| sponsored links |
Thread Tools | Display Modes |
#1 |
What would you suggest me? shoot at higher ISO and then try to reduce noise OR shoot at low ISO (let it be under exposed @ maximum -1) then adjust the levels at PS
I dont know, I never had questions in my mind before. Its just keeping on coming today. I have already posted 5 questions in different section today. Thanks
#include <iostream> int main() { std::cout << "POTN is the best." << std::endl; return 0; } |
| sponsored links |
#2 |
Unfortunately I dont know all the true technical aspects of it, but I would say expose properly at a higher ISO. If you underexpose, theres less data to work with since most of the picture resides in the left-hand of the histogram.
With programs as good as they are anymore at eliminating noise, I wouldnt worry about it too much. Just my two cents.
#3 |
Moderator
Some Volley Ball Tournament Tests **56K Warning!**
Noise: it is better to raise ISO than to underexpose
FrankC - 20D, RAW, Manual everything... Classic Carz, Racing, Air Show, Flowers. www.FrankCizek.com Find the light... A few Car Lighting Tips, and MOVE YOUR FEET! Have you thought about making your own book? // Need an exposure crutch? |
| sponsored links |
#4 |
Noise increases dramatically in underexposed photos, even at lower ISOs sometimes. The high ISO settings do much better.
Shawn McHorse - AustinRocky.org / RockyMusic.org Bodies: 5D Mark III, Rebel XTi, Elan 7NE Compact: S100 Flashes: 580EX II, 430EX Lenses: 16-35mm f/2.8L II, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 50mm f/1.4, 85mm f/1.8 Bags: Stealth Reporter D400AW, Toploader 75AW, Modulus Belt System |
#5 |
What do you call "high ISO"? To me it's over 640; to some it's over 100.
"Be yourself - everyone else is taken". Oscar Wilde |
#6 |
Master Flasher
Pretty much everyone who has tried it both ways comes to the conclusion that it's better to shoot at high ISO (even 3200) than to choose a lower ISO, underexpose and fix in post.
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
#7 |
Any thing that you would like to consider. If you think this needs a 1/125 + f5.6 ISO 200 but you decided to go for 1/125+ f5.6 +ISO 100 + -0.75 thinking that -0.75 can be adjusted in PS. Which one would you prefer first one with high ISO or the second one with low ISO+PP, Cheers.
#8 | |
Choice Two= bye bye to 50% of the data in your image. Think I'd go with Choice One http://www.luminous-landscape.com/tu...se-right.shtml
OMG I saw a nipple, my eye's are bleeding! Visit http://www.mcaryphoto.net (Nudity) warning most images found on this website were shot with cheap plastic lens (50mm 1.4 85 1.8 and 35 2.0) |
#9 |
Tis a fine line but...If your worried about noise I have found sometimes you can even up the Iso and overexpose{or correctly compensate} and then bring it back down in PP with decent results.(be sure to chimp to prevent clipping)
My test's are inconclusive but noise is definatly a function of exposure as well as ISO! A properly exposed high iso image is not that noisy... My camera tends to underexpose at high ISO, I feel this is what causes a large portion of the noise. Let me add this...I can think of no good reason to up the iso and then do in camera exposere compensation as this just brings your shutter speed back to what the lower iso was! However it is interesting to see how much this reduces noise at higher ISO And to the OP...Higher iso +proper exposure IMO is better than your other option!
7D, Sigma 8-16, 17-55, 70-200 2.8 IS, 580ExII, ........Searching for Talent & Skill; Will settle for Blind Luck! Last edited by neumanns : 4th of December 2007 (Tue) at 09:38. Reason: Let me add... |
#10 |
It doesn't make sense to use a lower ISO and adjust in post processing unless you have to (e.g. my 350D has a maximum ISO of 1600, but I can get similar results to a 20D at 3200 by underexposing by 1-stop at 1600 and then adjusting +1 in post with the raw file).
Bottom line is that the amplifier of the sensor will maintain more information than if you shoot raw and adjust in post processing. However, once you hit unity gain (1 data number represents 1 electron), there is no effective difference between post processing (with raw) and in camera amplification. For both the 20D and 350D this is below ISO 1600 according to http://www.clarkvision.com. e-k |
#11 |
slightly jealous
I agree. Shoot higher. The ISO amplification is done on the sensor in most Canon DSLR's, so (AFAIK) it can be done better than simply amplifying the output. I have heard reports that the 20D+'s ISO 3200 is simply ISO 1600 amplfified in software however - people have done tests and found little difference between the two.
At ISO 1600 and under though, I would always go up to the next ISO. Surely everyone here has taken an underexposed photo at ISO 100 or 200, and suddenly it looks like it was taken at ISO 1600.
Leo 20D|Tamron 17-50 2.8|Sigma 70-300mm APO DG Macro|50 1.8|Sigma EF-500 DG Super| My Photo Gallery *New* | My Gear List | Backup Photos Easily with Robocopy |
| Thread Tools | |
| Display Modes | |
| for those of you wondering about MarkIII low light,high ISO abilities | jlbrach | Canon EOS Digital Cameras | 29 | 29th of July 2007 (Sun) 23:27 |
| Low light, high ISO with a 30D | col4bin | Canon EOS Digital Cameras | 28 | 8th of May 2007 (Tue) 15:48 |
| high iso and low shutter football | KIPAX | Sports | 6 | 4th of October 2006 (Wed) 14:18 |
| 30D High vs Low ISO comparison | EOSAddict | Canon EOS Digital Cameras | 5 | 22nd of March 2006 (Wed) 16:53 |
| Something a little different; High ISO, Low light | Asmodeus | People | 5 | 27th of December 2005 (Tue) 10:49 |
