Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Sports
Reply
Thread Tools Display Modes
Old 2nd of December 2007 (Sun)   #1
Semmonka
Semmonka's Avatar
Default First Ice Hockey pics
Hi everybody!
Ive been reading this forum for some months and decided to post some of my pictures.
I took these pics few weeks ago and had no idea how difficult ice hockey photography can be. I know few pics are little bit OOF so I have to be more
carefull next time. These were taken with 30D + 70-200 IS.
I ran files through neat image and did some color adjustment. I know PP is one more area I need to study
Anyways, C&C are more than welcome
Cheers,
Vesa
1.
2.
3.
4.
Semmonka is offline   Reply With Quote
Old 2nd of December 2007 (Sun)   #2
LinkPhotography
Default Re: First Ice Hockey pics
good first attempt....try a custom white balance next time
LinkPhotography is offline   Reply With Quote
Old 2nd of December 2007 (Sun)   #3
Aaagogo
Aaagogo's Avatar
i like the stop actions but is it me or are the whites blown out?
Your 1st 10,000 images are your worst
One photo out of focus is a mistake, ten photo out of focus are an experimentation, one hundred photo out of focus are a style
Aaagogo is offline   Reply With Quote
Old 2nd of December 2007 (Sun)   #4
Semmonka
Semmonka's Avatar
Thanks for the comments.
I used custom white balance which I took of the ice. I did some corrections to the images so there should not be too much blown whites anymore. I really need to learn proper way to do color adjustment so I dont ruin the images
Old 2nd of December 2007 (Sun)   #5
900spg
You timed the action really well which is the most important part. The rest will come with practice. A good first attempt as the rink appears to be really dark.
Canon 5D MkIII | 7D | 40D | 350D
580EX II - 430EX II - BG-E3
50mm 1.8 II | 85mm 1:1.8 | 100mm 1:2.8L | Tokina 12-24 f4 | 24-70mm 2.8L | 70-200mm 2.8L | 100-400 4.5-5.6L | Kenko Extension Tubes and 1.4x Teleconverter
www.jpsphotos.net flickr TrekLens
900spg is offline   Reply With Quote
Old 2nd of December 2007 (Sun)   #6
DavidEB
DavidEB's Avatar
very good shots, especially for a first go.
your rink has the common problem of inconsistent lighting, different colors in different spots, likely also "cycling" or changing colors over the cycle of AC current. look around the rink for the most representative spot, and shoot a longer time exposure for your CWB shot (an exact multiple of one whole AC cycle, in europe 1/50 or 1/25 sec).
in photoshop there are a lot of ways to adjust. here's one that I use... hope this helps
David
my stuff - my gallery - go Rats!
DavidEB is offline   Reply With Quote
Old 3rd of December 2007 (Mon)   #7
Semmonka
Semmonka's Avatar
Thanks for the info David. The rink is very dark indeed. I just managed to get 1/500 speed with ISO 1600. Some areas are more dark than the others so it makes photography a bit tricky. Your theory about AC cycle is very interesting. We have 50 Hz system so taking CWB picture with shutter speed faster than 1/25 may cause some problems, as the cycle peak to peak time is 20ms. Have to try different speeds and check the pics if there is any difference
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Shooting Team Pics for Ice Hockey Alan Dye Sports 10 28th of January 2010 (Thu) 14:55
Lighting a Ice Hockey team on the Ice? serviceover Small Flash and Studio Lighting 6 9th of November 2007 (Fri) 15:39
How to get decent pics in an ice hockey rink StorageLady Canon EOS Digital Cameras 8 28th of September 2007 (Fri) 09:05
Boxing on Ice... Coventry Blaze v Cardiff Devils Ice Hockey scott wiggins Sports 10 18th of March 2007 (Sun) 07:33
First Ice Hockey Pics w/new lens Hockeyphoto Sports 5 12th of October 2006 (Thu) 23:21
