DSLR in high-iso/low-noise performance. But in adequate lighting, and/or under the right conditions, the pro1 (imo) performs incredibly well.
The pro1 is kind of a walk-around camera. Great for scouting work, hikes and vacations. 28-200mm equiv lens goes a long way to cover "most" needs. But it certainly has its limitations: poor low-light AF performance due to lack of AF-assist, minor vignetting at wide apertures, etc...
Unfortunately, I'm but an amateur to photography so I am not familiar with what a "newspaper environment" is and how the pro1 would fair.
Julian
Gear/Feedbacks | SmugMug
Founding member and President of the OGUS Photo Club (Over-Geared, Under-Skilled)
jwcdds is online now   Reply With Quote
Old 23rd of August 2005 (Tue)   #3
tonymerlin
Default Re: Pro 1 feedback requested
Hi, I'm certainly in the amateur category, but take a look at this website 'http://www.pbase.com/nero_design'.
It will show you just what the pro1 is capable of (in the right hands).
Best regards . . .
tonymerlin is offline   Reply With Quote
Old 24th of August 2005 (Wed)   #4
zacker
zacker's Avatar
pro 1 is fine for stills, landscapes and macros and studio work... action shots get a bit iffy unless you know when and where the action will be and you pre focus!
I love my Pro1... I also love my 350D I just use each one for its own particular use.
Craig-
zacker is offline   Reply With Quote
Old 24th of August 2005 (Wed)   #5
davidfig
we over look the simplest things
davidfig's Avatar
I took a look at the pro 1 some time back. I was more impressed than I thought I would be. Outdoors (lota light) is take some real good pictures. I think most of its competitors are rated better. But for some reason (L glass) the pictures I saw where on par with the D70 which just came out.
maybe a 350D with tamron 18-200 would do the trick. Just depends on how small you want.
5D | (2) 550EX | 17-40L | Tammy 28-75 2.8 | 28-135 | 50/1.8 | 85/1.8 | 70-200L 2.8 IS
Sigma 18-125 | (4)AB B400 | Load of Pentax M42's
davidfig is offline   Reply With Quote
Old 25th of August 2005 (Thu)   #6
Airedale1
Airedale1's Avatar
jwcdds hit most of my points. I would add too that the inherent shutterlag alone would probably disqualify it as a tool for a photojournalist. It will take excellent pictures under the right conditions. But, as a photojournalist you don't always have the ability to take the shot under optimum conditions.
Airedale1Photography
EOS 7D EOS 40D
EF-400 f/5.6L EF 70-200 f/4.0L IS EF 50 f/1.4 EF 17-40 f/4.0L IS EF-1.4x II 430EX II Speedlite
Paul Merritt
Airedale1 is offline   Reply With Quote
Old 25th of August 2005 (Thu)   #7
Maureen Souza
Ms. Moderator
Maureen Souza's Avatar
I have a Pro1 and I really like it for a walk around, P&S...... They are much more affordable these days too as they were around $1000 when they first came out.
5DmkIII 7D
Canon Lenses:
50/1.4, 85/1.2 135/2.0,
300/f4, 24-70!
Pro1
Maureen Souza is offline   Reply With Quote
Old 26th of August 2005 (Fri)   #8
Wsman2
Wsman2's Avatar
Picked mine up through here (by way of resellerratings.com): http://www.beachcamera.com/shop/Prod...=&Sku=CNPSPRO1.
With shipping (to CA from NJ), it came to $588.
Don't forget to do the firmware update (if applicable).
I like what it's done for me so far, but I have a ways to go with it yet.
Wsman2 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Trying something new... Feedback requested Jwreich People 8 17th of June 2006 (Sat) 20:41
Feedback requested: First attempts at concert photography tfire Performing Arts 18 23rd of May 2006 (Tue) 15:45
Feedback Requested on this Lighting System flauri Small Flash and Studio Lighting 4 21st of November 2005 (Mon) 00:55
Feedback Requested! B & G Sittin' on the dock SuzanneCarey Critique Corner 7 23rd of June 2005 (Thu) 04:03
A couple photos - feedback requested jerseycowboy Critique Corner 1 4th of February 2005 (Fri) 09:10
