Thread started 24 Nov 2007 (Saturday) 15:10
camera keeps saying BUSY
polkadot87
Nov 24, 2007 15:10 |  #1
I'm not sure which category this problem falls under so I'll just explain it here.
I use the Canon xti 400D with a Tamron 17-50 lens and whenever I use it indoors, which I usually do, I always have the problem of it not taking pictures continuously. I take one picture with it, using the flash, and then once I press the shutter button again, it won't take the picture and will say BUSY on the screen. After about 10 seconds it will take another one. This is extremely annoying and happens each time. What is wrong?
I was thinking maybe its loading the flash and that's why it takes so long to take another picture? Does this mean I should get an external flash? Also I should note that if I take one picture then change the settings right after that, I can take another picture right away.
Any help or suggestions would be really appreciated thank you so much! If I didn't explain something clear enough or if you need more info please let me know.
my general photography...
www.violettte.devianta​rt.com (external link)
my hamster photography...
http://polkadots87.liv​ejournal.com (external link)
S.Horton
I'm having size issues, does this get worse with age?
Nov 24, 2007 15:12 |  #2
Is your CF card slow (old), damaged or very nearly full?
Sam - TF Says Ishmael
:cool:
gofer
Nov 24, 2007 15:14 as a reply to  @ S.Horton's post |  #3
Yup, it's the flash re-charging
Steve.
number ­ six
"After 40 years still not housebroken, I still piddle on the carpet"
Nov 24, 2007 15:19 |  #4
An external flash will recharge faster, but unless you get one with an external battery pack there will still be a delay required between repeat shots.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
I do not piddle on the carpet!
gasrocks
Nov 24, 2007 15:44 |  #5
Try it w/o the flash and see how fast it goes.
dave ­ kadolph
"Fix the cigarette lighter"
Location: West Michigan--166.33 miles to the Cook County courthouse
Nov 24, 2007 16:00 as a reply to  @ gasrocks's post |  #6
Just took some famly photos at Thanksgiving with a 430 EX and that drops recycle time on an XTI to around 1/2 to 1 second with fully charged batteries.
Hope this helps
Middle age is when you can finally afford the things that a young man could truly enjoy.
Tools of the trade
polkadot87
Nov 24, 2007 16:27 as a reply to  @ dave kadolph's post |  #7
Thank you for the responses!
First of all, my card isn't near full when this happens and I thought I got a pretty good card so it can't be that. I tried taking pics without the flash and it works continuously. When I turn the flash on, it does let me take a bunch of shots in a row at first but after a while it slows down and always says Busy. So now that I know its the flash, there's really no way around it is there as I see getting an external just doesn't help much. oh well =(
gjl711
They have pills for that now you know.
Nov 24, 2007 16:53 |  #8
polkadot87 wrote in post #4377234 (external link)
Check out page 54 of the manual. Both the "busy" and the flash stopping after several shots in a row behavior are described. Simply, it takes time to recharge and busy is displayed, and if many pics are taken in a row the flash stops to keep it from overheating.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
polkadot87
Nov 24, 2007 16:59 as a reply to  @ gjl711's post |  #9
That really sucks.. I wonder if its the same with all cameras like Nikons and all?
Jon
Joined Jun 2004
Nov 24, 2007 17:02 |  #10
If it isn't it should be. As described, the flash needs to recharge; if a built-in flash firing at full power recharges quickly, the camera's devoting too much of its battery and internals to the flash; plus you run increased risk of overheating the flash from repeated rapid-fire shots.
Jon
Cocker Spaniels
polkadot87
Nov 24, 2007 17:11 as a reply to  @ Jon's post |  #11
hmm... I'll start experimenting more without the flash. See what I can do with just using the artificial lights in my room... the more watts the better!
xarqi
Nov 24, 2007 17:51 |  #12
Hmmmmm.
Using Av mode? Getting fuzzy backgrounds in your pictures? The delay could be the time it is taking the camera to expose the background in the dim available light - it works this way with flash in Av mode unless you override it (using some nasty, awkward, counterintuitive custom function buried in a menu somewhere).
Maybe not, but worth mentioning, I thought.
polkadot87
Nov 24, 2007 17:58 as a reply to  @ xarqi's post |  #13
I wasn't in Av mode but I do get fuzzy backgrounds and thats actually something I want since I'm doing portraits. I have 6 light bulbs in my room going, it almost looks like the sun in there!
Hermeto
Nov 24, 2007 18:10 |  #14
How about the Drive mode?
Make sure that you didn’t accidentally put it to Self-timer..
xarqi
Nov 24, 2007 18:12 |  #15
polkadot87 wrote in post #4377608 (external link)
Cool. Scratch one shaky theory then. Flash recharge time and cool off look to be the cause then, and an external flash the solution, at least partly.
22,874 views & 0 likes for this thread
version 2.0 /
Latest registered member is insurfr
698 guests, 379 members online
