Reply
Thread Tools Display Modes
Old 14th of August 2004 (Sat)   #1
clauger
Default Recharging G-5 Battery in Italy
I am planning a trip to Sicily this fall. I have a plug adapter to allow me to plug my G-5 battery charger into European wall outlets. Is this all I will need? Is there more than one type of plug adapter that could be required? I don't want to arrive and discover I can't recharge my battery. Thanks for any advice.
clauger is offline   Reply With Quote
Old 15th of August 2004 (Sun)   #2
Andy_T
Default
As was stated in about 20 threads in this forum ... your charger should work without problems.
Check it out ... on the charger it should read something like 100-230 Volts input. In Europe, we have 220 Volts, so it will work.
You only need the proper adapter to plug it into the wall in Italy. If you don't have that, you'll be able to buy that one in Europe or get it from your hotel receptionist.
Best regards,
Andy
Andy_T is offline   Reply With Quote
Old 15th of August 2004 (Sun)   #3
clauger
Default
Thanks. I do see that on my charger.
I did search the forum before posting, but didn't find the threads. Next time I'll search longer before posting.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
recharging batteries rachellen Accessories & Storage 3 26th of August 2006 (Sat) 02:57
recharging battery for s50 powershot hulagal Accessories & Storage 3 18th of April 2006 (Tue) 19:56
Recharging the battery on the 1D MKIIn question rrpruett Canon EOS Digital Cameras 4 29th of January 2006 (Sun) 14:47
1D Battery recharging problem clayk Accessories & Storage 7 29th of October 2003 (Wed) 12:23
Battery not recharging? MichaelH Canon G-series Digital Cameras 8 6th of August 2001 (Mon) 14:48
