Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Urban Life & Travel
Reply
Thread Tools Display Modes
Old 14th of November 2007 (Wed)   #1
hudsonp
hudsonp's Avatar
Default how to shoot this picture....
this picture was taken with a simple point and shoot and it appears as though the building is collapsing on itself. i've been asked to reshoot this so that its more professional looking. I'm shooting with an XTI and a 28-135mm lens and a tripod, what other suggestions do you have so that this doesn't turn out like this:
hudsonp is offline   Reply With Quote
Old 14th of November 2007 (Wed)   #2
BottomBracket
BottomBracket's Avatar
Default Re: how to shoot this picture....
No need to reshoot, use the Transform tool in photoshop to make the vertical lines vertical.
Pio
Veni, Vidi, Canoni - I Came, I Saw, I Took A Picture With My Canon
Fotopio.com - Gallery of the Meandering Eye
I am a leaf on the wind. Watch how I soar.
BottomBracket is offline   Reply With Quote
Old 14th of November 2007 (Wed)   #3
hudsonp
hudsonp's Avatar
sorry to be a complete user, but i'm not familiar with what you are talking about. i have a very limited knowledge of photoshop.
Old 14th of November 2007 (Wed)   #4
dlw3
dlw3's Avatar
See if you can rent a 'shift' lens from a camera store?
Or, use a tripod that is half the height of the building.. ha ha.
dlw
dlw3 is offline   Reply With Quote
Old 14th of November 2007 (Wed)   #5
hudsonp
hudsonp's Avatar
dlw
i was looking into the shift lens ($45 to rent for a week) ~1300 to buy. i'm guessing that my 3001 legs wont quite reach to the height needed
Old 14th of November 2007 (Wed)   #6
RuggerJoe
RuggerJoe's Avatar
The only way to keep the vertical lines parallel is to shoot it with the film/sensor plane vertical. there are 2 options to do this, a tilt/shift lens as others have mentioned, or shoot it with the camera 's film/sensor plane. You would need to take a wider shot and then crop it since the building would be in the upper portion of the shot.
If you have photo shop there are a couple ways to correct the distortion. CS2 have a lens correction filter(cant remeber the exact name) under Filters>Distort >Lens Correction (or something like that).
Joe
Comments / critiques always welcome.
http://www.flickr.com/photos/ruggerjoe/
Canon 350D
EF-S 17-85 IS USM | EF 50 1.8 | EF 70-300 IS | 580EX | a couple of kit lenses
All of which are all better than my skills.
RuggerJoe is offline   Reply With Quote
Old 15th of November 2007 (Thu)   #7
hudsonp
hudsonp's Avatar
thank you! I'll start playing with this photo and hopefully i can make it look better just using CS2.
Thanks again
Old 16th of November 2007 (Fri)   #8
SwingBopper
SwingBopper's Avatar
In PS Elements I use: Filter-Correct Camera Distortion. It may be the same in CS2. But you'll lose some of the bottom (the picture will become a parallelogram and you'll have to crop to make a rectangle. So you may have to re-shoot. If so, either keep the camera back perfectly parallel to the building or use telephoto and leave plenty of room on the bottom of the frame for eventual adjustment in post processing. Good luck.
EOS 5D II, 40D, Sony R1, Olympus 1030, Canon S5-IS.
"Those who stand for nothing fall for anything." A. Hamilton
SwingBopper is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How to shoot a well exposed picture aymanmb Canon EOS Digital Cameras 9 26th of September 2007 (Wed) 08:44
A picture from Sunday's shoot gcobb People 11 13th of July 2007 (Fri) 09:08
Picture size question ( what to shoot in ) 90blackcrx General Photography Talk 17 15th of September 2006 (Fri) 14:02
How do you like this picture ? - Frontal Shoot by Requests L Digital People 28 11th of March 2006 (Sat) 13:22
how to shoot a picture in a glass frame??? ldivinag Canon EOS Digital Cameras 8 12th of December 2003 (Fri) 12:55
