Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 13th of November 2007 (Tue)   #1
Collin85
Collin85's Avatar
Default HDR without tripod.. 5fps?
OK, I'll admit it.. I'm not a huge fan of tripods. It cramps my shooting style and although I most definitely bring them for night cityskapes/evening shoots, I tend to leave it home most other times. But I really want to explore HDR more, so here I'am.
My question is: I was wondering if the continuous shooting in cameras like the 30D would be good enough for me to leave the tripod home (for daytime situations). Say I set the 30D on 5fps, bracket 3 exposures.. what kind of shutter speeds would I need (for say, the overexposed shot (which requires the slowest shutter speed out of the lot)) to make it all work out relatively well?
I was thinking probably atleast 1/200th, but again I know it would depend on one's level of hand shake and their own definition of what is acceptable for shot to shot disprepancy.
Anyone have any experience with this?
Col | Flickr
5D3, 5D, 16-35L, 35L, 50L, 85L, 135L.
E-M5, CV 17.5/0.95
Collin85 is offline   Reply With Quote
Old 13th of November 2007 (Tue)   #2
adam LC
adam LC's Avatar
Default Re: HDR without tripod.. 5fps?
depends on the lens you use and the available light, I wouldn't have the slowest shutter speed any less than double the selected focal length, i.e FL@100mm=SS@1/200. Trial and error.
If you saw a man drowning and could either save him or take a picture...
What kind of film would you use? - Anonymous
adam LC is offline   Reply With Quote
Old 13th of November 2007 (Tue)   #3
NOsquid
NOsquid's Avatar
Just lock your elbows and give it a go. Photomatix has an alignment, and I'm sure there's way to do it in PS. Not ideal I suppose.
If you're not satisfied with the sharpness of your images then start with the tripod. Nobody can decide if the results are satisfactory but you.
NOsquid is offline   Reply With Quote
Old 13th of November 2007 (Tue)   #4
Collin85
Collin85's Avatar
Woops, I forgot to specify the lenses. It'll most likely be the 10-22, 17-40 or 17-55. I'd assume even 1/60th might be OK if you've got steady hands, but to be sure I thought I'd suggest something more like 1/200th.
Col | Flickr
E-M5, CV 17.5/0.95
Old 13th of November 2007 (Tue)   #5
azpix
azpix's Avatar
i say it won't work because if it's off even slightly the software gets jacked and also you mentioned night shots which means longer exposures.
That said...give it a shot.
Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20, Sigma 24mm 1.8 and a canon G11.
azpix is offline   Reply With Quote
Old 13th of November 2007 (Tue)   #6
adam LC
adam LC's Avatar
I agree, handholding for bracketed shots = trouble.
Old 14th of November 2007 (Wed)   #7
Jim Barnes
Yes it works, I've done it with a D60 (and I'm not sure of the frame rate on my dinosaur but it's well short of 5 fps). Photomatrix and Photoshop both perform alignment on images so much of it is taken care of for you.
You have to be careful with the shots though and keep a steady hand
on the odd occasion I've had to perform a crop and rotate for images that were well off but sooner or later the software grabs a hit.
To be certain of results I try to use a tripod but often its not possible. It's well worth a try, give it a go, experiment and work on your hand holding technique and you should see some results.
Jim Barnes
EOS 1n, EOS 33
EOS 5d mk II, 1d mkIIn, EOS 40D
Canon 300 f4, 70-200 f2.8, 24-70, 17-40, 100 2.8, 24 TS-E
Sigma 12-24
Jim Barnes is offline   Reply With Quote
Old 14th of November 2007 (Wed)   #8
stckciv
stckciv's Avatar
How bout a monopod?
There are always two people in every picture, the photographer and the viewer. ~Ansel Adams
stckciv is offline   Reply With Quote
Old 14th of November 2007 (Wed)   #9
aCiD99
aCiD99's Avatar
I do this ALL the time (I hate tripods too), in fact I did several just yesterday.
You'll probably have to take the same exposure set 3 times to get one set where you stayed sufficiently still between exposures. But it's not hard to get them aligned yourself in PS, then move them into whatever app you use for creating the HDR.
5DII, 7D w/grip, 30D w/grip; 10-20, 18-50/2.8, 70-200/2.8, 24-105L, 50/1.8 II, 28-135IS
www.bradgoldring.com
aCiD99 is offline   Reply With Quote
Old 14th of November 2007 (Wed)   #10
grig
Just make sure that the longest exposure respects the 1/f rule and you'll be fine. 90% of my hdrs are handheld.
grig is offline   Reply With Quote
Old 14th of November 2007 (Wed)   #11
Roy C
Roy C's Avatar
I have done successful HDR's hand holding the 30D with a 17-40 lens using 5fps mode and bracket 3 exposures (usually -2. 0 +2). Photomatix does a fairly good job of aligning the images providing there are some good well defined points to work to. Having said that, using a tripod is clearly best.
MY PHOTOSTREAM
500px gallery
Roy C is offline   Reply With Quote
Old 14th of November 2007 (Wed)   #12
ccp900
when all else fails, you can use 1 raw file to do an HDR.
ccp900 is offline   Reply With Quote
Old 14th of November 2007 (Wed)   #13
Roy C
Roy C's Avatar
Yep, Pseudo HDR from a single RAW works reasonable well for some shots.
MY PHOTOSTREAM
500px gallery
Old 14th of November 2007 (Wed)   #14
Miyagi-san
Miyagi-san's Avatar
wow those are a couple of awesome hdr shots, grig!
".....Nice camera! .....How many times zoom?!?"
Miyagi-san is offline   Reply With Quote
Old 14th of November 2007 (Wed)   #15
Donte
Donte's Avatar
Ok I am new to photography but what is a HDR image?
Donte is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Playing with 5fps with my 30D Chris Birds 2 16th of April 2007 (Mon) 17:16
Wishing 5D had 5fps.. Lightstream Canon EOS Digital Cameras 14 13th of August 2006 (Sun) 23:34
movie shot with 20D at 5fps booggerg General Photography Talk 6 3rd of May 2005 (Tue) 05:37
Animated Dunk...5fps tpinchback Sports 5 20th of January 2005 (Thu) 16:38
CP-E2 performance at 8.5fps timmyquest Canon EOS Digital Cameras 5 26th of December 2004 (Sun) 07:53
