#1 |
Background Throughout my younger years I spent a great deal of time climbing and mountaineering, and I was also actively involved in Search and Rescue in my home state of New Mexico. While I can lay no claim to having done anything particularly noteworthy (other than acquire numerous injuries and scars Serious hikers tend to have an interesting problem for carrying camera equipment over unimproved terrain. The LowePro and National Geographic products (and their numerous competitors) are well suited to most established trails and typical outdoors shooting. The problem becomes clear when you want to take 1-2 bodies and 4-5 lenses over unimproved terrain (i.e. no established trail) or through difficult/technical hikes. That leads to an even larger problem of how to carry that much equipment for a multi-day hike in a reasonably sized pack. To my eye, there is no ideal solution for the latter as of yet. In terms of a technical day pack for a reasonably flexible field kit, however, there have been a limited number of backpacks on the market. These are the packs that I’m mostly interested in, and I’ve spent the last year or so playing Goldilocks as I move through the catalog. Several weeks ago I reviewed the Mountain Smith Odyssey (link). While that was an excellent backpack, it was far too large for my needs (that pack is B.I.G). I sold the Odyssey and ordered a Mountainsmith Parallax (link) from B&H. Mountainsmith is one of the venerable backpacking companies; they manufacture products anywhere from casual hiking to hard-core technical alpine climbing. They do have a moderate selection of camera backpacks that tend to bridge the gap. Knowing full well that it’s not a complete description, I’ll say this: the LowePro kind of packs are designed by photographers for photographers. The Mountainsmith products are designed by hikers for hiking with cameras. There are numerous tradeoffs in proceeding from either paradigm—generally it’s a recurring compromise between stability and accessibility. All of that said, having owned several technical backpacks and too many daypacks to mention, my expectations of the Mountainsmith Parallax were this: rugged, intelligent, and rich with features. The Parallax did not disappoint me. Features External: 18" x 13" x 12" Internal: 16" x 11" x 8" Laptop Sleeve: 12.75” x 10.25” x 2.25” Volume: 1709 cu. in. (28 L) The Parallax is a well constructed from rip-stop nylon and has the double-stitched/edge rolled seams that you expect to find on a serious backpack. Like most camera backpacks (that I have used) access to the interior is via a full-zip panel under the shoulder straps. This panel is thickly padded, not only for comfort, but for protection of the camera gear as well. Inside the two translucent pouches that appear designed for small document storage—much to my dismay, a white/gray card wouldn’t fit in them gracefully without being substantially cut down. Curiously, both pouches are made from a water-resistant material and have rain guards on the zippers…as if I’d open the main compartment and expose the camera gear to the rain in order to get at the dry storage?? Lastly, the back panel seems rather flimsy while open, but when fully zipped the interior dividers removes any rigidness problems. There is a Velcro lined configurable interior compartment with padded dividers as you would typically expect. Two long L-shaped dividers create main storage on either side of the pack with a narrow channel in the center. Four dividers allow up to 6 bays to be created with two more smaller dividers for the center channel. The center channel is notable for its narrowness; it’ll hold a body or stack of filters/hoods, but it won't handle a lens gracefully. My 1D Mark III is a snug fit in the middle, but the outside compartments are large and easy to work with. Even the 82mm 16-35 2.8 L II is an easy fit, yet by some sort of black magic, narrower lenses like a 100 2.8 Macro do not seem prone to rattling around. The Mountainsmith website advertises the interior as being “fleece lined,” and while this is an interesting feature, it does cause some problems with the Velcro. The hook portion of the dividers doesn’t grab hold of the lining as aggressively as you would expect. At first this was extremely frustrating because it seemed to be a total failure of the Velcro materials, but some experimentation with dividers from other packs/cases revealed that it’s caused by the fleece/pile side of the system. You have to place the dividers deliberately, then spend a few seconds deliberately working them into position with a ‘wiggling’ motion before they fully attach. The fuzziness of the fleece will give a false attachment that promptly fails under any weight. If you work it in until the hooks can actually get to the pile, they perform as otherwise expected. The shoulder straps have an internal foam core and the typical S-shaped contour owing to an internal frame pack heritage. The cross-chest stabilizer appears to be rather low on the shoulder straps, adjusting somewhat beneath the sternum rather than across the top as I am used to seeing. At the bottom of either side is a typical mesh bottle pouch with an elastic drawstring closure. At the top and bottom of both sides is an adjustable attachment strap suitable for large tripods or a ridge rest. The left side had a rubberized carry handle, then another on top (both being obvious air-travel accessories but otherwise useful as well). Along the rear of the pack is a cleverly designed set of monopod straps that ends in an enclosed foot at the bottom. This is to prevent snagging a rigid pole on something that you can’t see behind you as well as to keep the monopod from perpetually sliding downward. When not in use, a simple system of snaps and pockets allows the whole system to tuck away so that they too aren’t snagging on something. Midway up the rear are three nylon gear loops for clipping on all manners of accessories. The very bottom of the pack has two more accessory straps that, more often than not, I’ve pressed into service for carrying a wet rainshell. Also on the rear of the bottom is where the rain fly tucks away when it’s not in active use. Be warned that while the rain fly is a nice idea (because a wet bag is a hassle), it can’t be used if there’s an external tripod or monopod because it is a very tight fit. ![]() The Rain Fly and Monopod holder. I have a hard time imagining a monopod that won’t fit in these straps. (click for larger) On the rear of the pack there are two half-zip compartments. The inner most compartment is for smallish laptops that will comfortably fit the 12.1” WXGA displays. There is enough room for a spare battery or AC adapter as well as a small number of discs and some other light accessories. Also in this compartment is a small mesh pouch that seems ideally sized for wallets and ID cards. The utility of this compartment is as questionable asthe wisdom of taking a laptop into the environment this kind of pack was designed for. It’s digital: don’t proof your shots in the wilderness, buy some more CF and take lots of pictures. That said, as this pack as been invading more and more of my non-wilderness uses, the laptop compartment has been seeing more uses. As you’ll discover in the conclusion, this pack does a lot more than just hiking, for which the laptop compartment becomes useful. However, much like my complaint with the Mountainsmith Odyssey, the laptop being positioned on the exterior of the rear puts it at risk of damage if the pack is suddenly dropped. Outside the laptop compartment is the second half-zip compartment, which unlike the rest of the pack, is free of pouches and straps and tuck away spaces. There is one small pouch at the top with a hook inside (clearly a key holder), but otherwise it is an unencumbered space. I have mostly used this space to stuff some layering fleece and a change of socks, not only because it’s convenient, but to offer some additional padding for the laptop when I have it. ![]() The laptop pocket and my fleece “stuff sack.” Note that the laptop is very exposed on the back. (click for larger) The last feature of note is a small pouch that attaches to the waist belts via a Velcro flap. There are two zip-close pockets with the smaller exterior pocket having CF-sized webbing and being ideally suited for loose cards or a full CF case. The top-zip interior pocket continues with the mesh CF retainers but will also hold three to four batteries (or one to two batteries from a 1-series). An alternate use is storing a filter (this is where I keep my CPL), or two filters if you’re willing to trade no-look access. Overall, you should be walking away with the impression of a backpack that’s well-designed and ruggedly constructed. Here’s a picture of all the stuff I typically cram into it. I’ll note that the 1D Mark III and 24-105 4L aren’t shown because they are taking the picture, but they sure do fit nicely in the indicated locations. A 1-series is probably a tad wide for that center channel, but I have no complaints. A 5D or smaller will fit perfectly. ![]() My typical internal configuration. Note that the 1D3 and 24-105 are not shown because they are in use for taking this epic shot. (click for larger)
The Mountainsmith Parallax is an excellent general purpose pack, but it excels for day-hiking, and even more so on rough terrain and unimproved trails. In my mind it wouldn’t take an extensive redesign effort to turn this into a very rugged technical pack because all the basic elements are there: stability and flexibility. The only down side is that this pack is for camera equipment only. The facilities to host anything else are sparse if present at all. If this were your only pack, the maximum sensible endurance would be just under a day unless you’re unusually proficient. That said, this pack is formidable in all other areas you would expect from a backpack. It is rugged to the point where you can expect it last several years, it’s size is just about right for people looking to carry a serious SLR kit without being the hulking cavern of the Odyssey, and it’s design is a model of simple efficiency. There’s a lot more to this pack than just hiking. At around $150 each, you can probably get close to this level of capability with other packs, but dollar for dollar, I doubt one can do better. I do have other bags that I keep around for specific purposes, such as LowePro Slingshots in case I’m looking for rapid-access, but this is the single most all-purpose backpack I have used so far. More and more I find myself using the Parallax not just for hiking, but for zoos, urban and architectural, as a travel bag in my car, and just about anything else. If I could have only one bag for all of my camera equipment, this would be it. In truth, my Pelican 1650 now a repository for cleaning equipment, gray cards, and retired filters; most of my lenses haven’t been out of the Parallax in weeks unless they were being used. I still haven’t found the pack I’m looking for, but this one is a definite keeper.
Canon 1D Mark III | 16-35 2.8L II | 24-105 4L IS | 50 1.2L | 70-200 2.8L IS| 100 2.8 MACRO| 300 4L IS | Gitzo 3530S | Arca Z-1dp http://www.canonfuse.net It's for my Canon. Last edited by Imaginos : 20th of November 2007 (Tue) at 06:25. Reason: Typoes |
| sponsored links |
#2 |
Very nice review!
I'm in the same boat as you. Haven't found the golden pack yet. |
#3 |
Great review. Thanks for posting
Mike
. My Gear & Wish List + Articles | My Flickr Galleries | My DT6.biz Website If at first you don't succeed, lose your temper and smash it to pieces. . |
| sponsored links |
#4 |
Another very fine review, and I keep hoping you will find just the right hybrid pack. I will steal your idea when that happens!
________________ Regards, MillCreek Snohomish County, Washington USA |
#5 |
[quote=Imaginos;4348360] Inside the two translucent pouches that appear designed for small document storage— Curiously, both pouches are made from a water-resistant material and have rain guards on the zippers…as if I’d open the main compartment and expose the camera gear to the rain in order to get at the dry storage??
![]() I found this review quite helpful and your overall impression is essentially the same as mine has been over the last 4 or so years (I bought the very first mountainsmith camera pack, which (I think) was the predecessor to this model. I've used the mountainsmith camera pack in a range of environments including multi-day expeditions into the Bolivian Amazon, deep Canyon treks in Peru with 100-400L IS , 70-200 2.8L IS , 17-40L Canon 20D, TONS of batteries, hard-drives, etc and I wanted to point out that I wholeheartedly agree with your review except for ONE point about the waterproof pocket liners and their placement. See enlarged, red text above. Notice the shot of the pack cover, specifically that it only covers the top, bottom, and backside of the pack from inclement (WET) weather. If you are in a torrential downfall and wearing a good outer shell, the water is going to bead down your back like a waterfall straight onto (and into) the unprotected back portion of the pack, exactly where the lid of this pack opens up and is most vulnterable. This is why the pack has the waterproof lined pockets (in my opinion). Without these, water will seep straight onto your gear and defeat the whole purpose of the rain liner for this pack. Also, think about situations where there isn't necessarily rain and you don't have this plastic lining. Think about a blistering hot summer day, you've just reached the summit of your favorite mountain, open the zippered lid and realize all of your protected gear is DRENCHED in your sweat that seeped through the unprotected backside. Another reason for the waterproof lining! In my opinion, the Mountainsmith designers were ingenious to put this lining here. Great review, by the way! KUDOS.
"Dream it. Plan it. Do it."
- National Geographic ...with a 300D and a kit lens 85 1.2L II, 70-200 2.8L IS, 100-400L IS, 17-40L, 50 1.4, 85 1.8, Elinchrom, Lastolite, Photoflex, Think Tank, Member: Canon Professional Services, National Association of Photoshop Professionals Last edited by SteveNC : 23rd of July 2008 (Wed) at 21:44. |
#6 |
-POTN's Three legged Support-
Excellent review! Great job!
| Gear List | Flickr | My Reviews | For Sale: Markins Q3T Traveler Ballhead w/ New Markins Clamp CLICK HERE |
#7 |
just purchased this pack based on your review. I am stoked to get this pack!! Thanks!
Fat, Drunk, and Stupid is no way to go through life son. (Jonesin for 'L') |
#8 |
Where did you end up getting it from?
- National Geographic ...with a 300D and a kit lens 85 1.2L II, 70-200 2.8L IS, 100-400L IS, 17-40L, 50 1.4, 85 1.8, Elinchrom, Lastolite, Photoflex, Think Tank, Member: Canon Professional Services, National Association of Photoshop Professionals |
#9 |
Well written review.. if I didn't already have an F-stop Satori on order I might look at something from the Mountainsmith line.
#10 |
Only amateurs use backpacks.
IT'S KODACHROME TIME! Gear? Ask if you're interested. My 'portfolio' for randoms, Railway shots Facebook page |
#12 |
B&H Photo $136.00
#13 |
Trainboy, you must have 2 or three sherpas to carry all that gear
#14 | |
-twitch-
Your....holga. Quote:
For anyone who was wondering, I'm citing the most reliable of internet sources, Ken Rockwell.
| Thread Tools | |
| Display Modes | |
| Mountainsmith Odyssey backpack review | Imaginos | Accessories & Storage | 12 | 7th of February 2008 (Thu) 22:42 |
| Mountainsmith Sideline Bag Review | Rick_R | Accessories & Storage | 5 | 12th of October 2007 (Fri) 09:16 |
| MountainSmith Odyssey or Parallax | Jubilee32 | Accessories & Storage | 0 | 30th of June 2006 (Fri) 21:25 |
