Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The POTN Lounge
Reply
Thread Tools Display Modes
Old 30th of October 2007 (Tue)   #1
mchong75
Default Laptop hard drive speed and space
Is there a noticeable difference between a 5400RPM versus a 7200RPM hard drive?
I’m customizing my laptop order via Dell.com and I can’t decide if I want the faster hard drive or to go with a larger memory. If I could, I would like both but Dell doesn’t offer that.
My choices are:
  • 250GB SATA 5400RPM
  • 160GB SATA 7200RPM
mchong75 is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #2
jeffscra
Default Re: Laptop hard drive speed and space
I would take the space over the speed.....I really doubt you will notice the difference between the two during operation.
jeffscra is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #3
mchong75
That's what I was wondering.
I know on paper (specs), the 7200RPM is faster but, for average joe, I wonder if it's really noticeable.
Old 30th of October 2007 (Tue)   #4
AirBrontosaurus
AirBrontosaurus's Avatar
Speed really, really is noticeable. Startlingly so. A 5400 RPM HDD will feel like January Molasses compared to a 7200 RPM one. Windows will boot up much faster, your computer will respond more quickly, and programs will start up faster too.
Go for speed over space is speed is AT ALL important to you. If you really don't care, then I suppose space would be better.
Still, going from 160gb to 250gb isn't really all that much.
Chris | My Flickr | AirBrontosaurus.com | Peleng 8mm Fisheye writeup
Body
: Canon 5D
Lenses: Canon 24-105mm f/4 L | Canon MP-E 65mm Macro | Canon 85mm f/1.8 |
AirBrontosaurus is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #5
misfit
misfit's Avatar
definately an issue, go with the faster speed drive as AB says.
Canon EOS 7D, EF 18-55mm (Kit Lens), EF 50mm 1.8 Mk II, Tamron AF 70-300mm F4-5.6, Sigma 50-500 F4:6.3 APO DG. Sigma 300 F2.8. MP-E 65mm
misfit is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #6
toneyw
toneyw's Avatar
IMO, I'd go with the larger drive. Unless you do alot of data transfer, the few ms you gain is nothing.
Canon 30D Gripped
EF 70-200 2.8L IS
EFS 17-55 2.8 IS
Speedlight 430EX
055XPROB w/ 488 RC2 Head
toneyw is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #7
mchong75
Hmmm, now that you mentioned it, it is sluggish when I try to lanuch applications, upload and download files from portable hard drives, windows does boot up bit slow.
Decisions, decisions, decisions...........
Old 30th of October 2007 (Tue)   #8
cdifoto
Don't get pissy with me
cdifoto's Avatar
The smaller faster drive is a smarter option. Get an external to dump your non-working files to. If there was a 160GB 7200 SATA drive option when I got my Dell I would have jumped on it, but I had to go with an 80GB SATA for the same speed.
Did you lose Digital Photo Professional (DPP)? Get it here. Cursing at your worse-than-a-map reflector? Check out this vid!
cdifoto is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #9
jtalerico
jtalerico's Avatar
What what are you going to use the laptop for?
Seeing that this is a photography forum you are not going to need a very fast drive to open / edit / save files. Now if this was a server or if you were going to be using this laptop for gaming, then yes, I would suggest the 7200RPM...
Website 7D | 70-200 2.8 IS L | 10-20 F3.5 SLD | 17-50 F2.8 EX FLD | 580EX II | BG-E7 | Bogen legs & Bogen 3265 Head | ThinkTank UD60 | Lowpro 302AW
jtalerico is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #10
Tony-S
Tony-S's Avatar
Originally Posted by AirBrontosaurus View Post
A 5400 RPM HDD will feel like January Molasses compared to a 7200 RPM one. Still, going from 160gb to 250gb isn't really all that much.
At around 120 or 130 gigs of data, the 250g/5400rpm drive will catch and surpass the the 160g/7200rpm drive in speed.
Gear list
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Beginner's guide to printing.
The PoTN film thread. 
Tony-S is offline   Reply With Quote
Old 30th of October 2007 (Tue)   #11
mchong75
It's mainly for photo editing & storage. And, of course, musics and video files. (which these take up most of the spaces)
Old 30th of October 2007 (Tue)   #12
jtalerico
jtalerico's Avatar
mc -
I highly doubt you are going to really notice much of a difference from 5200 - 7200 with what you are going to be using the drive for.
Old 30th of October 2007 (Tue)   #13
AirBrontosaurus
mc -
You mean, like... anything?
If you care about performance at all, the difference really is night and day. I've owned and worked with both; 5400 RPM is slow. Now, if you don't care about speed, then 5400 RPM is just fine... but then why ask the question in the first place?
I believe that, since the OP asked if he should get a faster drive or a larger drive, that he was interested in the performance a faster drive would offer, and was wondering if it was worth losing the additional size for. If you care about performance even a little bit, it is well, well worth the trade off of space. Thus, I believe that the speed difference on a 7200 RPM drive is worth trading for the space on the 5400 RPM drive.
And, an external 400gb HDD and enclosure is all of about $90. So, buy the faster drive, then put your OS, photoshop, and other larger/disk hungry applications on it. Then, dump the rest on the 400gb.
Disk speed can and does make a huge difference in the performance of a computer. HDDs are by far the slowest components, so any increase in performance on them is going to be felt by every other aspect of your computing.
True, but now you're getting into large-data burst rates, fragmentation, and other factors (ie, it's no longer apples to apples). The fact is that the access time of a 7200 RPM drive is less than that of the 5400 RPM drive, which leads to faster access of your data. The factors that can affect that access time (such as using a huge portion of the drive) are important, but that example is not exactly fair. In practice, the 7200 RPM drive is faster if you use a percentage instead of an absolute (and somewhat arbitrary) value (ie. 230 of the 250gb available on the larger drive compared to 150 of the 160gb on the small drive).
If you ever find yourself using 85-90% of a hard drive's capacity, then ANY drive is going to slow down. Instead, get a cheap dump drive and most of your problems will go away.
Body
: Canon 5D
Old 30th of October 2007 (Tue)   #14
cdifoto
cdifoto's Avatar
If there was no performance difference between 5400RPM and 7200RPM, they wouldn't make 7200RPM drives.
Old 30th of October 2007 (Tue)   #15
jtalerico
jtalerico's Avatar
Anyway, OP you cannot go wrong with either drive for what you are going to be using it for.
^^ How about battery life? From what I have read you will see about 15% increase in computer performance. But with that, your battery will suffer.. Not sure how much though.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WTB Laptop Hard Drive 2.5" internal thesupe87 Classifieds: Buy 6 18th of July 2007 (Wed) 12:42
Best hard drive?(for a Macbook pro speed vs.capacity) mknabster The POTN Lounge 2 11th of June 2007 (Mon) 11:53
cf flash memory vs hard drive/seagate photo drive pokertable Accessories & Storage 3 21st of August 2006 (Mon) 22:39
Cheap drive enclosure for 2.5/laptop drive R Schade Accessories & Storage 0 13th of June 2006 (Tue) 10:54
What do you do for Extra Hard drive space/storage for Large files/Raw ?? OverRunWithSons Accessories & Storage 15 11th of October 2005 (Tue) 16:41
