#1 |
Quick note:
This procedure is similar on the Canon EOS 40D, Canon EOS 50D and Canon EOS 5D, and I am sure it covers all the other bodies that have user-changeable focusing screen (I've only personally done it on the 40D, 50D and 5D) Alright, since I wanted to swap my 40D focusing screen to the Ef-D with grid lines I've been looking for a DIY to see how easy it really was, but I couldn't find one, so I decided to make one to help out whoever else is considering it. This is a guide only, you should still read the instructions that come with the focusing screen you are using, also do this at your own risk, I am not responsible for any damage to you or your camera equipment. Alright first of all, bring your 40D and your newly purchased focusing screen (in that case for me the Ef-D screen): ![]() Then open the box for the focusing screen, this is what you should have, instructions and the focusing screen and tool: ![]() Now lay your 40D down and take the body cap off, try doing that in a non dusty area. You will be looking for the little locking clip that holds the focusing screen holder up, I circled it in red in the picture: ![]() Put the provided tool under the clip: ![]() and pull up on it, the focusing screen holder will come down: ![]() Then using the same tool, press on the blue part of the handle top open the clip and clip it on the little tab that sticks out from the focusing screen: ![]() Lift the focusing screen up and slid it out: ![]() Then set the focusing screen you just removed in that little area made for it in the box: ![]() Last edited by 71sbeetle : 20th of March 2009 (Fri) at 13:16. |
| sponsored links |
#2 |
Now pick up the new focusing screen:
![]() Put it in the focusing screen holder, basically reverse steps from removing the other one: ![]() And push the focusing screen holder back up until it clicks: ![]() Replace the body cap on the camera, turn the camera ON, go to Menu, Custom Functions IV: Operation/Others, then go to C.Fn 5 and choose the appropriate Focusing Screen (0: Ef-A, 1: Ef-D, 2: Ef-S) That's it, you're done ! Go out and enjoy your new focusing screen ! Sorry if some of the pics are blurry, I am not used to my wife's Canon SD870IS yet The whole thing including opening the box, taking my 40D out the Pelican case and taking pictures of the whole process took me 7 minutes, I'm guessing the swap itself should take about 90 seconds at most ! Hope that helps someone |
#3 |
Great tutorial! I had started a thread about these focusing screens a couple of weeks ago. I was wondering exactly how it was done. Most everyone said it was easy but couldn't really explain or I couldn't really visualize. This really helps a lot! Good job!
Canon EOS 40D || 10-22mm EF-S || 24-70mm f/2.8L ||70-200mm f/2.8L IS || 50mm f/1.8 II || 60mm f/2.8 Macro EF-S |
| sponsored links |
#4 |
wut the heck, i didnt even know canon made a focusing screen
does this screen have the circle in the center to help you manually focus like the haodas? but i guess it wont matter cuz i dont have a 40d
www.iamLKC.com - leave a comment or two it can only help me grow =) Last edited by kaitanium : 5th of December 2007 (Wed) at 17:44. |
#5 |
Thanks for showing us this!
Canon 40D | EF-S 17-55 f/2.8 IS w/ ridiculously overpriced lens hood | EF 70-200mm f/4L | EF 50mm 1.8 | 430 EX | BG-E2N | Hakuba HG-503MX | Bogen 488RC2 |
#6 | |
mine has a defect too towards the center, I took the screen back out and it looks like the coating on the screen is uneven at that spot .... I wonder if I should call Canon or the place I bought it at (Adorama) ? |
#7 | |
No but they make the Ef-S which is for manual focusing, but is better with f/2.8 or better lenses, otherwise it will make the viewfinder quite dark |
#8 | |
Yup remember seeing your thread and this is why I made the DIY, I had ordered my screen I think the day before you posted it, and then I remember seeing your thread and I thought, hey, I am not the only one out there that would like an idea of what's involved before buying one, so I decided I'd make a DIY when I installed mine and here it is |
#9 |
is the screen with the grid lines any brighter than the original one? just wondering if I should try one or pay more for the katz eye brighter one.
5D, 40D and some L glass. |
#10 |
I want a katz one with a focus ring, but i really think I'm going to have someone do it. I just don't have the guts.
#11 |
don't think it's brighter but I know it will not mess up the metering like the katz eye does, oh and it is so easy to swap it's not even funny lol
#12 | |
Moderator
Mark
Mark ----- Some primes, some zooms, some Ls, some bodies. Bodies come and go, glass is forever. My G&N Blog - My Complete Gear List - Mac-Photo G&N FORUM EARLY ACCESS & IMAGE POSTING RULES |
#13 |
The Katz Eye screens look pretty sweet. But unfortunately they have all different kinds of varied exposure compensation to use based on different compositions. For this reason there is no way I would get one. With the Canon OEM focusing screens all you do is change the Custom Function and the exposure value change is all automatic. No manual setup or thinking. I don't like thinking. It makes my brain sweat!
#14 |
I have the Katz Eye screen, but without the split prism. I haven't noticed much in the way of metering issues with it. Mine's got their "OptiBrite" treatment. I got it because I wanted more precision than the standard Canon screen without sacrificing brightness and I wanted a "rule of thirds" grid.
The screen works quite nicely in my experience. I use the Ef-A setting in the camera. Note that I haven't done any formal testing of the metering accuracy. About the only real downside of the screen is that it's rather expensive. The Canon screens are about $35 apiece. Unless you really want the specific features of the Katz Eye, you're probably better off sticking with the Canon screens.
"There are some things that money can't buy, but they aren't Ls and aren't worth having" -- Shooter-boy 50D, 40D, 30D, 18-55 kit lens (surprisingly good), Sigma 18-50 f/2.8 Macro, 24-105L IS, 70-300 IS, Sigma 50/1.4, 35/2.0, Sigma 10-20, 430EX. |
#15 |
I say stupid things all the time
that's really cool
thanks for doing it. I have the 40D and been thinking about doing the same thing at some point. I was wondering how it was done. I just have one question, do the focus points still show up?
| Thread Tools | |
| Display Modes | |
| Anyone got the Ef-s focusing screen for their 40D? | Grimm75 | Canon EOS Digital Cameras | 25 | 21st of January 2009 (Wed) 18:34 |
| 40D - Small debris on focusing screen | krepta | Canon EOS Digital Cameras | 21 | 19th of March 2008 (Wed) 03:18 |
| EOS 40D Focusing Screen | hdflock | Canon EOS Digital Cameras | 2 | 16th of September 2007 (Sun) 14:42 |
| 40D Focusing Screen | Souwalker | Canon EOS Digital Cameras | 31 | 25th of August 2007 (Sat) 22:46 |
