Reply
Thread Tools Display Modes
Old 9th of June 2001 (Sat)   #1
rrhawks
Default Which LowePro case is best?
Wondering which LowePro bag is best fit for a G1+LensMate+collapsable rubber lenshood.
I live in Japan, where it's not so easy to try out all the bags, so any info would be great.
rrhawks is offline   Reply With Quote
Old 10th of June 2001 (Sun)   #2
pcmur
Default Re: Which LowePro case is best?
I have several LowePro cases and I suggest using the D-Res 40 AW to hold your camera with Lensmate, collapsable lens hood. It has room to spare with a partition if you choose to use a flash. The link is below:
http://www.lowepro.com/pages/byStyle/shoulder.htm
Good luck.
pcmur
pcmur is offline   Reply With Quote
Old 10th of June 2001 (Sun)   #3
pcmur
Just found that a new bag, the D-Res 25AW, would suit your needs if you don't want storage for a flash. If your click on 'camera matrix' you'll see that it names the G1 as compatible and it should also accommodate your Lensmate since it's tall and thin.
http://www.lowepro.com/pages/bySeries/dres.htm
pcmur
Old 13th of June 2001 (Wed)   #4
roncityofderby
Besides the D-Res 40 AW there is a newer version, the D-Res 220AW. It has a rear compartment, with divider. I just got one for my G1. It easily holds the camera w/ or w/o Lensmate, extra memory, filters, etc. There is not room for a flash or some auxilary lenses (the Canon 1.5X does not fit). However, I do not always take my tele lens with me, but need most everything else. I mainly wanted a bag that is compact and easy to use. Maybe someday as I keep adding equipment, I will get a larger bag.
roncityofderby is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Lowepro Lens case mikev63 Canon EF and EF-S Lenses 0 1st of February 2007 (Thu) 20:07
Lowepro Lens Case help please Sherpa Canon EF and EF-S Lenses 2 1st of August 2004 (Sun) 09:59
