Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 1st of November 2007 (Thu)   #1
oatbill
oatbill's Avatar
Default A540 Problems
Hey everybody, I'm having trouble with my year old A540. It will take photos with no flash fine, but if I try to use the flash the flash on the LCD just blinks and the camera won't focus of take the shot. Any help would be terrific. Thanks
oatbill is offline   Reply With Quote
Old 4th of November 2007 (Sun)   #2
rjevang24
rjevang24's Avatar
Default Re: A540 Problems
My wife has the same camera and was experiencing the same problem. A fresh set of batteries solved the problem.
rjevang24 is offline   Reply With Quote
Old 16th of August 2008 (Sat)   #3
rlowe82
I found this after having the same problem:
http://www.usa.canon.com/consumer/co...=2111&id=28799
Does your camera still have the issue?
rlowe82 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
A540 Caraamericana Small Compact Digitals by Canon 1 13th of July 2007 (Fri) 09:43
need help printing from A540 djdevastator Small Compact Digitals by Canon 1 29th of January 2007 (Mon) 20:58
need some help with my a540 settings... a540tjl General Photography Talk 0 7th of January 2007 (Sun) 14:23
any problems with the A540? JW22 Small Compact Digitals by Canon 1 4th of December 2006 (Mon) 18:28
Anyone have any experiences with the new A540? littlehouse Small Compact Digitals by Canon 2 3rd of April 2006 (Mon) 19:22
