Thread started 17 Nov 2007 (Saturday) 06:18
Prev/next
How do I calibrate monitor without a calibration tool?
bphillips330
ohio
Nov 17, 2007 06:18 |  #1
I am trying to figure out if there is a way to "profile" my monitor to get it as accurate as possible without one of those tools. It is not in my budget right now to purchase the device that you put on the monitor to calibrate it. I have done some editing and when i send it to costco it is hit and miss what I wanted.
I know that could be as costco is not a Pro Lab but i have had very good luck with snapshots. There are some pictures i would like to blow up, and if I am going to spend that money, i want it to be as close as possible.
How do some of the Pro labs (mpix, or whatever you recommend) do on color correcting.
last question. Which calibration device is the most recommended for the least amount of money. I know that is hard to do. But on a budget, what do people recommend.
Canon EOS 5D Mark III | Canon EF 24-105mm f/4L IS USM, EF 70-200mm f/2.8L IS USM |
Doogiekr
Doogiekr's Avatar
Spain, for the moment.
Nov 17, 2007 06:25 |  #2
I am by no means an expert, but I like my Huey Pro. It really helped me to get my colors to match from screen to printer, and its only $110 or so from B and H. Im still fighting some with black and white tones, but for colors it was a drastic help.
As far as calibrating without it, I am not sure. I found mine was pretty far off before I got the Huey, so obviously I did not do a good job without it.
~Doogie
"From the very core of our being, we simply desire contentment." - 14th Dalai Lama
PixelMagic
Racine, WI
Nov 17, 2007 07:40 |  #3
It depends on what type of monitor you have. If you have a CRT then you can use Adobe Gamma to do some very basic calibration. But since CRT are no longer being manufactured Adobe has stopped including Gamma in its most recent software packages so you'd need to get it from some other source.
If you have a LCD/TFT (flat panel) monitor then you need a calibration device since most TFT monitors only allow you to adjust brightness. Adobe Gamma does not work with LCD/TFT monitors.
bphillips330
ohio
Nov 17, 2007 08:44 |  #4
FedkaTheConvict wrote in post #4331935external link
I have a 20" crt display. Does the calibration device save some sort of profile that will load each time the computer loads up?
PixelMagic
Racine, WI
Nov 17, 2007 10:36 |  #5
Yes, the device will save a profile that is loaded by the operating system each time it boots up.
Now depending on the age of your monitor a calibration device might not work. Most CRT monitors have a useful life of 4-5 years and if its older it might be too out of spec to be corrected by calibration.
bphillips330
ohio
Nov 17, 2007 16:54 |  #6
So if my monitor is 5 years old or so, is it not worth me trying to calibrate it. I guess it might help alittle to try and get as close as possible.
snowyowl13
snowyowl13's Avatar
Prince Edward Island, Canada
Nov 18, 2007 07:35 |  #7
I wasn't aware of this. I suppose then that I should uninstall Adobe Gamma and just use Naturalcolour (Samsung's program supplied with the monitor) to calibrate my monitor. i can't really afford Spyder right now.
Dan
Canon 7D, Canon 50D, Canon 20D:18-55mm EF-S, 75-300mm EF, Sigma F4-5.6 DG Macro 70-300mm APO, Canon 100-400 mm F4.5-F5.6 L IS USM
http://snowyowl.smugmu​g.com/Natureexternal link
Lowner
"I'm the original idiot"
Lowner's Avatar
Salisbury, UK.
Nov 18, 2007 08:48 as a reply to snowyowl13's post |  #8
Most calibration devices sit neglected for long periods (in my case it's 3 weeks between calibrations). Why not ask around locally? Someone must have one you can borrow!
Thats probably one useful reason for joining a local photo group.
While the manufacturer would probably tell you that its not allowed according to the licence, they are never going to a) find out OR b) bother to do anything about it if they do.
Richard
Richard
http://rcb4344.zenfoli​o.comexternal link
snowyowl13
snowyowl13's Avatar
Nov 18, 2007 10:29 |  #9
Good thought. Well worth follow-up.
Dan
sandro9mm
sandro9mm's Avatar
Italy, Milan
Nov 18, 2007 11:41 |  #10
hi sorry for the off-topic, do laptop computers need calibration?
Photography Tipsexternal link - Learn photography now!
Famous photographersexternal link - Video Interviews, photos, biography
My gearexternal link
sandro9mm
sandro9mm's Avatar
Italy, Milan
Nov 18, 2007 11:46 |  #11
OP check this website: http://www.normankoren​.com ...neprints1A.html#Tes​tPrintexternal link
this is technique of calibrating without tools :) looks pretty good
tonylong
...winded
tonylong's Avatar
Gallery: 58 photos
Vancouver, WA USA
Nov 18, 2007 23:48 |  #12
To the OP,
I can feel for you! Before I got a "device" I went through this, because I was just setting up my new laptop and at the time was trying to do things on-the-fly.
Fortunately, I had both a good photo printer and a nearby store (Walgreens) that has a good printer, the Fuji Frontier, so: I made two or three rounds of: print a set of photos on my printer and print the same set at Walgreens, plus put them out on the Web, then make adjustments to my monitor, repeat the process...
Of course, the time and printing costs add up to asking yourself "why didn't I just get the dang calibration set?" but when you're just getting started you do what you must!
I printed pics out on my own printer as well as Walgreens 'cause I wanted to make sure that I was getting the same results from each as well as "good enough" on the Web.
Tony
Tony Long Photos on PBaseexternal link
Wildlife project pics hereexternal link, Biking Photog shoots hereexternal link, "Suburbia" project hereexternal link! Mount St. Helens, Mount Hood pics hereexternal link
René ­ Damkot
René Damkot's Avatar
enschede, netherlands
Nov 19, 2007 07:03 |  #13
sandro9mm wrote in post #4338856external link
Yes, off course.
Even calibrated, laptop screens will be marginal mostly.
Why Color Management.
Color Problems? Click here.
MySpaceexternal link
Get Colormanagedexternal link
Twitterexternal link
snowyowl13
snowyowl13's Avatar
Nov 19, 2007 08:03 |  #14
snowyowl13 wrote in post #4337851external link
Nobody answered this. Should I uninstall Adobe Gamma or does it matter?
Dan
PixelMagic
Racine, WI
Nov 19, 2007 08:54 |  #15
At mininum you should remove it from your Startup folder so it doesn't lauch by default at every reboot.
snowyowl13 wrote in post #4344333external link
3,984 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00468 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is marywilliams
811 guests, 319 members online
