#1 |
Anyone got info for removing the G1 lens so I can remove this spec?
Its not affecting the pictures as far as I can tell but it bugs me to no end for it to be there! Thanks for any info |
| sponsored links |
#2 |
A reply to my post about speck on lens: Yes, I agree that our two questions bring no answers. This form has many G1 users, but I can only guess no lens specialists. I took my camera to a repair shop that said scratches on the outer lens are much less a problem than any specks or blemishes on the inner lenses. The closer the defect is to the aperture the problem will be worse, he said. I also talked to a cousin of mine from Chile who is a photo buff and very well educated and here is his response to my question about a scratch on the lens:
In simple words: it affects, but depends on the % surface of the lens affected by the "speck" but must be really small but if you have warranty and all that stuff and it is no much trouble to get it changed, Do it. Not in Simple words: you can guess if the lens is for example 50 millimeters diameter like my Vivitar Lens when you calculate the area of the lens .... Radius = Diameter /2 = 25 Area = Radius * Radius * Pi = 1963.5 mm2 of surface ........ If the Speck is 3 by 1 mm means that have 3 mm2 of surface round 0.15 % of distortion ( FOR A 50 mm LENS!!!!) I just see your camera seems to have a lens of about 1" inch in diameter ...... do the math if you want but my recommendation is the same. |
#3 |
"but I can only guess no lens specialists" maybe there are! I have built many telescopes and ground many lenses and mirrors over the years. Dust in or on a lens usually doesn't effect resolution or light gathering but it can and does effect contrast. The more dust the lesser the contrast this is generally cause by light scattering. Dust inside a lens can also go astray and end up were it shouldn't! There should be no dust in a new camera lens, take it back and bitch! you paid good money for a quality instrument and dust is not part of the deal.
Grant |
| sponsored links |
#4 |
Hi I got several questions if you don't mind, is it true that using a shirt to wipe the lens of your camera could damage your lens? If so how much damage will it do to your lens, is it fixable? Please let me know and thanks in advance
#5 | |
El General Moderator
If a lens is slightly "unclean" it's not good to rub it all day long with any material - anything will wear out the coating if used too much. Clean it only when absolutely needed. Better still, don't touch the lens when shooting and get a Lensmate - it'll keep it out of dirt quite well.
This signature signifies my significance significantly Photo Gallery ---------------------------- |
#6 | |
Point is, do not let the cloth used for cleaning lenses to get in touch with anything that could stick on the cloth and harm the lenses. One wipe with microfibre cloth with a small hard particle can mean one scratch on the lens, one scratch that's deeper than any coatings. |
#7 |
I have worn prescription glasses most of my life, and I learned one important lesson early on. It's pointless to try to clean a lens if your hands are not really clean.
If at all possible, I wash my hands carefully with soap before I get near a camera. Hands don't have to be "dirty" to leave oily fingerprints on lenses. |
| Thread Tools | |
| Display Modes | |
| sprayway lint & dust remover-OLD | 77mini | The POTN Lounge | 1 | 19th of February 2007 (Mon) 13:34 |
| Strands of lint on pane where AF lights are (not mirror) | Charles4400 | Canon EOS Digital Cameras | 7 | 20th of October 2006 (Fri) 14:59 |
| Piece of lint on 20D Mirror | Nellas | Canon EOS Digital Cameras | 9 | 11th of May 2005 (Wed) 16:06 |
| A look inside an EF lens | GeForceFX | Canon EF and EF-S Lenses | 7 | 14th of March 2005 (Mon) 01:05 |
| I used a mini lint roller to clean my 10D sensor and now.... | BCdives | Canon EOS Digital Cameras | 14 | 10th of January 2004 (Sat) 01:28 |
