Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 18th of November 2007 (Sun)   #1
widgetrich
Default comments on photo-please
I took in shade on manuel
www.photographybywidget.com
2- 20d, 70-200 f2.8IS. 50mm 1.4, tam 17-50 2.8, 580ex
widgetrich is offline   Reply With Quote
Old 18th of November 2007 (Sun)   #2
disneydork06
disneydork06's Avatar
Default Re: comments on photo-please
lighting looks good. shades are always good to shoot in. so are cloudy days. nice job.
Ryan
~AZ POTN Planned Activities
let me know how I can improve, cause we all know I need it : Flickr
myspace facebook The Greatest online forum known on Earth twitter500xp
follow me! in something^ you know you want to
disneydork06 is offline   Reply With Quote
Old 18th of November 2007 (Sun)   #3
Packhorse-4
Packhorse-4's Avatar
Nice pictures – If you have a chance you may want to take the pictures again from the ground level. You could use a little fill flash to remove the shadows under the ball cap. The little girl in the second picture is adorable in the soft lighting, but the young man looks a bit uncomfortable hunched over like that.
John
My Photos | My Gear
Packhorse-4 is offline   Reply With Quote
Old 18th of November 2007 (Sun)   #4
Robert_Lay
Robert_Lay's Avatar
Both shots are very nice.
Conratulations!
For future reverence, you may want to learn how to save your images for the forum so that the EXIF data is preserved. This allows the critics to see important information they might need in order to make constructive critiques.
Here are my suggestions for sizing images for posting in Critique Corner:
Size your image to not larger than 800 pixels in either direction (that's the guideline max.).
In Photoshop use Image->Image Size and enable Resampling (this will downsample your larger image to the new smaller size by throwing away some of the information, so save this smaller version under a different name from your original or you may lose your original).
Do not be confused by the dimensions in inches or the DPI value - those are irrelevant. The size of the image on a monitor depends only on the screen resolution of that monitor and the number of pixels in your image. For example, most monitors are set for screen resolution of 70 to 100 pixels per inch. That means that an 800 pixel image dimension will actually be from 8" to 11" on the monitor.
In order to stay under the 100kB limit on file size, use JPG compression quality low enough to get under 100kB by watching the file size change as you adjust the quality slider. It may be a little in error, so stay under 90 kB to be safe.
If the file size limit poses problems, you may want to host on another site and place a link to the image hosted elsewhere, but the 800 pixel maximum still applies.
A related issue is the EXIF data. In order to be sure that your EXIF data is available for the critique, do NOT use File->Save for Web. That process removes the EXIF data from the file. Following my suggestions above preserve the EXIF data in the file.
Bob
Quality of Light, Photo Tool ver 2.0
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
Robert_Lay is offline   Reply With Quote
Old 21st of November 2007 (Wed)   #5
dlw3
dlw3's Avatar
IMHO, bright cloudy days are the best days for photography.
XTi, 28-135, 70-300
dlw3 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Outdoor photo, comments please scobols People 7 4th of January 2007 (Thu) 10:28
Car photo. Comments, please. mcmustang Transportation 9 9th of August 2006 (Wed) 12:06
Anyway to view all photo comments in one place tmweb Version 1.0-1.5 discussion 4 12th of April 2005 (Tue) 15:33
First Photo Post, Comments Appreciated JaertX People 6 4th of February 2005 (Fri) 21:20
Visitor createable comments per photo onnastick Version 1.0-1.5 discussion 1 9th of July 2004 (Fri) 16:32
