Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 2nd of December 2007 (Sun)   #1
Curtis N
Master Flasher
Curtis N's Avatar
Default Using gels to create colored backgrounds
Since I do most of my portrait shoots on location, I wanted a way to create different background colors with minimal gear and expense. I read a little about using gels to create colored backgrounds so I gave it a try today.
Anyone with any suggestions or tips is welcome to chime in.
I started with "thunder grey" seamless paper which is a very dark grey. Using a dark background allows blasting it with plenty of gelled light to overcome the spill from the main & fill lights. If you use a white or light grey background, it will just be blown out when you add any significant amount of light to it.
I mounted a 580EX II Speedlite behind the subject about waist high, four feet in front of the background, and aimed it at the gray seamless, angling it up to her head height.
I used gels from the Roscolux swatchbook that you can get for next to nothing. These swatchbooks have hundreds of gels to choose from. I picked the darkest gels in their respective colors to create the most saturated light possible. The gels nest under the tab for the wide panel on the 580EX II and will stay in place as long as they don't get bumped. Those with other brands of flash unit may need to find alternative mounting methods. Note: I would not recommend sandwiching the gel between the lens and the flip-down wide panel on the flash. The gels get quite hot and I would not want to risk damaging the flash from the heat buildup.
For today's shots I adjusted the power in order to meter the background more-or-less equal to my camera aperture. I was able to get into the f/9 - f/11 range with the 580EX II at 1/2 power.
Here's the Midnight Grey backdrop with no background light.
This is with the background light but no gel.
Gelled flash - #2002 "Storaro Orange"
#2005 "Storaro Cyan"
#39 "Skelton Exotic Sangria"
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Old 2nd of December 2007 (Sun)   #2
viperx27
User is banned from forums
Default Re: Using gels to create colored backgrounds
looks good. here's an old thread on using them
http://photography-on-the.net/forum/...&highlight=EDU
viperx27 is offline   Reply With Quote
Old 3rd of December 2007 (Mon)   #3
Borderfox
Borderfox's Avatar
Very handy, I am getting a Lastolite HiLite and these would be great when not using high key..
Borderfox is offline   Reply With Quote
Old 3rd of December 2007 (Mon)   #4
mmahoney
mmahoney's Avatar
Nice light Curtis .. and I thought you only talked about flashes
| Canon DSLR's & Lenses |
mmahoney is offline   Reply With Quote
Old 3rd of December 2007 (Mon)   #5
whiskaz
whiskaz's Avatar
Very nice!! It looks great against the grey seamless. I use black and it works well too.
Jeremy | Gear List | EyeDigress - A Photoblog | blinkphotography.net
"This aggression will not stand, man."
whiskaz is offline   Reply With Quote
Old 3rd of December 2007 (Mon)   #6
cdifoto
Don't get pissy with me
cdifoto's Avatar
He talks about flashes and sticking stuff to 'em. But that's about it.
I got the same swatch book a few days ago, mainly for the tungsten gel. I'll definitely be playing with other colors though.
cdifoto is offline   Reply With Quote
Old 3rd of December 2007 (Mon)   #7
Gatorboy
Gatorboy's Avatar
You might want to use some black tape over the small hole in the gel. That white light coming through can contaminate your gelled color a bit.
Dave Hoffmann
My Blog
Gatorboy is offline   Reply With Quote
Old 3rd of December 2007 (Mon)   #8
Curtis N
Master Flasher
Curtis N's Avatar
The gel gets hot. The tape would melt, or at least the adhesive on the tape would.
Once, in my younger days, I put two small strips of vinyl electrical tape on a flash to reduce its output. The flash was being used behind the subject as a background light. While the rising smoke did create a somewhat cool effect, the flash unit will never be the same.
That little hole represents a small enough portion of the total area that its effect is negligible.
Old 8th of December 2007 (Sat)   #9
azpix
azpix's Avatar
I was actually going to ask about this tonight. I plan a getting the Roscolux swatchbook but bh is quoting up to 14 days. In meantime, I went michael's and tried to find some "gel type" material. No luck. I did get some real thin colored paper that I'm going to try. Anyone know where to get gels locally? i've tried a couple of camera shops and they don't stock it.
Curtis,
how are you attaching the swatches to the flash?
Gear- 7d, 24-105L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20, Sigma 24mm 1.8 and a canon G10.
azpix is offline   Reply With Quote
Old 8th of December 2007 (Sat)   #10
Curtis N
Master Flasher
Curtis N's Avatar
For the gels I use "out in the field", I use velcro on the ends. Just adhesive-backed velcro tape about 3/4" wide. I stick it to about 1/4" of each end of the gel and cover the rest of the adhesive with tape. There's a picture in this thread.
Side note: All my flash units have a strip of Velcro wrapped around the head. It's great for Lumiquest flash modifiers, home-made bounce cards, gels, flags or anything else I want to stick to the flash. I put the loop side on the flash and the hook side goes on everything else.
But for coloring the background there's too many possible colors to go the velcro route with all of them. I found that as long as the flash was angled upwards I could just set the gel on the flash lens and stick it under the little pull tab on the wide panel of the 580EX II. It'll stay there as long as you don't bump it too hard.
Old 8th of December 2007 (Sat)   #11
azpix
azpix's Avatar
Anyone needing the Roscolux swatchbook that curtis mentions can get them here.
Might be faster than BH and there is no shipping charge.
EDIT: they are not faster than B & H.
Old 8th of December 2007 (Sat)   #12
Marionne
Yay! I just signed up for one! Thanks!
Marionne is offline   Reply With Quote
Old 8th of December 2007 (Sat)   #13
mc4fun
mc4fun's Avatar
Great info, thanks,,,,
BTW, Curtis, all the info you provide, how may hours are in your day,,,,,seems like more than 24 LOL
Stefan
Rebel XTi, 430EX, OptekaFL50AF-c, Quataray 70-300 1:4 5.6 LD
I am finding out I ask a lot of questions Then I think" I do not look forward to the day I am not able to ask them" So for now "I will ask!"
mc4fun is offline   Reply With Quote
Old 8th of December 2007 (Sat)   #14
TMR Design
TMR Design's Avatar
I don't think you can find a better value for a penny out there.
Lover of manual focus Zeiss glass.
Gear List & Feedback
Please call me Robert or Rob, not TMR
My Online Portfolio
TMR Design is online now   Reply With Quote
Old 8th of December 2007 (Sat)   #15
Blackey Cole
I actually ave been getting the Vivitar filter kits since 90% of te time I use a Vivtar 285 strobe and it will normanlly be a bG light. Now I have three of the I will pick up a fourt and that will give me four 285 to work with the Quantary QTB-9500a that had switchable bases that decide how it will work. I have three of them 1for ETTL use I have the brack/cable setup for it and I just got a Canon Off Camera Cord 2 for my Stroboframe Pro L Bracket be I gotit I would use it as a remote with the remote base and trigger it with one of several remote devices depending on which other flash was being used. My biggest grip is that the auto on it is fair limited but the good thing sis when I use the Stofen and need a direct light it has one built in so it has to strobes in one and the second is switchable.
I going out on a limb and say you watch the video at the top of this forumn and saw how he took the Thunder Grey bg and make it several colors by rcposure and gels. So you how it works. SO I think you are on your way to perfecting it Curtis.
Blackey Cole is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
colored gels on 285HV relsah Small Flash and Studio Lighting 5 25th of April 2007 (Wed) 14:31
Question about Gels (non-colored) TMR Design Small Flash and Studio Lighting 5 1st of April 2007 (Sun) 15:16
Colored Gels For 550EX? Scottes Small Flash and Studio Lighting 7 14th of July 2005 (Thu) 18:59
Using Colored Gels minatophase3 General Photography Talk 3 10th of November 2004 (Wed) 12:39
Colored backgrounds or colored lighting? dphoto Small Flash and Studio Lighting 6 30th of August 2004 (Mon) 17:24
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
