Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Wildlife Talk
Reply
Thread Tools Display Modes
Old 28th of November 2007 (Wed)   #1
chauncey
chauncey's Avatar
Default Soft wildlife with 70-200ISL
You guys talked me out of upgrading my xti so please help me with my 70-200 ISL lens.
I used this lens, at all ranges, with IS on, all summer at high altitudes (no haze) in CO. and I got some really good landscapes, handheld panoramas and handheld HDR. But...
When I got the occasional shot at wildlife, the images came out softer that what I like. I thought at first it was nothing more than "buck fever" and I started paying more attention and using "sniper" tactics in locking the camera to my body. Helped only a little. This occured throughout the range of f-stops and magnification. I shoot mostly in A-V or T-V modes.
Could it be that I wasn't waiting long enough for the IS and AF to "kick in"? How long does it take? Failing that, what else could it be?
chauncey is offline   Reply With Quote
Old 28th of November 2007 (Wed)   #2
Mark_Cohran
Moderator
Mark_Cohran's Avatar
Default Re: Soft wildlife with 70-200ISL
The IS and AF kick in on this lens in under a second (usually and in good light), so unless you were really quickly snapping away, I doubt that's a problem. However, if the wildlife is moving and you're trying to shoot with a low shutter speed (using the IS to hold the lens optics steady), you can still get soft photos. IS helps with camera/lens movement (shake), not subject movement.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Thirty-five years of shooting and still learning.
My G&N Blog (NSFW)- My Complete Gear List - Mac-Photo Website - My Tumblr Site (NSFW)
G&N FORUM EARLY ACCESS & IMAGE POSTING RULES
Mark_Cohran is offline   Reply With Quote
Old 28th of November 2007 (Wed)   #3
viperx27
User is banned from forums
an example pic would really help. mine works great for wildlife, though a longer len is always nice too
viperx27 is offline   Reply With Quote
Old 2nd of March 2009 (Mon)   #4
Tom Reichner
Tom Reichner's Avatar
Chauncey, Did you ever resolve this issue?
Wildlife photographed in the wild.
http://www.tomreichner.com/Wildlife
“There are no bad pictures; that's just how your face looks sometimes.”
― Abraham Lincoln
Tom Reichner is offline   Reply With Quote
Old 23rd of March 2009 (Mon)   #5
chauncey
chauncey's Avatar
Tom, you got me to thinking.
As hindsight, I don't believe the problem was in the lens, I think it was a body/user based problem.
That was about the time that I started to upgrade cameras, to the 5D>Ds2>Ds3.
I never took a quality image with the xti when extreme AF ability was necessary.
There were lots of decent landscapes, but none for that crispy critter shot.
Gear...Ds Mk III, 16-35 f/2.8, 24-105 f/4.0, 70-200 f/4 and f/2.8, 300 f/2.8, and assorted other stuff.
Old 23rd of March 2009 (Mon)   #6
Tom Reichner
Chauncey,
I'm glad you've figured this out. I just can't believe that people on this forum talked you out of upgrading your digitatl Rebel. Bad advice. I't great to see that you now have a body with a sensor as good as the 5D. You should see dramatic improvements in your wildlife images.
I'd love to see some of your recent attempts with the 5D.
Tom
― Abraham Lincoln
Old 23rd of March 2009 (Mon)   #7
chauncey
chauncey's Avatar
You misunderstood my response, I use a Ds3 now. 'Tis a superlative body.
See my signature.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Soft or Not: Do some lenses have higher percentages of soft copies than others? SunTsu Canon EF and EF-S Lenses 4 31st of October 2007 (Wed) 01:37
Soft light - Soft image PhotoAlien People 9 21st of July 2006 (Fri) 08:05
PS: Soft Flower, Soft Edge. My Feminine Side. MattyB Still Life, B/W & Experimental 8 29th of September 2005 (Thu) 11:45
