Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 29th of October 2007 (Mon)   #1
Jethro790
Jethro790's Avatar
Default Second Curtain Sync
Can someone explain or demonstrate what this means for me? The manual says something about a light trail following the subject... Excuse my ignorance.
Thanks!
If you must know...
Jethro790 is offline   Reply With Quote
Old 29th of October 2007 (Mon)   #2
E-K
Default Re: Second Curtain Sync
Basically the flash will fire just before the shutter closes rather than when it just finishes opening. So say you were photographing a car with a relatively slow shutter speed. You will see the red lights registering on the image behind the car and then the flash illuminates the car and freezes it -- so you have a nice bright image of the car with a light trail behind it.
With first curtain sync the light trail would be in front of the car. You could always drive in reverse I suppose .
e-k
E-K is offline   Reply With Quote
Old 29th of October 2007 (Mon)   #3
mikep00
A simple example is a moving car in low light. If you shoot it regular (first curtain shutter), you will have the flash go off at the beginning on the shot. So the photo would be a sharp image of a car, with a motion blur going forward. Kinda seems backwards, but if you set it for 2nd curtain, then you will have a motion blur with the sharp image at the front.
That would convey the movement of the car much better. Test out the 2 settings on a moving object and you will understand
mikep00 is offline   Reply With Quote
Old 29th of October 2007 (Mon)   #4
Tommy
I have a Peepster.
Tommy's Avatar
Now if you want to get technical....
You camera has 2 shutter curtains. When you click the shutter release, the first curtain opens exposing the film (in our case, sensor). Once the media has been exposed for the set amount of time, the second curtain closes behind it. At our camera's sync speed (the 30D is 1/250th) the second curtain closes the instant the first one if fully opened. Anything faster than sync speed and the second curtain starts to close before the first one is even open all the way. Your flash is normally set to fire as soon as the first curtain is open, before the second one starts to close. If you set it to 2nd curtain sync, it fires as soon as the 2nd curtain is about to close. So at 1/250th shutter speed, you'll see no effect of 2nd curtain sync. As far as the effect on slower shutter speeds, the others here have already described that to you.
Sorry if you didn't want the technical stuff.... I felt like typing though... lol...
Tommy
___________________________
"Vision without execution is hallucination" - Thomas Edison (1847-1931)
MySpace | Facebook | ModelMayhem | Blog | Central PA Wedding and Senior Photographer | Gear List
Tommy is offline   Reply With Quote
Old 29th of October 2007 (Mon)   #5
Curtis N
Master Flasher
Curtis N's Avatar
Illustrated here:
http://web.canon.jp/imaging/flashwor...ain/index.html
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #6
grphx
grphx's Avatar
Good thread!
Canon 50D, Canon 430ex(x2) Canon 70-200mm F/2.8 L Tamron 17-50mm f/2.8
grphx is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #7
tmartin110
I found these videos on You Tube were very helpful in breaking it down to simple science. Snapfactory is the video creator and they have several that are helpful.
http://www.youtube.com/watch?v=Xnn5nzPvoIM
tmartin110 is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #8
bwolford
bwolford's Avatar
The same thing can happen with rain drops. With first curtain sync the rain appears to fall up, with second curtain sync, rain falls down...
Brice
Sample Gallery
bwolford is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #9
Big WIll
"Slight breach of etiquette"
Big WIll's Avatar
Go out and try it for yourself and it will make a lot more sense
Computers blur the boundaries... We are being released from the suddenness of photography, the suddenness of the shutter
Big WIll is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #10
Jethro790
Jethro790's Avatar
Thats a good idea!
Thanks everyone, I think I get it.
If you must know...
Old 30th of October 2007 (Tue)   #11
dancinec
dancinec's Avatar
Here is what I have read in nature photography magazine recommending the second curtain sync. The animal may react to the flash, but since the flash comes as the second curtain is closing, the animal's reaction comes after the exposure.
Dennis
Canon 20D, 30D, 40D, 50D, Canon 100 mm Macro, Canon 100-400mm, Canon 400mm 5.6L, Canon TC 1.4X, Tamron 28-75 mm, Bogen 3221 Tripod, Kirk BH-1 ballhead, Sigma EF-500 DG Super Flash, Canon 580 II Flash, Better Beamers, Whimberly Plamp.
My galleries
dancinec is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Second curtain sync w/ST-E2 tfiorda Small Flash and Studio Lighting 3 3rd of October 2007 (Wed) 14:43
Second Curtain Sync Brandon123 Small Flash and Studio Lighting 4 5th of January 2007 (Fri) 15:43
second curtain sync? statenine Small Flash and Studio Lighting 5 4th of October 2006 (Wed) 17:08
Rear Curtain Sync ? Mrs Smarty Pants Canon EOS Digital Cameras 8 17th of July 2006 (Mon) 22:27
Second curtain sync with 10d beardo Small Flash and Studio Lighting 3 7th of June 2006 (Wed) 06:22
