#1 |
I haven't used my 40D for a week or two and now when I turn it on and try to do anything, the small LCD just says "buSY" on it. The camera Auto Focuses fine but I am unable to take any pictures or even review the pictures I have taken. Am I missing anything here? =/
I've tried removing the battery including the tiny back up one yet the problem still exists. Last edited by mikaelrules : 30th of October 2007 (Tue) at 01:58. |
| sponsored links |
#2 |
Do you mean the LCD on the top of the body?
Have you removed all batteries, including the date battery? If not, please do that, cycle the power switch and shutter switch a few times and then let the camera sit for half an hour or so. After that, put the batteries back in and start over. If you still have the same problem, you need to get a replacement. I'm curious what brought this issue on. Did you make any changes of lenses or other accessories? The reason I ask is that I'm on my second 40D, which started Err 99-ing and it is back for service now. I'm awaiting word on what the problem is. It would be really great if we could figure out if there is some combination of accessories that the 40Ds just don't like. I know that isn't a happy thought, but I am beginning to wonder. Best, Michael
40D kit is sold | G10 Love it!!! | 350D w/BG-E3 | EF-S 10-22 | 70-200 2.8L | Canon 1.4x II | Tammy 28-300 VC | B+W filters | Novoflex Magicball | 50D and 5D MKII on the way... |
#3 |
Yup, I mean the LCD on top of the body. Right now the camera is sitting without any batteries and I'm going to try again later tonight to see how it goes.
I did not touch the camera from the time I last used it to the time this error started showing up. All I did was take out the CF card a few days ago to copy pictures. The lens on the camera is still the one I was using when the camera was working fine. (24-70L, if it matters). I hope I don't have to send this back to Canon because I'm leaving for Tokyo tomorrow and might have to take the 350D instead. |
| sponsored links |
#4 |
Small world, I was in Tokyo with my 350D back in March/April of this year. If you are in Shinjuku, you've got to check out the Canon Digital Center there, it's caddy-corned across the street from the Hilton.
I have heard that some people have had to leave their cameras sit overnight with all batteries removed to clear them. Too bad you have to leave tomorrow. That is a really weird error. I take it that the error continues with a CF card in place. That's the only thing I can think of. Please keep us posted. I'm really wondering about the 40D, way too many issues around the world with this camera. Even if your 40D isn't working, why not take it with you? If you are in Tokyo, Canon will work on your camera there while you wait. Their service was incredible when I was there. Don't worry if you don't speak Japanese, there will be someone there to help you. Good luck, Michael
40D kit is sold | G10 Love it!!! | 350D w/BG-E3 | EF-S 10-22 | 70-200 2.8L | Canon 1.4x II | Tammy 28-300 VC | B+W filters | Novoflex Magicball | 50D and 5D MKII on the way... Last edited by M24 : 30th of October 2007 (Tue) at 02:31. Reason: typos |
#5 |
Try another card if you have one. Could be corrupt and the body could be stuck reading it.
#7 |
Well, I just put the batteries back in and still got the same result. Same goes for trying another CF card. I've never used the camera's USB connection, but I just tried plugging it in and... nothing happened. The computer did not detect anything and the camera remained in its "stuck" state. I guess my camera's off to canon when I get to Tokyo then.
#8 |
Please let us know what happens when you return from tokyo.
Also, when I was at the Canon Digital Center in Shinjuku, they had just about every model laid out on a table for consumers to play with. Back then in March, I got to play with a 1D MK III and was blown away. Perhaps you will get to handle a 1Ds MK III? I am looking forward to hearing more on your story. Best, Michael
#9 |
Well, I just got back from the Canon service center here in Tokyo and they said it would take 10 days for them to get it fixed. Unfortunately, I'm not going to be here that long so I guess I'm just going to get the camera fixed when I return to the Philippines on Sunday.
#10 |
Ten days!!! Wow!
Did they tell you what is wrong with it ![]() I hope they gave you some info. Also, did you get to play with anything new while there? I'm jealous, if I could, I'd be on a plane to Tokyo today, I love it there!!! Best, Michael
#11 |
Hi guys, I'm having the very same problem on my 40D, and I think its a CF card problem, although I use a fast Extreme III 2.0G Sandisk card. Maybe this happens when you delete your old data with a PC instead of the camera? Or maybe when you have all the sharpening functions turned on? But why the unusually long delay between shots when you have the highly-touted DIGIC III processor inside your camera? I'm with M24 on this, I wish Canon gave us some info....
#12 |
my 40D and 30D both still show 'busy' AFTER all pics are finished downloading to the pc, i just turn camera off and disconnect cord with no problems.
i saw a thread like this a week aog.
Rob - "a photographer is a painter, in a hurry!" Canon 7D ~ Canon EF 70-200mm f/2.8L IS MKII ~ Canon EF-S 17-55mm f/2.8 IS ~ Canon EF 50mm f/1.8 II ~ Canon 430EX ~ Canon 580EXII ~ Canon EF 2.0X III Telephoto Extender ~ Canon SX230 HS |
#13 |
are you able to get into the menu?
if so, maybe resetting all options to default might do the trick. and, failing that how 'bout installing or re-installing (if possible) newest firmware?
i'm a canon gear junkie..........i..... need....help............in buying me more canon gear. ![]() Gear List |
#14 |
me? i'm able to still access all functions, so i'm not concerned at this point.
#15 |
phocalphobe, were you asking me? I checked my firmware, its an older version (v1.3), but seems the new one posted by Canon is fraught with problems too (v1.5). I'll try resetting to defaults and see what happens. My problem started when I started shooting in low light and the batteries of the hotshoe flash gave out. Maybe it tripped something...
Last edited by Aliengreen : 23rd of December 2007 (Sun) at 04:05. Reason: additional info |
| Thread Tools | |
| Display Modes | |
| Camera saying "busy"---XTI users | dianas | Canon EOS Digital Cameras | 18 | 14th of July 2007 (Sat) 16:14 |
| "BUSY" message flashing on LCD when plugged in via USB | verty | Canon EOS Digital Cameras | 13 | 7th of November 2006 (Tue) 02:03 |
| Alien Bees "Busy Bee" Package!!! | StealthLude | Small Flash and Studio Lighting | 10 | 31st of March 2006 (Fri) 03:22 |
