Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 27th of July 2002 (Sat)   #1
Woodchuck
Default Sharpen on the camera or after the fact?
Hi,
I have an S30 and am having a blast with it. However, generally I find the pictures a little on the soft side and generally do a minor "sharpen" of most of them (usually with ACDSee). Today I went to an outside model train show and set the sharpen control on the camera on the plus side. The pictures I took today seem a lot better and don't feel I need to use sharpen on the computer side. My curiosity is if it makes any difference to sharpen on the camera or afterwards on the computer? My gut feeling is that it may retain better detail when cropping if done on the camera. Any thoughts on this?
Thanks a lot!
Woodchuck is offline   Reply With Quote
Old 28th of July 2002 (Sun)   #2
jim9tan
Default Re: Sharpen on the camera or after the fact?
Sharpness can be very subjective. It is a good idea to test your camera's sharpen facility against the software that's available to you.
Software varies in ability. In general, the Unsharpen Mask (USM) technique yields the best results. It allows you to specific the degree of sharpening (from 1 to 100), the radius of the effect, etc.
In my tests, I find that TIFF images from RAW files are soft. The JPG images are "sharper" and noisier. TIFF images which have been sharpened "in" camera are slightly sharper than JPG and somewhat less noisy.
The question is: How "sharp" do you need your output? Only you can decide. I suggest that you experiment with USM on RAW/TIFF and JPG images.
Find your preference. Also, USM can be used to correct images that are less than perfect. I am sure that all of us take pictures like that.
Regards,
jim9tan is offline   Reply With Quote
Old 28th of July 2002 (Sun)   #3
Woodchuck
Hi jim9tan,
Thanks much for the feedback! I have a lot of experimenting to do and that is the element that is really keeping me interested in photography. Years ago I played around a lot with 35mm photography, but did not have nearly as much fun as I am having with the digital in learning how to compose, edit and do special effects on photos. And, what a joy to go out shooting for a day and realize I am not wasting film
Old 24th of August 2002 (Sat)   #4
Aundog
I missed something! Which control do you use to sharpen the image on the camera (S30)?
btw do you find the Auto mode with flash on gives flesh tones that are much too red?
Aundog is offline   Reply With Quote
Old 24th of August 2002 (Sat)   #5
Rustle
Sharpening can be found at the bottom of the menu screen. I'll save flash comments for your other thread.
Russ
Rustle is offline   Reply With Quote
Old 25th of August 2002 (Sun)   #6
Aundog
Thanks Russ
I was in Auto Mode and thus no Sharpness option; found it now!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
To Sharpen or Not to Sharpen for Stock Davidsl222 The Business of Photography 10 30th of August 2006 (Wed) 20:18
What is better - Camera built-in Sharpen, or PS CS2 USM ? roli_bark RAW, Post Processing and Printing 6 8th of June 2006 (Thu) 16:12
Sharpen in camera? unclokie RAW, Post Processing and Printing 13 4th of July 2005 (Mon) 19:24
10D RAW and JPG out of camera sharpen questions. flipp Canon EOS Digital Cameras 2 26th of October 2004 (Tue) 23:41
