#1 |
Anybody know a good Inexpensive underwater housing for a canon XTi? Not going deep but just something to keep my camera dry underwater.
Thanks, Greatshot |
| sponsored links |
#2 |
Disposable underwater P&S. I've read many a horror story about "airtight, guaranteed" housings that did not deliver. I guess the question you have to make sure about is: if it fails and the camera is damaged, how many tears will you cry
#3 |
yeah, i don't think i'd go inexpensive with something like an underwater housing....
| sponsored links |
#4 |
I've heard of some success from products from ewa-marine (http://www.ewamarine.com/index.php?id=49). You should check scubaboard.com or wetpixel.com to get some opinions though.
It sounds like you aren't diving so it should be fine as long as you are thorough with checking for leaks. On our recent trip to Australia's Great Barrier Reef, the divemaster suggested dunking it in a tub of water for an initial 3-second check, and a subsequent 30-second check. We used an Ikelite housing for the first time which was effective, but definitely not inexpensive. Edit: Hmm... just did a quick search. Madweasel (http://photography-on-the.net/forum/...d.php?t=385564) doesn't like the ewa product, but another poster on scubaboard (http://www.scubaboard.com/forums/arc...p/t-84945.html) likes it very much. Good luck!
Our Japan photos: www.LouwPhotography.com/Asia/Japan Our travel photos: www.LouwPhotography.com Last edited by louwphotography : 26th of November 2007 (Mon) at 23:10. |
#5 | |
I *strongly* discourage anyone from taking a DSLR underwater in a baggie. I don't care if the EWAs are "designed" for this - there are too many failures and flooded cameras. If you do opt to go this route, be sure you're insured for water damage. For a full diving rig, the least expensive decent quality would be the Ikelite housings.
-Amber Underwater Photographer (Topside Photography Poseur) Canon 60D | Canon 400D | Canon 60 f2.8 | Sigma 10-20 | Tokina 10-17 FE | Sigma 18-200 DC OS | Sigma 150-500 DC OS | Canon 70-200 f2.8 IS MkII | Canon 17-55 f2.8 IS | Seatool XTi Underwater Housing | Seatool 60mm Port | Seatool Dome Port | Inon Strobes | 67mm macro lenses (2), Woody's diopter |
#6 |
Canon P&S with Canon housing
I have used two and they both worked fine for what I wanted to do.
5D & G15
EF 70-200 f/2.8L IS, EF 24-70 f/2.8L, EF 35-135 USM f/4 & EF 50 f/1.8, Sigma 150-500 580EX, Kenko 2X Pro DG TC Retired: G9, SD800IS, S45, Elan, AE1-Program |
#7 |
#8 |
There are 2 ways to do it, one is cheap and may lead you to end up shopping for another camera, the other is expensive and may also lead you to shop for another camera, but not because the first method caused your camera to drown. Unless you want to spend well over $1000 then buy a P & S and the inexpensive housing for it.
http://photography-on-the.net/forum/...d.php?t=409089
A skill is developed through constant practice with a passion to improve, not bought. Cozumel travel & dive photos www.picasaweb.google.com/CozumelTimeCapsules Radio Control Event albums www.picasaweb.google.com/tcprcphotos |
#9 | |
| Thread Tools | |
| Display Modes | |
| Underwater housings | pgo | Accessories & Storage | 3 | 7th of May 2007 (Mon) 14:03 |
| Underwater Housings for 20D | bryan k | Accessories & Storage | 34 | 11th of January 2007 (Thu) 03:50 |
| Underwater Housings? | musclepump | Accessories & Storage | 3 | 18th of June 2006 (Sun) 19:09 |
| Underwater Housings | northbounddesign | Accessories & Storage | 1 | 24th of May 2006 (Wed) 20:23 |
| Underwater housings for Canon 20D | Torcidas | Canon EOS Digital Cameras | 1 | 25th of October 2004 (Mon) 15:35 |
